586,352 active members*
3,291 visitors online*
IndustryArena Forum > CAM Software > SolidCAM for SolidWorks and SolidCAM for Inventor > Adding tabs and changing the order of plunge etc
    Mar 2013
    82
    I'm definately new to this so please excuse my ignorance. Currently I am cutting my part out if stock and leaving .5mm at the bottom so it doesn't move about.
    My question is do I have to define where I want tabs manually to hold the small 3mm thick part in place (roughly the size of a golf ball or can Solidcam do this for me?
    The next question is, rather than do the edge and then come in to do plunge cuts on the part (3 holes) is there a way of reversing it so it does holes first and then the edge?
    Many thanks
    Mostyn Cafe n Customs Homepage Mostyn
    Cafe Racer and Custom Bike Builds
    Aug 2008
    14
    Tabs in SC is not the easiest but I got a working solution that I'm using from guru_florida in another thread, link below. If you figure out any other way I'm happy to try it..
    http://www.cnczone.com/forums/solidc...ml#post1174949
    Mar 2013
    82
    Cool I was doing one of the suggestions already. Ido like the idea of Solidcam 2012 though lol
    Www.mostynindustries.com.au
  1. Changing the order of operations?
    By doublec4 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 01-15-2013, 05:10 AM
  2. Adding tabs to existing file
    By budpage in forum CamBam
    Last Post: 03-22-2011, 03:10 AM
  3. Help changing plunge and retract location
    By SWATH in forum Visual Mill
    Last Post: 01-06-2011, 10:22 PM
  4. Changing order of the wizards table in Mach
    By Phishaholic in forum Tormach Personal CNC Mill
    Last Post: 08-23-2009, 05:04 PM
  5. Adding Tabs With MasterCam V9
    By mmcclain02 in forum Mastercam
    Last Post: 01-20-2006, 08:53 PM
