586,753 active members*
7,301 visitors online*
    Converting 18i-MB to 18i-TB ?
    I've got two 18i-MB and need a controller for a lathe.
    Is there anyone with an idea how to convert a 18i-MB to a 18i-TB
    Uli
    Aug 2011
    2517
    the main difference is the system software.
    You need to install the lathe version. On 18i it will be in flash ROM.
    then a few parameters need to be changed.
    you may be able to get it to work simply by removing the Y axis with a parameter
    Thanks, that's what I expected.
    Any idea of what this could cost?
    Apr 2009
    1379
    If you have an earlier motherboard version, then it is fairly simple and costs nothing, as long as you have the lathe software. The later motherboards required a program from Fanuc to enable options, and may require Fanuc to come in. Let us know what happens.
    This is for sure the point. I've got the 18i-MB5 and it has the milling software. I doubt having the lathe software somewhere hidden in the system....
    It's really difficult to get answers from Fanuc Germany if you do not have a professional account there. And you can't get it without a business tax (VAT) number.
    Apr 2009
    1379
    You can copy the lathe software from a friend's machine. I may be able to get it, but I have never done it on a iB series- only earlier controls.
    What are your motherboard part #s?
  1. converting to dxf
    By laserninja in forum MetalWork Discussion
    Last Post: 07-27-2013, 08:45 PM
  2. Can I get help converting .tap to .bpp
    By Mattheww in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-22-2013, 09:02 PM
  3. converting to dxf
    By maxter41 in forum MetalWork Discussion
    Last Post: 04-16-2013, 02:00 AM
  4. Converting X1
    By iflymyhelishigh in forum Benchtop Machines
    Last Post: 12-23-2008, 03:23 AM
  5. Converting to 3 ph with a VFD
    By reabdet21 in forum Uncategorised MetalWorking Machines
    Last Post: 07-17-2007, 03:28 PM
