Originally Posted by
wizard
One idea I've been flipping through my head is turning regular extrusions 45 degrees to run rollers on the corners of the extrusions. I have a pile of salvaged extrusions but little else at the moment.
I wonder if the extrusion will tend to splay open if there is any significant preload on it. With the beveled edges, you could fit a 0.5"x0.5" cold-rolled steel bar into the extrusion's slot, edge up. If you could secure it well (this would be the hard part) then steel V-rollers could ride on it fairly well,
Paul Rowntree
Vectric Gadgets, WarpDriver, StandingWave and Topo available at PaulRowntree.weebly.com
