I've been rehabing an old Weidemann turret punch for the past month and finally have everything working with the exception of the T axis servo (the one that spins the turret). Whenever I go to zero out the machine all of the other servos behave as they should but T does nothing. If I take the servo out and put it on a different axis it works fine and I've also swapped cables. Oddly the servo amp board has no error lights on and the fanuc controller shows no problem with it in the diagnostics screen. Has anyone ever seen an issue like this? Any thoughts or suggestions would be much appreciated.
