Unsuccessful ignition of SteelTailor CNC cutting machine?
New year is coming! Happy New Year 2014!
This problem maybe caused by following :
1. The SteelTailor CNC cutting machine power supply of the CNC and plasma power source is abnormal.
2. The distance between the torch and job is too long. Standard distance is 1mm~1.3mm.
3. The grounding cable of the plasma power source is not connected to the job.
4. Lack of Air pressure.
5. There is a failure with the relay inside the electrical box.
6. Consumable worn out.
Hope you can get what you need and solve your problem. If this still can't solve your problem. Pls email at [email protected]
More information about SteelTailor FAQ:
FAQ - Parts&Service - SteelTailor offers portable CNC cutting machines,portable table plasma cutting machine,CNC plasma and flame cutting machine,cnc plasma cutters
SteelTailor--The world leader of portable CNC cutting machine
www.steeltailor.com
