586,389 active members*
2,967 visitors online*
Results 1 to 11 of 11
    Sep 2013
    8
    Looking for Fanuc I.C. pinout.
    I am servicing a Fanuc power supply and am looking for a pinout for Fanuc IC HA16630G.
    Jan 2013
    119
    Look in the datasheet!
    Sep 2013
    8
    I have not been able to locate a datasheet for this device. Do you have one?
    Aug 2007
    793
    Attachment 216852
    what's on?
    Sep 2013
    8
    Thanks. All the supplies look good and clean. It is the voltage monitor circuitry that is failing. The output (pin 9) is at 8v where should be at zero volts to drive the control circuit. Pins 3 & 23 are at 0v where they are at +14V on a good board. Thus the System Enable line is signaling a failure to the rest of the system. I suspect this IC is bad. I found one on ebay. I guess I will try it.
    Thanks again
    Aug 2007
    793
    I faced with bad voltage monitor in this IC two times. added an ordinary voltage supervisor and all is ok
    Sep 2013
    8
    Not a bad ideal! Do you monitor just the 24V supply or the +-15V supplies also?
    Mar 2014
    Re: Looking for Fanuc I.C. pinout.
    Can you send me datasheet of IC HA16630? I have trouble same to you, I have been trying to find it but i haven't found any ones. Or Can you give me some advance?
    Aug 2007
    793
    The only we have is that schematics, from what we can see where to add supervisor
    Mar 2014
    thanks for help. i have solve my problem
    Feb 2016
    11
    Quote Originally Posted by ngoc_003 View Post
    Hello
    Please I have some issue whats you found in the board ?thank you
  1. Replies: 3
    Last Post: 03-17-2015, 01:22 PM
  2. Fanuc PulseCoder pinout, mising quadrature?
    By laserted in forum Fanuc
    Last Post: 11-12-2013, 06:48 PM
  3. I need the pinout for a Fanuc Servo Motor (6 pin/wire)
    By Fonzi in forum Servo Motors / Drives
    Last Post: 11-07-2013, 04:44 PM
  4. Fanuc pulse coder pinout?
    By Jonne in forum Servo Motors / Drives
    Last Post: 02-02-2013, 03:49 AM
  5. FAnuc components pinout
    By Lrapso in forum Fanuc
    Last Post: 05-17-2012, 09:05 PM
