Originally Posted by
rs4race
Thanks for the replies guys, after some more searching I have found I can use the usb or ethernet smoothstepper with the setup above. I'm leaning towards the ethernet version for reliability. I am curious about the rated speeds of them though usb at 2Mhz and ethernet at 4Mhz. The Stepper drivers are limited up to 200khz, so it seems that even 2Mhz is way overkill. I also found winformach64, but the information is limited on this. All of my PC's are 64bit and I wonder if this might be a better option, its also ethernet.
Looks like Im gonna go with
(1) MX3660 3-axis Digital Driver $259.95
(3) KL23H2100-50-4B (3/8” Dual shaft with a flat) 570 oz-in $54.95 / $164.85
(1) KL-600-48 48V/12.5A Power Supply $129.95 or Kl-4813 48V/13A Unregulated - $139
(1) Ethernet Smoothstepper - $189
Is there anything else special that I should be looking at?
As far as steppers are concerned, yes both the USB and Ethernet Smooth Stepper pretty much drive them identically. The 4MHz max step frequency allows the Smooth Stepper to produce a more accurate (smoother) step pulse train.
The practical advantage of Ethernet over USB is that the Ethernet interface uses a differential paired wiring resulting in an interface that is more resilient to Electrical noise (EMI).
I always recommend to my customers to go for the Ethernet SmoothStepper unless their budget is really tight.
Also the Ethernet SS has 3rd parallel port which is great for pendants, tool-changers, etc
Cheers,
Peter
Homann Designs - http://www.homanndesigns.com/store
