I am doing a fairly simple part that requires milling around the edge and then some holes inside.
The end mill I'm using is 6mm and the holes I want are 6mm. I've already guessed that Solidcam won't allow me to do that. Keep in mind this is only the second piece I've ever cnc'ed.
So I've added a second operation and thought that doing a tool change is the way forward. I've changed the tool to 4mm diameter and now it mills the already milled edges before doing the holes. How do I get it to just do the holes?
I thought adding a second operation using the 6mm end mill but instead of doing a '3d mill' operation doing a '3d drill' operation instead might work but it keeps coming up with 'geometry not selected'.
Any help would be appreciated.
Cheers
Raf
Mostyn Cafe n Customs Homepage Mostyn
Cafe Racer and Custom Bike Builds
