587,048 active members*
2,879 visitors online*
IndustryArena Forum > Other Machines > Machine Created Art > My collection of machine created art and stuff :)
Results 1 to 10 of 10
    Nov 2012
    43
    Hello all,
    Thought I would share what i have created with my homebuilt cnc.
    It is only a small desktop machine with a cutting area of X-370mm, Y-285mm, Z-70mm with an Ozito 850w router for spindle driven by SuperPID (best purchase ever!), 3A Nema23 steppers driven by the Massmind.org thb6064 driver kits.
    This is just a hobby for me and a thoroughly enjoyable one at that.
    So enough natter and on with the pics
    Here is the latest creation, a ball bearing maze made from mdf and clear acrylic.
    These were my own design drawn up in bobcad v24.
    Just single sided with an 11mm diameter steel ball.
    Attachment 214812
    This is another maze, but this time 2 sided and a bit smaller using 8mm steel ball (2 or more balls to make it a bit more of a challenge)
    Side 1
    Attachment 214814
    Side 2
    Attachment 214816
    Some V-Carvings from a little while ago. done with a 90degree v bit.
    These were just images taken from google and vectorized
    I stained the mdf first then carved it with some of them.
    Attachment 214818
    Attachment 214820
    Attachment 214822
    Attachment 214824
    Couple of 3d puzzles
    Purchased the landrover plans from Makecnc.com, well worth it as you get very detailed assembly instructions and dxf files for both mm and inch.
    Attachment 214826Attachment 214828
    Attachment 214830
    Bought a rotary axis from fleabay for $280 and had a bit of a play.
    Attachment 214834
    Attachment 214836
    Attachment 214838
    Did a few Lithophanes with the 4th axis on white pvc pipe, lit up with led torch in the first one
    Attachment 214840Attachment 214842
    This one i painted the pipe black first and carved a base and top for it and lit it with led strip light.
    This is my sons night light now, he loves it!
    Attachment 214844Attachment 214846
    Attachment 214848Attachment 214850
    And another V-carve, different method this time. Still just an image from google and vectorized but stained the mdf black before carving.
    Attachment 214852
    I have done a lot more but didn't take photos of them and have gifted them away.
    I will post more pics of creations as i do them or find pics of
    Feel free to ask any questions about machine and what not, be glad to share.
    Such an addictive hobby that's for sure
    Jan 2010
    2141
    The PVC pipe lithophanes are very interesting to me.
    I'm having trouble enlarging the photos - what is the diameter of the PVC pipe that you used? Are the engravings very deep? How much material must be removed from the pipe thickness in order for light to be visible through the engraving?
    6855
    Very nice I like that truck!
    Nov 2006
    227
    You can see the Bic lighter in the first pic (for scale)...
    PVC pipe creates a very nice effect!
    Nov 2012
    43
    thanks for the comments!
    Doorknob, the pvc pipe i used here is 50mm diameter with a wall thickness of 3mm. i think from memory the cut depth was about 1mm.
    the light will shine through the pipe no problems, the cut depth just determines how much light is needed to properly illuminate the litho.
    I also have some 80mm diameter stormwater pipe i want to try out, its a lot thinner walled at 1.5mm so cut depth would probably only need to 0.5mm or so.
    oh and heres a couple more pics i found.
    A scaled down Telecaster, my first attempt at 2 sided machining on the neck ( can probably see where i didn't set safe z high enough and ploughed thru the neck haha )
    Attachment 214968Attachment 214970
    and in the spirit of christmas, wifey decorated it after i cut it out.
Name:	xmas tree 3.jpg
    Nov 2012
    43
    Hi all back again with another creation.
    Made another litho, this time on a flat piece of cast acrylic and drew up a frame/ lightbox for it.
    Found the frame pattern on google, then vectorized it in v-carve.
    Stained the 16mm mdf prior to carving.
    The litho is a perfect press fit into the rebate in the frame, had to do some light sanding of the litho edges for the perfect fit but didn't take much
    Lit up with led strip light stuck around the inside of the light box area and added a few slots to the back cover for ventilation.
    Attachment 215146Attachment 215148Attachment 215150
    Nov 2012
    43
    Re: My collection of machine created art and stuff :)
    Still at it, More stuff!
    Picked up a bunch of 6061 ally scrap from boat builders and had a play with 2 sided machining again.
    This one is from 1" 6061 scrap piece.
    Milled the block to 90x90mm with holes in the corners to match my baseplate hold down holes so when i flipped the peice and screw it back down it will be in the right place.
    Did the v-carving first with a 22mm 90 degree v bit, wasn't sure how well it would work but it worked very well.
    I nearly got it right, i missed by about 0.2mm as you might be able to see, next time i'll set up a fence to more accurately position the stock.
    Some horrible tool marks on the outside surface of the bottom piece, i suspect it was from ramping the plunges and the bit chattering also cheap chinese end mill too.
    Not bad for a test tho
    Attachment 245804Attachment 245806
    Attachment 245808Attachment 245810
    Fits together quite well, not sue what I'll use it for yet maybe a little grease pot or something like that
    Attachment 245812
    Nov 2012
    43
    Back again!
    More aluminium v-carving, this time just a couple of small keyring size items.
    Still using my chinese 90 degree vee bit, working very well.
    0.2mm DOC with 0.1mm stepover at 21000rpm and 1300mm/min
    This time i spray painted them, let them dry then finely sanded off the high points to leave the paint in the v-carving.
    Aussie 5 cent piece for size comparison
    Attachment 251388
    Attachment 251398
    Attachment 251400
    Attachment 251402
    Attachment 251404
    Jul 2005
    18
    very nice work.
    Jul 2010
    98
    Very inspiring stuff. Nice work.
    Thanks for sharing
  1. Anyone looking into Machine Data Collection - Free Webinar
    By norm61 in forum News Announcements
    Last Post: 01-30-2014, 03:45 AM
  2. My machine created art
    By Chill_Factor in forum Machine Created Art
    Last Post: 12-11-2008, 06:03 PM
  3. Machine data collection
    By clujan in forum Haas Mills
    Last Post: 04-30-2008, 11:07 PM
  4. MCA (Machine Created Art)
    By j m in forum Machine Created Art
    Last Post: 08-27-2007, 01:44 PM
  5. Mach3 tuning (cuts small stuff fine, but is off on big stuff)
    By jdbaker in forum Mach Software (ArtSoft software)
    Last Post: 03-15-2007, 05:30 PM
