586,780 active members*
3,849 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Tooling Plate for BF30 Milling Machine
Results 1 to 9 of 9
    Aug 2005
    180
    Just thought I'd post some pictures of the tooling plate I made today for my BF30 mill.
    Its made from a piece of 450mm x 250mm x 25mm tooling plate aluminium sourced locally from Durbin Metals, Bristol - these guys are really friendly and could be a good source of materials (I am not associated with this company).
    It has alternate M10 reamed holes and M10 thread holes on an 25mm pitch. The M10 threaded holes are also counter bored to allow them to take threaded tooling pins. I bought some hardened M10 tooling pins on ebay and these are a nice tight push fit in to the reamed holes.
    All machining was lubricated using parafin rather than WD40 - cheaper for me.
    I cut bolt holes to meet up with the T slots on the mill table, the middle holes at either end are reamed M10 to accept locating stubs that will be machined to be a close sliding it with the M12 mill T slots.
    All up, it took around 2.5 hrs to make and should be really useful.
    I used the tapping feature on the BF30 mill - once set up this works really well when using a spiral point tap.
    Apr 2005
    862
    Looks very nice.
    Thanks for the tip on that supplier, never heard of them but they are only 15 minutes from my house!
    LongRat
    www.fulloption.co.uk
    Aug 2005
    180
    Yes their website looks like they only supply large quantities but a telecon revealed that they will supply small lengths of material. Guy on the phone was very helpful.
    Aug 2006
    1602
    That looks really good!
    Are you going to add alignment dowels to your table, or do you plan to just align it once and leave it on there?
    Apr 2006
    13
    Re: Tooling Plate for BF30 Milling Machine
    I know this was posted some time back, but are you able to give a quick tutorial on how to (and how not to) use the tapping feature on the BF30?
    Would really appreciate this...
    Thanks !
    Aug 2005
    180
    Sure, first off with large taps you really need a dedicated tapping chuck. Set the machine in to tapping mode, select low gear and slowest spindle speed. Experiment in free air with the quill down feed and different settings on the depth stop. The depth stop has sensors in it for spindle start and reverse. With a bit of fiddling you can set it to start just above the workpiece and reverse as the tap exists. I wouldn't trust it for blind holes!
    Clean and lube the tape between hole - I also use spiral point tapes for machine work.
    Apr 2006
    13
    Thank you !
    So a tapping collet will not replace a dedicated tapping chuck?
    Thank you again!
    Aug 2005
    180
    It should be OK as long as it can drive the square section of the tap. A normal collet will slip as the tap gets larger and material gets stronger I.e. M10 in mild steel needs a very positive drive.
    Apr 2006
    13
    Agree, Thank you!
  1. Surfacing aluminum plate, for tooling plate
    By 30dayo in forum Material Machining Solutions
    Last Post: 12-21-2013, 11:29 PM
  2. Can anyone machine a tooling plate for me?
    By Nateg281 in forum Benchtop Machines
    Last Post: 06-29-2010, 02:35 AM
  3. Have the milling machine, now I need tooling
    By Coryc in forum Uncategorised MetalWorking Machines
    Last Post: 03-25-2010, 05:11 AM
  4. Any tips for designing a fixture plate / tooling plate?
    By thackman in forum Benchtop Machines
    Last Post: 12-19-2008, 06:26 PM
  5. Aluminum: flat, bar, sheet, plate, tooling plate??????????
    By Dan S in forum DIY CNC Router Table Machines
    Last Post: 06-28-2007, 06:48 AM
