Hey fellas. I'm trying to offset-turn a part.
This is the code that i made.
M35 (c-axis engage)
T0303
G98G0Z2.C0.M8
X90.Y0.
#100=2.
N100G17G3I-3.J0.W-0.2H-360.F3000.
#100=#100-0.2
IF[#100GE-150.]GOTO100
Machine is Puma3100LY with Fanuc I-series control.
Now for some reason the machine is popping out an alarm "0020 over tolerance radius".
I tried to run the code omitting the H-360. for c axis and it worked fine.
I don't see any reason why the arc calculation should be affected by this since it's not lying on the same plane where the circle is.
And the manual says 2 more axes can be added as long as it's not on the same plane.
I can mill the jaws to offset the part but that would be an additional set up and there's very small stock to clamp the part, only 12mm so I can't imagine turning this without the tailstock engaged and I won't be able to do that using offset jaws.
Anybody got any idea about this?
Uly
