586,842 active members*
3,155 visitors online*
Thread: Rapid moves
    Jan 2011
    20
    Rapid moves
    I have programmed 3 small profiles, when it post them the moves between the profiles are Feed moves, which the way the post is outputting is a 3 axis feed move which machines though the materal getting to the next profile. I think if the output was a Rapid move it would move Z first then positon. Is this something I missed in my program or is there something in the post to cover this? Mike
    Aug 2012
    621
    It sounds like the Rapid Plane, Feed Plane, and/or Top of Part values may not be set correctly for your setup. If you have Top of Part at 0.00, for instance, the Rapid and Feed planes need to be set above that. Can you zip the .bbcd file and post it? That'd help to determine exactly what the problem is.
    Luke
    "All I'm trying to find out is the fellow's name on first base" -- Lou Costello
    Jan 2011
    20
    I changed my program to put each profile in a Machining sequence of its own and that helped because it forced rapids to be output, I then added mulitable depths works good until it gets to the finish pass then would mill across part. I am attaching the program, the post and the output which I marked up 2 of the errors. I cannot figure out how to NOT take a finish pass when using profile, I am sure there must be a way but I could not figure it out. Mike
    Aug 2012
    621
    Set the Finish tool diameter to zero. BobCAD will interpret that as "no tool" and it will disable the finish pass.
    Luke
    Aug 2012
    621
    I'm a little puzzled, looking at your file. You should be able to put all the features into one Machine Setup and have it run them sequentially, with no gouging issues. I might set the part up a little differently, perhaps using an open pocket for the long curved slot down to -2.5, then a profile to cut the outer 0.75' slot down to -3.1, but that's just a choice to reduce the number of rapids caused by the profile strategy. I suspect that the problem you encountered is in your Post Processor file, but I'm not well-versed in the various PP settings. Maybe some of the more experienced folks can find something there to help you out.
    Luke
  1. Sometimes no Z rapid moves
    By paradiddle in forum Surfcam
    Last Post: 07-03-2012, 08:01 PM
  2. VSD-A Error #9 on some rapid moves
    By nicad in forum CNC Machine Related Electronics
    Last Post: 07-19-2011, 08:06 PM
  3. Rapid tool moves when not cutting?
    By Fleck in forum G-Code Programing
    Last Post: 04-22-2009, 07:26 AM
  4. Newbie - torch dragging on rapid moves
    By bad-rat-57 in forum Waterjet General Topics
    Last Post: 07-10-2008, 12:45 PM
  5. Rapid moves G00
    By dicksonhof in forum Mach Software (ArtSoft software)
    Last Post: 11-07-2006, 04:21 PM
