586,416 active members*
3,822 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > V25, 4th axis basic. Odd things. see screenshot, post processor and code.
Results 1 to 8 of 8
    Oct 2005
    278
    Here's the issues-
    1. if I set the stock wizard for a cylindrical workpiece and then generate code to cut a shape inside it (as pictured in the screen shot) why will it just generate code off the parts geometry. Shouldn't it allow me to generate code starting at the boundary of the stock and machine into the stock until I reach the parts geometry?
    What's the point of being forced to run the stock wizard, if the code fails to see the stock as stock to be removed?
    to run this part, without being able to start at the stock is irritating. I can only start at a level I pick for the start, BUT that level is dependant upon the Z location of the geometry underneath it. SO...I am stuck with cutting huge amounts of stock on some parts in a single pass, and very little stock when cutting at Z locations with a higher Z value of the part geometry.
    2. I am using a Mach3 PP written by bobcad (attached) it seems to send the tool to Y0 after a program completes. How can I eliminate this in the PP?
    3. The simplest part of my part geometry (pictured) is the cylinder at the base of the skull. This should be the fastest part of the program. The cyl is concentric with my A axis, and should cut quite quickly seeing as it only has go to Z(location) and rotate in the A axis.
    Instead it seems to break up the cylinder into many many different segments (not of consistant angular size mind you) and this takes forever to cut. Oddly, the coordinated Z and A cuts for the skull seem to go much faster than the cuts for the cylinder.
    4. I seem to have the A axis's rotation stop after every line of code that uses it. I would think that their would be a way to have it more smoothly flow into the next line. Is this a PP issue or one in Mach3?
    The machine is a BP with a peiseiler 4th axis all running steppers/SmoothStepperUSB/mach3.
    Thoughts?
    Nate.
    Ann Arbor Meechigan
    Oct 2005
    278
    Nate.
    Ann Arbor Meechigan
    Oct 2005
    278
    post attached
    Attached Files Attached Files
    Nate.
    Ann Arbor Meechigan
    Oct 2005
    278
    Code sample attached.
    O100
    (PROGRAM NUMBER)
    ( FIRST MACHINE SETUP - Machine Setup - 1)
    (PROGRAM NAME - CODEFOREXAMPLE..NC)
    (POST - MACH3 V25 3AXIS)
    (DATE - WED. 12/18/2013)
    (TIME - 02:48PM)
    N01 G20 G40 G49 G91.1
    (FIRST CUT - FIRST TOOL)
    (JOB 1 Feature 4Ax-Rotary)
    (FEATURE 4AX-ROTARY)
    (TOOL #1 0.1 ENDMILL ROUGH)
    N02 T1 M6
    N03 A -99720.
    N04 S9549 M03
    N05 G00 G90 G54 X-8.55 Y0.
    N06 G43 H1 Z3.5926 M08
    N07 Z0.2609
    N08 G01 Z0.1609 F114.5916
    N09 G93 Z0.1624 A-99717.234 F9999.99
    N10 Z0.1643 A-99714.461 F9999.99
    N11 Z0.1667 A-99711.695 F9999.99
    N12 Z0.1696 A-99708.922 F9999.99
    N13 Z0.1732 A-99706.156 F9999.99
    N14 Z0.1774 A-99703.383 F9999.99
    N15 Z0.1823 A-99700.617 F9999.99
    N16 Z0.188 A-99697.844 F9999.99
    N17 Z0.1945 A-99695.078 F9999.99
    N18 Z0.199 A-99692.305 F9999.99
    N19 Z0.2024 A-99689.539 F9999.99
    N20 Z0.2065 A-99686.766 F9999.99
    N21 Z0.2113 A-99684. F9999.99
    N22 Z0.2169 A-99681.234 F9999.99
    N23 Z0.2234 A-99678.461 F9999.99
    N24 Z0.2308 A-99675.695 F9999.99
    N25 Z0.2394 A-99672.922 F9999.99
    N26 Z0.2492 A-99670.156 F9999.99
    N27 Z0.2576 A-99667.383 F9999.99
    N28 Z0.2647 A-99664.617 F9999.99
    N29 Z0.2729 A-99661.844 F9999.99
    N30 Z0.2824 A-99659.078 F9999.99
    N31 Z0.2897 A-99656.305 F9999.99
    N32 Z0.297 A-99653.539 F9999.99
    N33 Z0.3055 A-99650.766 F9999.99
    N34 Z0.3102 A-99649.383 F9999.99
    N35 Z0.3152 A-99648. F9999.99
    N36 Z0.3206 A-99646.617 F9999.99
    N37 Z0.3264 A-99645.234 F9999.99
    N38 Z0.3304 A-99643.844 F9999.99
    N39 Z0.3346 A-99642.461 F9999.99
    N40 Z0.3371 A-99639.695 F9999.99
    N41 Z0.3391 A-99636.922 F9999.99
    N42 Z0.3421 A-99634.156 F9999.99
    N43 Z0.346 A-99631.383 F9999.99
    N44 A-99628.617 F9999.99
    N45 Z0.3421 A-99625.844 F9999.99
    N46 Z0.3391 A-99623.078 F9999.99
    N47 Z0.3371 A-99620.305 F9999.99
    N48 Z0.3345 A-99617.539 F9999.99
    N49 Z0.3304 A-99616.156 F9999.99
    N50 Z0.3264 A-99614.766 F9999.99
    N51 Z0.3206 A-99613.383 F9999.99
    N52 Z0.3151 A-99612. F9999.99
    N53 Z0.31 A-99610.617 F9999.99
    N54 Z0.3052 A-99609.234 F9999.99
    N55 Z0.2967 A-99606.461 F9999.99
    N56 Z0.2896 A-99603.695 F9999.99
    N57 Z0.2824 A-99600.922 F9999.99
    N58 Z0.2727 A-99598.156 F9999.99
    N59 Z0.2645 A-99595.383 F9999.99
    N60 Z0.2575 A-99592.617 F9999.99
    N61 Z0.249 A-99589.844 F9999.99
    N62 Z0.239 A-99587.078 F9999.99
    N63 Z0.2302 A-99584.305 F9999.99
    N64 Z0.2225 A-99581.539 F9999.99
    N65 Z0.2162 A-99578.766 F9999.99
    N66 Z0.2107 A-99576. F9999.99
    N67 Z0.2061 A-99573.234 F9999.99
    N68 Z0.2022 A-99570.461 F9999.99
    N69 Z0.199 A-99567.695 F9999.99
    N70 Z0.1945 A-99564.922 F9999.99
    N71 Z0.1876 A-99562.156 F9999.99
    N72 Z0.1818 A-99559.383 F9999.99
    N73 Z0.1769 A-99556.617 F9999.99
    N74 Z0.1726 A-99553.844 F9999.99
    N75 Z0.1691 A-99551.078 F9999.99
    N76 Z0.1661 A-99548.305 F9999.99
    N77 Z0.1637 A-99545.539 F9999.99
    N78 Z0.1619 A-99542.766 F9999.99
    N79 Z0.1606 A-99540. F9999.99
    N80 Z0.1597 A-99537.234 F9999.99
    N81 Z0.1594 A-99534.461 F9999.99
    N82 Z0.1562 A-99531.695 F9999.99
    N83 Z0.153 A-99528.922 F9999.99
    N84 Z0.1503 A-99526.156 F9999.99
    N85 Z0.1482 A-99523.383 F9999.99
    N86 Z0.1465 A-99520.617 F9999.99
    N87 Z0.1454 A-99517.844 F9999.99
    N88 Z0.1447 A-99515.078 F9999.99
    N89 Z0.1444 A-99512.305 F9999.99
    N90 Z0.1447 A-99509.539 F9999.99
    N91 Z0.1453 A-99506.766 F9999.99
    N92 Z0.1465 A-99504. F9999.99
    N93 Z0.1481 A-99501.234 F9999.99
    N94 Z0.1484 A-99498.461 F9999.99
    N95 Z0.1487 A-99495.695 F9999.99
    N96 Z0.1494 A-99492.922 F9999.99
    N97 Z0.1505 A-99490.156 F9999.99
    N98 Z0.1493 A-99487.383 F9999.99
    N99 Z0.1486 A-99484.617 F9999.99
    N100 Z0.1483 A-99481.844 F9999.99
    N101 Z0.1484 A-99479.078 F9999.99
    N102 Z0.149 A-99476.305 F9999.99
    N103 Z0.1501 A-99473.539 F9999.99
    N104 Z0.1498 A-99470.766 F9999.99
    N105 Z0.1484 A-99468. F9999.99
    N106 Z0.1476 A-99465.234 F9999.99
    N107 Z0.1472 A-99462.461 F9999.99
    N108 Z0.1473 A-99459.695 F9999.99
    N109 Z0.1478 A-99456.922 F9999.99
    N110 Z0.1488 A-99454.156 F9999.99
    N111 Z0.1504 A-99451.383 F9999.99
    N112 A-99448.617 F9999.99
    N113 Z0.149 A-99445.844 F9999.99
    N114 Z0.148 A-99443.078 F9999.99
    N115 Z0.1475 A-99440.305 F9999.99
    N116 Z0.1474 A-99437.539 F9999.99
    N117 Z0.1477 A-99434.766 F9999.99
    N118 Z0.1485 A-99432. F9999.99
    N119 Z0.1498 A-99429.234 F9999.99
    N120 Z0.1502 A-99426.461 F9999.99
    N121 Z0.1493 A-99423.695 F9999.99
    N122 Z0.1486 A-99420.922 F9999.99
    N123 Z0.1484 A-99418.156 F9999.99
    N124 Z0.1487 A-99415.383 F9999.99
    N125 Z0.1494 A-99412.617 F9999.99
    N126 Z0.1505 A-99409.844 F9999.99
    N127 Z0.1495 A-99407.078 F9999.99
    N128 Z0.1489 A-99404.305 F9999.99
    N129 Z0.1485 A-99401.539 F9999.99
    N130 Z0.1481 A-99398.766 F9999.99
    N131 Z0.1466 A-99396. F9999.99
    N132 Z0.1456 A-99393.234 F9999.99
    N133 Z0.145 A-99390.461 F9999.99
    N134 Z0.1449 A-99387.695 F9999.99
    N135 Z0.1453 A-99384.922 F9999.99
    N136 Z0.1461 A-99382.156 F9999.99
    N137 Z0.1472 A-99379.383 F9999.99
    N138 Z0.1487 A-99376.617 F9999.99
    N139 Z0.1507 A-99373.844 F9999.99
    N140 Z0.1532 A-99371.078 F9999.99
    N141 Z0.1563 A-99368.305 F9999.99
    N142 Z0.1594 A-99365.539 F9999.99
    N143 Z0.1599 A-99362.766 F9999.99
    N144 Z0.1609 A-99360. F9999.99
    N145 G94 X-8.5496 Z0.1658 F229.1831
    N146 X-8.5492 Z0.1707
    N147 X-8.5488 Z0.1755
    N148 X-8.5484 Z0.1802
    N149 X-8.5477 Z0.1882
    N150 X-8.5469 Z0.1954
    N151 X-8.5461 Z0.2026
    N152 X-8.5453 Z0.2098
    N153 X-8.5445 Z0.217
    N154 X-8.5437 Z0.2242
    N155 X-8.543 Z0.2314
    N156 X-8.5422 Z0.2386
    N157 X-8.5414 Z0.2457
    N158 X-8.5406 Z0.2528
    N159 X-8.5398 Z0.2598
    N160 X-8.5391 Z0.2661
    N161 X-8.5383 Z0.2718
    N162 X-8.5375 Z0.2776
    N163 X-8.5367 Z0.2834
    N164 X-8.5359 Z0.2891
    N165 X-8.5352 Z0.2949
    N166 X-8.5344 Z0.3007
    N167 X-8.5336 Z0.3064
    N168 X-8.5328 Z0.3122
    N169 X-8.532 Z0.3179
    N170 X-8.5313 Z0.3237
    N171 X-8.5305 Z0.3293
    N172 X-8.5297 Z0.335
    N173 X-8.5289 Z0.3406
    N174 X-8.5281 Z0.3459
    N175 X-8.5273 Z0.3507
    N176 X-8.5266 Z0.3556
    N177 X-8.5258 Z0.3605
    N178 X-8.525 Z0.3654
    N179 G93 Z0.3667 A-99357.234 F9999.99
    N180 Z0.3678 A-99355.844 F9999.99
    N181 Z0.3691 A-99354.461 F9999.99
    N182 Z0.3706 A-99353.078 F9999.99
    N183 Z0.3725 A-99351.695 F9999.99
    N184 Z0.3744 A-99350.305 F9999.99
    N185 Z0.3766 A-99348.922 F9999.99
    N186 Z0.3791 A-99347.539 F9999.99
    N187 Z0.382 A-99344.766 F9999.99
    N188 Z0.3835 A-99343.383 F9999.99
    N189 Z0.3853 A-99342. F9999.99
    N190 Z0.3873 A-99340.617 F9999.99
    N191 Z0.3897 A-99339.234 F9999.99
    N192 Z0.3923 A-99337.844 F9999.99
    N193 Z0.3952 A-99336.461 F9999.99
    N194 Z0.3985 A-99335.078 F9999.99
    N195 Z0.402 A-99333.695 F9999.99
    N196 Z0.4059 A-99332.305 F9999.99
    N197 Z0.41 A-99330.922 F9999.99
    N198 Z0.4124 A-99329.539 F9999.99
    N199 Z0.4149 A-99328.156 F9999.99
    N200 Z0.4177 A-99326.766 F9999.99
    N201 Z0.4208 A-99325.383 F9999.99
    N202 Z0.4243 A-99324. F9999.99
    N203 Z0.4281 A-99322.617 F9999.99
    N204 Z0.4322 A-99321.234 F9999.99
    N205 Z0.4367 A-99319.844 F9999.99
    N206 Z0.4415 A-99318.461 F9999.99
    N207 Z0.4468 A-99317.078 F9999.99
    N208 Z0.4524 A-99315.695 F9999.99
    N209 Z0.4567 A-99314.305 F9999.99
    N210 Z0.4613 A-99312.922 F9999.99
    N211 Z0.4664 A-99311.539 F9999.99
    N212 Z0.4718 A-99310.156 F9999.99
    N213 Z0.4776 A-99308.766 F9999.99
    N214 Z0.4837 A-99307.383 F9999.99
    N215 Z0.4891 A-99306. F9999.99
    N216 Z0.4949 A-99304.617 F9999.99
    N217 Z0.5011 A-99303.234 F9999.99
    N218 Z0.5079 A-99301.844 F9999.99
    N219 Z0.5135 A-99300.461 F9999.99
    N220 Z0.5192 A-99299.078 F9999.99
    N221 Z0.5253 A-99297.695 F9999.99
    N222 Z0.5319 A-99296.305 F9999.99
    N223 Z0.539 A-99294.922 F9999.99
    N224 Z0.5504 A-99292.156 F7987.5654
    N225 Z0.5563 A-99290.766 F9999.99
    N226 Z0.5627 A-99289.383 F9999.99
    N227 Z0.5696 A-99288. F9999.99
    N228 Z0.577 A-99286.617 F9999.99
    N229 Z0.583 A-99285.234 F9999.99
    N230 Z0.5898 A-99282.461 F7863.3519
    N231 Z0.5934 A-99281.078 F9999.99
    N232 Z0.5974 A-99279.695 F9999.99
    N233 Z0.606 A-99276.922 F7556.431
    N234 Z0.6079 A-99274.156 F7798.0352
    N235 Z0.6113 A-99271.383 F7727.9542
    N236 Z0.6135 A-99270. F9999.99
    N237 Z0.6113 A-99268.617 F9999.99
    N238 Z0.6079 A-99265.844 F7728.1144
    N239 Z0.606 A-99263.078 F7797.5262
    N240 Z0.5974 A-99260.305 F7557.9813
    N241 Z0.5934 A-99258.922 F9999.99
    N242 Z0.5898 A-99257.539 F9999.99
    N243 Z0.583 A-99254.766 F7862.3118
    N244 Z0.577 A-99253.383 F9999.99
    N245 Z0.5695 A-99252. F9999.99
    N246 Z0.5626 A-99250.617 F9999.99
    N247 Z0.5562 A-99249.234 F9999.99
    N248 Z0.5503 A-99247.844 F9999.99
    N249 Z0.5449 A-99246.461 F9999.99
    N250 Z0.5389 A-99245.078 F9999.99
    N251 Z0.5318 A-99243.695 F9999.99
    N252 Z0.5252 A-99242.305 F9999.99
    N253 Z0.5191 A-99240.922 F9999.99
    N254 Z0.5135 A-99239.539 F9999.99
    N255 Z0.5078 A-99238.156 F9999.99
    N256 Z0.501 A-99236.766 F9999.99
    N257 Z0.4947 A-99235.383 F9999.99
    N258 Z0.489 A-99234. F9999.99
    N259 Z0.4837 A-99232.617 F9999.99
    N260 Z0.4776 A-99231.234 F9999.99
    N261 Z0.4717 A-99229.844 F9999.99
    N262 Z0.4662 A-99228.461 F9999.99
    N263 Z0.4612 A-99227.078 F9999.99
    N264 Z0.4566 A-99225.695 F9999.99
    N265 Z0.4524 A-99224.305 F9999.99
    N266 Z0.4466 A-99222.922 F9999.99
    N267 Z0.4413 A-99221.539 F9999.99
    N268 Z0.4363 A-99220.156 F9999.99
    N269 Z0.4317 A-99218.766 F9999.99
    N270 Z0.4277 A-99217.383 F9999.99
    N271 Z0.424 A-99216. F9999.99
    N272 Z0.4206 A-99214.617 F9999.99
    N273 Z0.4175 A-99213.234 F9999.99
    N274 Z0.4148 A-99211.844 F9999.99
    N275 Z0.4123 A-99210.461 F9999.99
    N276 Z0.41 A-99209.078 F9999.99
    N277 Z0.4058 A-99207.695 F9999.99
    N278 Z0.4019 A-99206.305 F9999.99
    N279 Z0.3984 A-99204.922 F9999.99
    N280 Z0.3951 A-99203.539 F9999.99
    N281 Z0.3922 A-99202.156 F9999.99
    N282 Z0.3895 A-99200.766 F9999.99
    N283 Z0.3871 A-99199.383 F9999.99
    N284 Z0.385 A-99198. F9999.99
    N285 Z0.3832 A-99196.617 F9999.99
    N286 Z0.3818 A-99195.234 F9999.99
    N287 Z0.3791 A-99192.461 F9999.99
    N288 Z0.3764 A-99191.078 F9999.99
    N289 Z0.3741 A-99189.695 F9999.99
    N290 Z0.372 A-99188.305 F9999.99
    N291 Z0.3702 A-99186.922 F9999.99
    N292 Z0.3687 A-99185.539 F9999.99
    N293 Z0.3674 A-99184.156 F9999.99
    N294 Z0.3663 A-99182.766 F9999.99
    N295 Z0.365 A-99180. F9999.99
    N296 Z0.3648 A-99177.234 F9999.99
    N297 Z0.3643 A-99174.461 F9999.99
    N298 Z0.362 A-99171.695 F9999.99
    N299 Z0.3606 A-99168.922 F9999.99
    N300 Z0.3602 A-99166.156 F9999.99
    N301 Z0.3607 A-99163.383 F9999.99
    N302 Z0.3623 A-99160.617 F9999.99
    N303 Z0.364 A-99157.844 F9999.99
    N304 Z0.3642 A-99155.078 F9999.99
    N305 Z0.3631 A-99152.305 F9999.99
    N306 Z0.3629 A-99149.539 F9999.99
    N307 Z0.3638 A-99146.766 F9999.99
    N308 Z0.3656 A-99144. F9999.99
    N309 Z0.3669 A-99142.617 F9999.99
    N310 Z0.3684 A-99141.234 F9999.99
    N311 Z0.3702 A-99139.844 F9999.99
    N312 Z0.3722 A-99138.461 F9999.99
    N313 Z0.3746 A-99137.078 F9999.99
    N314 Z0.3771 A-99135.695 F9999.99
    N315 Z0.3766 A-99132.922 F9999.99
    N316 Z0.3769 A-99130.156 F9999.99
    N317 Z0.3781 A-99127.383 F9999.99
    N318 Z0.3791 A-99126. F9999.99
    N319 Z0.3803 A-99124.617 F9999.99
    N320 Z0.3818 A-99123.234 F9999.99
    N321 Z0.3836 A-99121.844 F9999.99
    N322 Z0.385 A-99119.078 F9999.99
    N323 Z0.3868 A-99116.305 F9999.99
    N324 Z0.3881 A-99114.922 F9999.99
    N325 Z0.3897 A-99113.539 F9999.99
    N326 Z0.3915 A-99112.156 F9999.99
    N327 Z0.3958 A-99109.383 F9999.99
    N328 Z0.3969 A-99106.617 F9999.99
    N329 Z0.3984 A-99103.844 F9999.99
    N330 Z0.3997 A-99101.078 F9999.99
    N331 Z0.4007 A-99099.695 F9999.99
    N332 Z0.3998 A-99096.922 F9999.99
    N333 A-99094.156 F9999.99
    N334 Z0.4008 A-99091.383 F9999.99
    N335 Z0.4017 A-99090. F9999.99
    N336 Z0.4002 A-99087.234 F9999.99
    N337 Z0.3997 A-99084.461 F9999.99
    N338 Z0.4003 A-99081.695 F9999.99
    N339 Z0.4007 A-99080.305 F9999.99
    N340 Z0.3989 A-99077.539 F9999.99
    N341 Z0.3979 A-99074.766 F9999.99
    N342 Z0.3963 A-99072. F9999.99
    N343 Z0.3958 A-99070.617 F9999.99
    N344 Z0.3918 A-99067.844 F9999.99
    N345 Z0.39 A-99066.461 F9999.99
    N346 Z0.3885 A-99065.078 F9999.99
    N347 Z0.3862 A-99062.305 F9999.99
    N348 Z0.3846 A-99059.539 F9999.99
    N349 Z0.382 A-99056.766 F9999.99
    N350 Z0.3807 A-99055.383 F9999.99
    N351 Z0.3786 A-99052.617 F9999.99
    N352 Z0.3772 A-99049.844 F9999.99
    N353 Z0.3768 A-99047.078 F9999.99
    N354 Z0.3771 A-99044.305 F9999.99
    N355 Z0.3747 A-99042.922 F9999.99
    N356 Z0.3725 A-99041.539 F9999.99
    N357 Z0.3705 A-99040.156 F9999.99
    N358 Z0.3689 A-99038.766 F9999.99
    N359 Z0.3675 A-99037.383 F9999.99
    N360 Z0.3663 A-99036. F9999.99
    N361 Z0.3646 A-99033.234 F9999.99
    N362 Z0.3635 A-99030.461 F9999.99
    N363 Z0.3634 A-99027.695 F9999.99
    N364 Z0.3643 A-99024.922 F9999.99
    N365 Z0.3641 A-99022.156 F9999.99
    N366 Z0.3623 A-99019.383 F9999.99
    N367 Z0.3608 A-99016.617 F9999.99
    N368 Z0.3604 A-99013.844 F9999.99
    N369 Z0.3609 A-99011.078 F9999.99
    N370 Z0.3623 A-99008.305 F9999.99
    N371 Z0.3644 A-99005.539 F9999.99
    N372 Z0.365 A-99002.766 F9999.99
    N373 Z0.3654 A-99000. F9999.99
    N374 G94 X-8.5242 Z0.3702 F229.1831
    N375 X-8.5234 Z0.3751
    N376 X-8.5227 Z0.38
    N377 X-8.5219 Z0.3849
    N378 X-8.5211 Z0.3898
    N379 X-8.5203 Z0.3946
    N380 X-8.5195 Z0.3995
    N381 X-8.5188 Z0.4044
    N382 X-8.518 Z0.4091
    N383 X-8.5172 Z0.4139
    N384 X-8.5164 Z0.4187
    N385 X-8.5156 Z0.4235
    N386 X-8.5148 Z0.428
    N387 X-8.5141 Z0.4323
    N388 X-8.5125 Z0.4409
    N389 X-8.5109 Z0.4494
    N390 X-8.5094 Z0.458
    N391 X-8.5078 Z0.4666
    N392 X-8.5063 Z0.4752
    N393 X-8.5047 Z0.4837
    N394 X-8.5031 Z0.4921
    N395 X-8.5016 Z0.5006
    N396 X-8.5 Z0.509
    N397 G93 Z0.5102 A-98997.234 F9293.5844
    N398 Z0.5128 A-98994.461 F9220.8909
    N399 Z0.5146 A-98993.078 F9999.99
    N400 Z0.5167 A-98991.695 F9999.99
    N401 Z0.5182 A-98988.922 F9149.6958
    N402 Z0.5206 A-98986.156 F9087.9846
    N403 Z0.5223 A-98984.766 F9999.99
    N404 Z0.5244 A-98983.383 F9999.99
    N405 Z0.5268 A-98982. F9999.99
    N406 Z0.5296 A-98980.617 F9999.99
    N407 Z0.5328 A-98979.234 F9999.99
    N408 Z0.5373 A-98976.461 F8732.6764
    N409 Z0.5398 A-98975.078 F9999.99
    N410 Z0.5426 A-98973.695 F9999.99
    N411 Z0.5458 A-98972.305 F9999.99
    N412 Z0.5494 A-98970.922 F9999.99
    N413 Z0.5533 A-98969.539 F9999.99
    N414 Z0.5577 A-98968.156 F9999.99
    N415 Z0.5625 A-98966.766 F9999.99
    N416 Z0.5664 A-98965.383 F9999.99
    N417 Z0.5704 A-98964. F9999.99
    N418 Z0.5749 A-98962.617 F9999.99
    N419 Z0.5793 A-98961.234 F9999.99
    N420 Z0.5839 A-98959.844 F9999.99
    N421 Z0.589 A-98958.461 F9999.99
    N422 Z0.5945 A-98957.078 F9999.99
    N423 Z0.6064 A-98954.305 F7311.1888
    N424 Z0.6117 A-98952.922 F9999.99
    N425 Z0.6175 A-98951.539 F9999.99
    N426 Z0.6237 A-98950.156 F9999.99
    N427 Z0.6305 A-98948.766 F9999.99
    N428 Z0.645 A-98946. F6732.4209
    N429 Z0.652 A-98944.617 F9999.99
    N430 Z0.659 A-98943.234 F9999.99
    N431 Z0.6651 A-98941.844 F9999.99
    N432 Z0.6718 A-98940.461 F9999.99
    N433 Z0.679 A-98939.078 F9999.99
    N434 Z0.6828 A-98938.383 F9999.99
    N435 Z0.6951 A-98936.305 F8238.7428
    N436 Z0.709 A-98933.539 F6248.4042
    N437 Z0.7129 A-98932.844 F9999.99
    N438 Z0.7169 A-98932.156 F9999.99
    N439 Z0.7304 A-98929.383 F6110.2786
    N440 Z0.7341 A-98928.695 F9999.99
    N441 Z0.737 A-98928. F9999.99
    N442 Z0.7473 A-98925.234 F6143.5057
    N443 Z0.7598 A-98922.461 F5952.1052
    N444 Z0.7633 A-98921.766 F9999.99
    N445 Z0.7706 A-98919. F6066.5935
    N446 Z0.7797 A-98916.234 F5942.9664
    N447 Z0.7819 A-98915.539 F9999.99
    N448 Z0.784 A-98912.766 F6047.2987
    N449 Z0.7879 A-98910. F6002.6088
    N450 Z0.784 A-98907.234 F6002.6416
    N451 Z0.7819 A-98904.461 F6047.272
    N452 Z0.7727 A-98901.695 F5926.8175
    N453 Z0.7651 A-98898.922 F6042.2788
    N454 Z0.7633 A-98898.234 F9999.99
    N455 Z0.7503 A-98895.461 F5905.7255
    N456 Z0.7394 A-98892.695 F6094.5042
    N457 Z0.737 A-98892. F9999.99
    N458 Z0.7341 A-98891.305 F9999.99
    N459 Z0.7203 A-98888.539 F6071.4825
    N460 Z0.7169 A-98887.844 F9999.99
    N461 Z0.7128 A-98887.156 F9999.99
    N462 Z0.6983 A-98884.383 F6184.2873
    N463 Z0.6951 A-98883.695 F9999.99
    N464 Z0.6828 A-98881.617 F8232.9484
    N465 Z0.6789 A-98880.922 F9999.99
    N466 Z0.6717 A-98879.539 F9999.99
    N467 Z0.6651 A-98878.156 F9999.99
    N468 Z0.659 A-98876.766 F9999.99
    N469 Z0.652 A-98875.383 F9999.99
    N470 Z0.6449 A-98874. F9999.99
    N471 Z0.6304 A-98871.234 F6727.7472
    N472 Z0.6236 A-98869.844 F9999.99
    N473 Z0.6173 A-98868.461 F9999.99
    N474 Z0.6116 A-98867.078 F9999.99
    N475 Z0.6064 A-98865.695 F9999.99
    N476 Z0.5943 A-98862.922 F7298.1513
    N477 Z0.5888 A-98861.539 F9999.99
    N478 Z0.5838 A-98860.156 F9999.99
    N479 Z0.5792 A-98858.766 F9999.99
    N480 Z0.5703 A-98856. F7855.0242
    N481 Z0.5663 A-98854.617 F9999.99
    N482 Z0.5624 A-98853.234 F9999.99
    N483 Z0.5575 A-98851.844 F9999.99
    N484 Z0.5531 A-98850.461 F9999.99
    N485 Z0.549 A-98849.078 F9999.99
    N486 Z0.5453 A-98847.695 F9999.99
    N487 Z0.5421 A-98846.305 F9999.99
    N488 Z0.5394 A-98844.922 F9999.99
    N489 Z0.5371 A-98843.539 F9999.99
    N490 Z0.5327 A-98840.766 F8743.5337
    N491 Z0.5294 A-98839.383 F9999.99
    N492 Z0.5265 A-98838. F9999.99
    N493 Z0.5241 A-98836.617 F9999.99
    N494 Z0.5221 A-98835.234 F9999.99
    N495 Z0.519 A-98832.461 F9044.7854
    N496 Z0.5174 A-98829.695 F9130.9947
    N497 Z0.5167 A-98828.305 F9999.99
    N498 Z0.5145 A-98826.922 F9999.99
    N499 Z0.5128 A-98825.539 F9999.99
    N500 Z0.5102 A-98822.766 F9222.3996
    N501 Z0.509 A-98820. F9294.4367
    N502 Z0.509 A-98817.234 F9316.6836
    N503 Z0.5096 A-98815.844 F9999.99
    N504 Z0.5078 A-98813.078 F9299.1803
    N505 Z0.5064 A-98810.305 F9336.4302
    N506 Z0.5063 A-98807.539 F9365.0462
    N507 Z0.5075 A-98804.766 F9343.2505
    N508 Z0.5101 A-98802. F9271.3637
    N509 Z0.5096 A-98799.234 F9299.8389
    N510 A-98796.461 F9306.1961
    N511 Z0.511 A-98793.695 F9279.0121
    N512 Z0.5138 A-98790.922 F9197.332
    N513 Z0.5157 A-98789.539 F9999.99
    N514 Z0.52 A-98786.766 F9025.6753
    N515 Z0.5212 A-98784. F9098.0578
    N516 Z0.5222 A-98781.234 F9082.589
    N517 Z0.5242 A-98778.461 F9034.6865
    N518 Z0.5258 A-98777.078 F9999.99
    N519 Z0.5276 A-98775.695 F9999.99
    N520 Z0.5299 A-98774.305 F9999.99
    N521 Z0.5324 A-98772.922 F9999.99
    N522 Z0.5354 A-98771.539 F9999.99
    N523 Z0.5377 A-98770.156 F9999.99
    N524 Z0.5383 A-98767.383 F8812.8071
    N525 Z0.54 A-98764.617 F8775.8875
    N526 Z0.5432 A-98761.844 F8692.8448
    N527 Z0.5453 A-98760.461 F9999.99
    N528 Z0.5475 A-98757.695 F8647.9
    N529 Z0.5507 A-98754.922 F8576.9518
    N530 Z0.5528 A-98753.539 F9999.99
    N531 Z0.5554 A-98752.156 F9999.99
    N532 Z0.5572 A-98750.766 F9999.99
    N533 Z0.5598 A-98748. F8451.3692
    N534 Z0.5617 A-98745.234 F8434.9729
    N535 Z0.5629 A-98743.844 F9999.99
    N536 Z0.5627 A-98741.078 F8425.802
    N537 Z0.5639 A-98738.305 F8410.3629
    N538 Z0.5651 A-98736.922 F9999.99
    N539 Z0.5643 A-98734.156 F8394.9866
    N540 Z0.565 A-98731.383 F8395.5291
    N541 Z0.5659 A-98730. F9999.99
    N542 Z0.5645 A-98727.234 F8380.2389
    N543 A-98724.461 F8399.889
    N544 Z0.5651 A-98723.078 F9999.99
    N545 Z0.5632 A-98720.305 F8386.8833
    N546 Z0.5627 A-98717.539 F8422.6684
    N547 Z0.5629 A-98716.156 F9999.99
    N548 Z0.5608 A-98713.383 F8414.8074
    N549 Z0.5584 A-98710.617 F8439.6611
    N550 Z0.5573 A-98709.234 F9999.99
    N551 Z0.553 A-98706.461 F8438.0723
    N552 Z0.551 A-98705.078 F9999.99
    N553 Z0.5479 A-98702.305 F8571.6369
    N554 Z0.5453 A-98699.539 F8636.4537
    N555 Z0.5434 A-98698.156 F9999.99
    N556 Z0.5404 A-98695.383 F8693.4805
    N557 Z0.5385 A-98692.617 F8767.5229
    N558 Z0.5377 A-98689.844 F8809.4686
    N559 Z0.5326 A-98687.078 F8696.1041
    N560 Z0.5302 A-98685.695 F9999.99
    N561 Z0.5281 A-98684.305 F9999.99
    N562 Z0.5247 A-98681.539 F8933.0196
    N563 Z0.5224 A-98678.766 F9020.237
    N564 Z0.5213 A-98676. F9077.4689
    N565 Z0.52 A-98673.234 F9097.5216
    N566 Z0.5159 A-98670.461 F9036.2438
    N567 Z0.5141 A-98669.078 F9999.99
    N568 Z0.5116 A-98666.305 F9198.8351
    N569 Z0.5101 A-98663.539 F9265.6651
    N570 Z0.5098 A-98660.766 F9299.5268
    N571 Z0.5101 A-98658. F9298.7797
    N572 Z0.5078 A-98655.234 F9276.1258
    N573 Z0.5065 A-98652.461 F9338.4143
    N574 A-98649.695 F9362.6504
    N575 Z0.5079 A-98646.922 F9336.4918
    N576 Z0.5096 A-98644.156 F9299.8326
    N577 Z0.5089 A-98641.383 F9309.2568
    N578 Z0.509 A-98640. F9999.99
    N579 G94 X-8.4984 Z0.517 F229.1831
    N580 X-8.4969 Z0.5249
    N581 X-8.4953 Z0.5328
    N582 X-8.4937 Z0.5407
    N583 X-8.4922 Z0.5486
    N584 X-8.4906 Z0.5566
    N585 X-8.4891 Z0.5645
    N586 X-8.4875 Z0.5724
    N587 X-8.4859 Z0.5803
    N588 X-8.4844 Z0.5882
    N589 X-8.4828 Z0.5956
    N590 X-8.4812 Z0.6028
    N591 X-8.4797 Z0.6098
    N592 X-8.4781 Z0.6169
    N593 X-8.4766 Z0.6239
    N594 X-8.475 Z0.631
    N595 G93 A-98637.234 F7516.0582
    N596 Z0.6325 A-98634.461 F7496.4563
    N597 Z0.6356 A-98631.695 F7441.641
    N598 Z0.6375 A-98630.305 F9999.99
    N599 Z0.6391 A-98627.539 F7420.1827
    N600 Z0.6423 A-98624.766 F7363.5851
    N601 Z0.6445 A-98623.383 F9999.99
    N602 Z0.647 A-98622. F9999.99
    N603 Z0.6523 A-98619.234 F7198.3404
    N604 Z0.6565 A-98616.461 F7183.8559
    N605 Z0.6592 A-98615.078 F9999.99
    N606 Z0.6624 A-98613.695 F9999.99
    N607 Z0.666 A-98612.305 F9999.99
    N608 Z0.6732 A-98609.539 F6911.5579
    N609 Z0.677 A-98608.156 F9999.99
    N610 Z0.6813 A-98606.766 F9999.99
    N611 Z0.686 A-98605.383 F9999.99
    N612 Z0.6913 A-98604. F9999.99
    N613 Z0.6967 A-98602.617 F9999.99
    N614 Z0.7013 A-98601.234 F9999.99
    N615 Z0.7058 A-98599.844 F9999.99
    N616 Z0.7109 A-98598.461 F9999.99
    N617 Z0.7227 A-98595.695 F6266.0954
    N618 Z0.7366 A-98592.922 F6046.9011
    N619 Z0.7492 A-98590.156 F6024.2264
    N620 Z0.7595 A-98588.078 F7833.208
    N621 Z0.7738 A-98585.305 F5772.805
    N622 Z0.7861 A-98583.234 F7434.8398
    N623 Z0.8006 A-98580.461 F5594.3611
    N624 Z0.8084 A-98579.078 F9999.99
    N625 Z0.8227 A-98576.305 F5464.9975
    N626 Z0.8397 A-98573.539 F5257.8714
    N627 Z0.8442 A-98572.844 F9999.99
    N628 Z0.8512 A-98571.461 F9999.99
    N629 Z0.8631 A-98568.695 F5318.6567
    N630 Z0.8775 A-98565.922 F5155.1211
    N631 Z0.8806 A-98565.234 F9999.99
    N632 Z0.8913 A-98562.461 F5194.8458
    N633 Z0.9009 A-98560.383 F6763.7764
    N634 Z0.9034 A-98559.695 F9999.99
    N635 Z0.9099 A-98556.922 F5174.2975
    N636 Z0.9151 A-98554.844 F6841.9938
    N637 Z0.9164 A-98552.078 F5176.115
    N638 Z0.9189 A-98550. F6873.0652
    N639 Z0.9159 A-98547.234 F5157.8639
    N640 Z0.9151 A-98545.156 F6905.5144
    N641 Z0.9084 A-98542.383 F5140.758
    N642 Z0.9034 A-98540.305 F6900.9481
    N643 Z0.9009 A-98539.617 F9999.99
    N644 Z0.8885 A-98536.844 F5094.0144
    N645 Z0.8806 A-98534.766 F6942.3091
    N646 Z0.8775 A-98534.078 F9999.99
    N647 Z0.8632 A-98531.305 F5158.5416
    N648 Z0.8512 A-98528.539 F5314.8095
    N649 Z0.8442 A-98527.156 F9999.99
    N650 Z0.8267 A-98524.383 F5207.9388
    N651 Z0.8118 A-98521.617 F5414.9413
    N652 Z0.8084 A-98520.922 F9999.99
    N653 Z0.793 A-98518.156 F5502.7922
    N654 Z0.7861 A-98516.766 F9999.99
    N655 Z0.7699 A-98514. F5598.4134
    N656 Z0.7563 A-98511.234 F5830.4795
    N657 Z0.7425 A-98508.461 F5912.9467
    N658 Z0.7366 A-98507.078 F9999.99
    N659 Z0.7224 A-98504.305 F6035.3459
    N660 Z0.7107 A-98501.539 F6270.0459
    N661 Z0.7057 A-98500.156 F9999.99
    N662 Z0.6966 A-98497.383 F6530.0196
    N663 Z0.6912 A-98496. F9999.99
    N664 Z0.686 A-98494.617 F9999.99
    N665 Z0.6812 A-98493.234 F9999.99
    N666 Z0.6769 A-98491.844 F9999.99
    N667 Z0.6689 A-98489.078 F6845.3679
    N668 Z0.6651 A-98487.695 F9999.99
    N669 Z0.6617 A-98486.305 F9999.99
    N670 Z0.6587 A-98484.922 F9999.99
    N671 Z0.6562 A-98483.539 F9999.99
    N672 Z0.6523 A-98480.766 F7195.2137
    N673 Z0.6476 A-98478. F7214.2317
    N674 Z0.6453 A-98476.617 F9999.99
    N675 Z0.6419 A-98473.844 F7325.4163
    N676 Z0.6384 A-98471.078 F7360.299
    N677 Z0.6357 A-98468.305 F7416.2818
    N678 Z0.6342 A-98465.539 F7460.2901
    N679 Z0.632 A-98462.766 F7472.0421
    N680 Z0.6313 A-98460. F7505.9477
    N681 Z0.6313 A-98458.617 F9999.99
    N682 Z0.6301 A-98455.844 F7512.6884
    N683 Z0.6303 A-98453.078 F7524.7162
    N684 Z0.631 A-98451.695 F9999.99
    N685 Z0.6308 A-98448.922 F7516.8324
    N686 Z0.6316 A-98446.156 F7510.0123
    N687 Z0.6334 A-98443.383 F7484.4125
    N688 Z0.6342 A-98440.617 F7479.6844
    N689 Z0.6365 A-98437.844 F7442.9649
    N690 Z0.6383 A-98436.461 F9999.99
    N691 Z0.6393 A-98433.695 F7419.7209
    N692 Z0.6415 A-98430.922 F7387.2183
    N693 Z0.6432 A-98429.539 F9999.99
    N694 Z0.6444 A-98426.766 F7361.159
    N695 Z0.6471 A-98424. F7316.8565
    N696 Z0.649 A-98422.617 F9999.99
    N697 Z0.6514 A-98421.234 F9999.99
    N698 Z0.6542 A-98419.844 F9999.99
    N699 Z0.6552 A-98417.078 F7239.6494
    N700 Z0.6572 A-98414.305 F7212.0632
    N701 Z0.6609 A-98411.539 F7147.4043
    N702 Z0.6661 A-98408.766 F7055.9797
    N703 Z0.6681 A-98407.383 F9999.99
    N704 Z0.6729 A-98404.617 F6996.0831
    N705 Z0.6754 A-98401.844 F7013.8618
    N706 Z0.677 A-98400.461 F9999.99
    N707 Z0.6787 A-98397.695 F6985.8875
    N708 Z0.6824 A-98394.922 F6925.2315
    N709 Z0.6847 A-98393.539 F9999.99
    N710 Z0.687 A-98390.766 F6897.8399
    N711 Z0.6888 A-98389.383 F9999.99
    N712 Z0.6929 A-98386.617 F6812.1185
    N713 Z0.6954 A-98383.844 F6814.1504
    N714 Z0.6988 A-98381.078 F6767.0686
    N715 Z0.699 A-98378.305 F6784.8793
    N716 Z0.701 A-98375.539 F6763.9609
    N717 Z0.7004 A-98372.766 F6767.207
    N718 Z0.7017 A-98370. F6759.9734
    N719 Z0.7005 A-98367.234 F6760.0173
    N720 Z0.701 A-98364.461 F6767.1736
    N721 Z0.6991 A-98361.695 F6764.1126
    N722 Z0.6988 A-98358.922 F6784.7162
    N723 Z0.6954 A-98356.156 F6767.6686
    N724 Z0.693 A-98353.383 F6813.9753
    N725 Z0.689 A-98350.617 F6814.3414
    N726 Z0.6858 A-98347.844 F6866.9079
    N727 Z0.6847 A-98346.461 F9999.99
    N728 Z0.6807 A-98343.695 F6894.8744
    N729 Z0.6778 A-98340.922 F6955.2703
    N730 Z0.677 A-98339.539 F9999.99
    N731 Z0.674 A-98336.766 F6990.8402
    N732 Z0.6729 A-98335.383 F9999.99
    N733 Z0.6683 A-98332.617 F7000.3023
    N734 Z0.6635 A-98329.844 F7045.533
    N735 Z0.6611 A-98328.461 F9999.99
    N736 Z0.6575 A-98325.695 F7147.0241
    N737 Z0.6554 A-98322.922 F7207.1806
    N738 Z0.6542 A-98320.156 F7237.7339
    N739 Z0.6515 A-98318.766 F9999.99
    N740 Z0.6491 A-98317.383 F9999.99
    N741 Z0.6456 A-98314.617 F7280.6571
    N742 Z0.6432 A-98311.844 F7336.0379
    N743 Z0.6401 A-98309.078 F7354.7222
    N744 Z0.6386 A-98306.305 F7409.1896
    N745 Z0.6382 A-98303.539 F7427.5686
    N746 Z0.6361 A-98302.156 F9999.99
    N747 Z0.6329 A-98299.383 F7435.3034
    N748 Z0.6314 A-98296.617 F7492.3799
    N749 A-98293.844 F7511.0232
    N750 Z0.6319 A-98292.461 F9999.99
    N751 Z0.6297 A-98289.695 F7498.6346
    N752 Z0.6287 A-98286.922 F7533.2119
    N753 Z0.6293 A-98284.156 F7537.9794
    N754 Z0.6313 A-98281.383 F7507.2928
    N755 Z0.631 A-98280. F9999.99
    N756 G94 X-8.4734 Z0.638 F229.1831
    N757 X-8.4719 Z0.6451
    N758 X-8.4703 Z0.6521
    N759 X-8.4688 Z0.6592
    N760 X-8.4672 Z0.6662
    N761 X-8.4656 Z0.6733
    N762 X-8.4641 Z0.6802
    N763 X-8.4625 Z0.6872
    N764 X-8.4609 Z0.6936
    N765 X-8.4594 Z0.7
    N766 X-8.4578 Z0.7064
    N767 X-8.4563 Z0.7128
    N768 X-8.4547 Z0.7192
    N769 X-8.4531 Z0.7256
    N770 X-8.4516 Z0.732
    N771 X-8.45 Z0.7384
    N772 G93 A-98277.234 F6422.8271
    N773 Z0.7404 A-98274.461 F6403.9151
    N774 Z0.7427 A-98272.383 F8492.9202
    N775 Z0.7434 A-98269.617 F6381.0465
    N776 Z0.7462 A-98266.844 F6347.1907
    N777 Z0.751 A-98264.078 F6280.9032
    N778 Z0.753 A-98262.695 F9999.99
    N779 Z0.7565 A-98259.922 F6254.6125
    N780 Z0.7613 A-98257.156 F6196.5222
    N781 Z0.768 A-98254.383 F6100.561
    N782 Z0.7737 A-98251.617 F6082.0822
    N783 Z0.7813 A-98248.844 F5977.5944
    N784 Z0.791 A-98246.078 F5846.3053
    N785 Z0.7937 A-98245.383 F9999.99
    N786 Z0.8026 A-98242.617 F5791.2324
    N787 Z0.813 A-98239.844 F5673.4174
    N788 Z0.8249 A-98237.078 F5546.4006
    N789 Z0.837 A-98234.305 F5461.7604
    N790 Z0.8517 A-98231.539 F5286.5453
    N791 Z0.8553 A-98230.844 F9999.99
    N792 Z0.8675 A-98228.078 F5283.0356
    N793 Z0.8822 A-98225.305 F5122.5588
    N794 Z0.8995 A-98222.539 F4937.2167
    N795 Z0.9035 A-98221.844 F9999.99
    N796 Z0.9168 A-98219.078 F4987.8545
    N797 Z0.9328 A-98216.305 F4828.7241
    N798 Z0.9412 A-98214.922 F9486.5348
    N799 Z0.9569 A-98212.156 F4728.8571
    N800 Z0.9714 A-98209.383 F4695.5518
    N801 Z0.9831 A-98206.617 F4711.2902
    N802 Z0.9972 A-98203.844 F4594.7966
    N803 Z1.0069 A-98201.078 F4639.1604
    N804 Z1.016 A-98199. F6068.9089
    N805 Z1.0216 A-98196.234 F4624.4263
    N806 Z1.025 A-98194.844 F9179.941
    N807 Z1.0261 A-98194.156 F9999.99
    N808 Z1.0276 A-98191.383 F4616.417
    N809 Z1.0292 A-98190. F9202.1752
    N810 Z1.0265 A-98187.234 F4607.1112
    N811 Z1.0261 A-98185.844 F9239.3872
    N812 Z1.0233 A-98184.461 F9194.668
    N813 Z1.0174 A-98181.695 F4615.3098
    N814 Z1.016 A-98181. F9999.99
    N815 Z1.0043 A-98178.234 F4566.0307
    N816 Z0.9972 A-98176.156 F6198.7705
    N817 Z0.9833 A-98173.383 F4599.8608
    N818 Z0.9714 A-98170.617 F4705.9983
    N819 Z0.9569 A-98167.844 F4695.3289
    N820 Z0.9412 A-98165.078 F4729.1981
    N821 Z0.9245 A-98162.305 F4765.8267
    N822 Z0.9099 A-98159.539 F4910.3045
    N823 Z0.9035 A-98158.156 F9999.99
    N824 Z0.8995 A-98157.461 F9999.99
    N825 Z0.8821 A-98154.695 F4933.736
    N826 Z0.8674 A-98151.922 F5123.3377
    N827 Z0.8553 A-98149.156 F5286.1274
    N828 Z0.8402 A-98146.383 F5249.4965
    N829 Z0.8272 A-98143.617 F5411.5071
    N830 Z0.8165 A-98140.844 F5572.4583
    N831 Z0.8046 A-98138.078 F5599.1777
    N832 Z0.7939 A-98135.305 F5715.449
    N833 Z0.7847 A-98132.539 F5842.3679
    N834 Z0.7777 A-98129.766 F5967.5269
    N835 Z0.7744 A-98128.383 F9999.99
    N836 Z0.7662 A-98125.617 F6011.089
    N837 Z0.76 A-98122.844 F6128.5417
    N838 Z0.7558 A-98120.078 F6215.7411
    N839 Z0.7529 A-98117.305 F6266.6667
    N840 Z0.7511 A-98115.922 F9999.99
    N841 Z0.7471 A-98113.156 F6291.1098
    N842 Z0.745 A-98110.383 F6346.1392
    N843 Z0.742 A-98107.617 F6355.7762
    N844 Z0.741 A-98104.844 F6393.2419
    N845 Z0.7397 A-98102.766 F8528.9504
    N846 Z0.7389 A-98100. F6412.693
    N847 Z0.7392 A-98098.617 F9999.99
    N848 Z0.7385 A-98095.844 F6417.0669
    N849 Z0.7391 A-98093.078 F6418.3235
    N850 Z0.7399 A-98091.695 F9999.99
    N851 Z0.7397 A-98088.922 F6410.0003
    N852 Z0.7414 A-98086.156 F6396.4219
    N853 Z0.7421 A-98084.766 F9999.99
    N854 Z0.743 A-98082. F6384.7736
    N855 Z0.7457 A-98079.234 F6352.7854
    N856 Z0.7472 A-98076.461 F6347.6177
    N857 Z0.75 A-98073.695 F6315.6198
    N858 Z0.7529 A-98071.617 F8370.8147
    N859 Z0.7542 A-98068.844 F6289.5706
    N860 Z0.7571 A-98066.078 F6254.9973
    N861 Z0.7592 A-98064.695 F9999.99
    N862 Z0.7613 A-98061.922 F6227.4251
    N863 Z0.7654 A-98059.156 F6175.533
    N864 Z0.7686 A-98057.078 F8190.8744
    N865 Z0.7714 A-98054.305 F6141.5861
    N866 Z0.7756 A-98051.539 F6093.0477
    N867 Z0.7778 A-98048.766 F6095.3732
    N868 Z0.7806 A-98046. F6068.8047
    N869 Z0.7855 A-98043.234 F6005.7391
    N870 Z0.7895 A-98041.156 F7954.0728
    N871 Z0.7946 A-98038.383 F5934.2404
    N872 Z0.7986 A-98035.617 F5920.8089
    N873 Z0.8012 A-98032.844 F5915.9096
    N874 Z0.8058 A-98030.078 F5861.5504
    N875 Z0.808 A-98027.305 F5867.4645
    N876 Z0.811 A-98024.539 F5840.6867
    N877 Z0.8122 A-98021.766 F5840.385
    N878 Z0.8145 A-98019.695 F7749.8789
    N879 Z0.8149 A-98016.922 F5820.5023
    N880 Z0.8166 A-98014.844 F7736.1618
    N881 Z0.8164 A-98012.078 F5807.9376
    N882 Z0.8174 A-98010. F7736.7349
    N883 Z0.8163 A-98007.234 F5803.174
    N884 Z0.8166 A-98005.156 F7745.1967
    N885 Z0.8147 A-98002.383 F5806.9969
    N886 Z0.8145 A-98000.305 F7760.1506
    N887 Z0.8118 A-97997.539 F5818.9041
    N888 Z0.811 A-97995.461 F7788.0722
    N889 Z0.808 A-97992.695 F5840.7515
    N890 Z0.8058 A-97989.922 F5867.2787
    N891 Z0.8013 A-97987.156 F5863.2017
    N892 Z0.7986 A-97984.383 F5914.1557
    N893 Z0.7946 A-97981.617 F5920.8072
    N894 Z0.7896 A-97978.844 F5935.8464
    N895 Z0.7842 A-97976.078 F5967.7063
    N896 Z0.7799 A-97973.305 F6024.3479
    N897 Z0.7773 A-97970.539 F6076.0068
    N898 Z0.7748 A-97967.766 F6097.4223
    N899 Z0.7707 A-97965. F6099.8442
    N900 Z0.7678 A-97962.234 F6145.8986
    N901 Z0.7636 A-97959.461 F6155.0974
    N902 Z0.7606 A-97956.695 F6201.9556
    N903 Z0.7571 A-97953.922 F6221.1296
    N904 Z0.7551 A-97951.156 F6261.9013
    N905 Z0.751 A-97948.383 F6259.4006
    N906 Z0.7477 A-97945.617 F6301.8827
    N907 Z0.7463 A-97942.844 F6343.4282
    N908 A-97941.461 F9999.99
    N909 Z0.7427 A-97938.695 F6338.9699
    N910 Z0.7405 A-97935.922 F6382.7797
    N911 Z0.7401 A-97933.156 F6405.6561
    N912 Z0.7405 A-97931.078 F8538.1144
    N913 Z0.738 A-97928.305 F6399.6517
    N914 Z0.7374 A-97925.539 F6427.6842
    N915 Z0.7387 A-97922.766 F6420.8341
    N916 Z0.7391 A-97921.383 F9999.99
    N917 Z0.7384 A-97920. F9999.99
    N918 G94 X-8.4484 Z0.7448 F229.1831
    N919 X-8.4469 Z0.7512
    N920 X-8.4453 Z0.7576
    N921 X-8.4438 Z0.764
    N922 X-8.4422 Z0.7704
    N923 X-8.4406 Z0.7768
    N924 X-8.4391 Z0.7829
    N925 X-8.4375 Z0.7886
    N926 X-8.4359 Z0.7943
    N927 X-8.4344 Z0.8001
    N928 X-8.4328 Z0.8058
    N929 X-8.4312 Z0.8115
    N930 X-8.4297 Z0.8172
    N931 X-8.4281 Z0.823
    N932 X-8.4266 Z0.8287
    N933 X-8.425 Z0.8344
    N934 G93 Z0.8349 A-97917.234 F5681.2988
    N935 Z0.8375 A-97914.461 F5659.1824
    N936 Z0.838 A-97911.695 F5660.2545
    N937 Z0.8404 A-97908.922 F5641.3259
    N938 Z0.8449 A-97906.156 F5593.7466
    N939 Z0.8478 A-97903.383 F5589.0485
    N940 Z0.8515 A-97900.617 F5559.0553
    N941 Z0.8573 A-97897.844 F5496.2959
    N942 Z0.8616 A-97895.078 F5487.7797
    N943 Z0.8685 A-97892.305 F5410.4934
    N944 Z0.8774 A-97889.539 F5314.5721
    N945 Z0.8856 A-97886.766 F5283.8569
    N946 Z0.8946 A-97884. F5215.3188
    N947 Z0.9029 A-97881.922 F6816.6654
    N948 Z0.9127 A-97879.156 F5098.502
    N949 Z0.9248 A-97876.383 F4980.032
    N950 Z0.9352 A-97874.305 F6495.4528
    N951 Z0.9475 A-97871.539 F4864.9252
    N952 Z0.9615 A-97868.766 F4753.0045
    N953 Z0.9725 A-97866.695 F6239.4581
    N954 Z0.9861 A-97863.922 F4653.1241
    N955 Z1.0022 A-97861.156 F4525.4629
    N956 Z1.0112 A-97859.766 F8826.3282
    N957 Z1.0183 A-97858.383 F8982.2099
    N958 Z1.0321 A-97855.617 F4455.2925
    N959 Z1.049 A-97852.844 F4322.1535
    N960 Z1.0639 A-97850.078 F4309.1668
    N961 Z1.0778 A-97847.305 F4277.164
    N962 Z1.0889 A-97844.539 F4281.2627
    N963 Z1.0987 A-97842.461 F5610.3361
    N964 Z1.108 A-97839.695 F4234.7076
    N965 Z1.1137 A-97838.305 F8351.9305
    N966 Z1.1183 A-97835.539 F4234.3582
    N967 Z1.1215 A-97834.156 F8407.9089
    N968 Z1.1228 A-97831.383 F4225.0351
    N969 Z1.1243 A-97830. F8427.7088
    N970 Z1.1219 A-97827.234 F4218.4182
    N971 Z1.1215 A-97825.844 F8454.0734
    N972 Z1.1157 A-97823.078 F4215.2027
    N973 Z1.1137 A-97821.695 F8484.3513
    N974 Z1.1031 A-97818.922 F4197.2442
    N975 Z1.0988 A-97817.539 F8502.3995
    N976 Z1.0861 A-97814.766 F4220.8134
    N977 Z1.0778 A-97812.695 F5717.0466
    N978 Z1.0639 A-97809.922 F4276.9431
    N979 Z1.049 A-97807.156 F4309.206
    N980 Z1.0323 A-97804.383 F4325.1623
    N981 Z1.0183 A-97801.617 F4452.4569
    N982 Z1.0112 A-97800.234 F8980.2392
    N983 Z0.9938 A-97797.461 F4451.0154
    N984 Z0.9792 A-97794.695 F4597.748
    N985 Z0.9691 A-97792.617 F6238.4875
    N986 Z0.954 A-97789.844 F4690.3352
    N987 Z0.9412 A-97787.078 F4821.1102
    N988 Z0.9351 A-97785.695 F9763.6352
    N989 Z0.9208 A-97782.922 F4866.5927
    N990 Z0.9087 A-97780.156 F5002.0071
    N991 Z0.8991 A-97777.383 F5125.0193
    N992 Z0.8931 A-97775.305 F6939.3796
    N993 Z0.8825 A-97772.539 F5185.3431
    N994 Z0.8731 A-97769.766 F5274.1621
    N995 Z0.8663 A-97767. F5382.0789
    N996 Z0.8628 A-97764.922 F7267.6629
    N997 Z0.8553 A-97762.156 F5432.4892
    N998 Z0.8503 A-97759.383 F5519.6524
    N999 Z0.8473 A-97756.617 F5572.0379
    N1000 Z0.8449 A-97753.844 F5595.5655
    N1001 Z0.8411 A-97751.078 F5601.0297
    N1002 Z0.8393 A-97748.305 F5638.7018
    N1003 Z0.8369 A-97745.539 F5648.2076
    N1004 Z0.8364 A-97742.766 F5667.6424
    N1005 Z0.8351 A-97740. F5671.0807
    N1006 Z0.8357 A-97737.234 F5676.1691
    N1007 Z0.8352 A-97734.461 F5676.0566
    N1008 Z0.8366 A-97731.695 F5670.2658
    N1009 Z0.8367 A-97728.922 F5668.1756
    N1010 Z0.8389 A-97726.156 F5652.7174
    N1011 Z0.8396 A-97723.383 F5650.0459
    N1012 Z0.8424 A-97720.617 F5625.6571
    N1013 Z0.8438 A-97717.844 F5621.6315
    N1014 Z0.8471 A-97715.078 F5590.7048
    N1015 Z0.849 A-97713. F7439.5033
    N1016 Z0.8523 A-97710.234 F5556.7807
    N1017 Z0.855 A-97708.156 F7381.7914
    N1018 Z0.8567 A-97705.383 F5536.3278
    N1019 Z0.8606 A-97702.617 F5499.4187
    N1020 Z0.8635 A-97700.539 F7304.2106
    N1021 Z0.8669 A-97697.766 F5463.2557
    N1022 Z0.8709 A-97695. F5433.6767
    N1023 Z0.8734 A-97692.922 F7224.7506
    N1024 Z0.8776 A-97690.156 F5390.3899
    N1025 Z0.8817 A-97687.383 F5366.0437
    N1026 Z0.8852 A-97685.305 F7113.7252
    N1027 Z0.8885 A-97683.234 F7092.3821
    N1028 Z0.8925 A-97680.461 F5302.365
    N1029 Z0.8975 A-97677.695 F5264.6146
    N1030 Z0.9005 A-97674.922 F5262.4031
    N1031 Z0.9054 A-97672.156 F5218.9724
    N1032 Z0.9084 A-97669.383 F5216.7954
    N1033 Z0.9111 A-97667.305 F6927.3595
    N1034 Z0.9133 A-97664.539 F5192.3002
    N1035 Z0.9153 A-97663.156 F9999.99
    N1036 Z0.9169 A-97660.383 F5173.372
    N1037 Z0.919 A-97658.305 F6875.4456
    N1038 Z0.9199 A-97655.539 F5156.522
    N1039 Z0.9211 A-97654.156 F9999.99
    N1040 Z0.9208 A-97651.383 F5149.3759
    N1041 Z0.9215 A-97650. F9999.99
    N1042 Z0.9206 A-97647.234 F5147.5628
    N1043 Z0.9211 A-97645.844 F9999.99
    N1044 Z0.9192 A-97643.078 F5149.472
    N1045 Z0.9184 A-97641. F6878.4459
    N1046 Z0.916 A-97638.234 F5162.5596
    N1047 Z0.9153 A-97636.844 F9999.99
    N1048 Z0.912 A-97634.078 F5176.3262
    N1049 Z0.9104 A-97632. F6929.389
    N1050 Z0.907 A-97629.234 F5203.672
    N1051 Z0.9043 A-97627.156 F6956.2558
    N1052 Z0.8996 A-97624.383 F5227.7582
    N1053 Z0.8975 A-97622.305 F7023.1819
    N1054 Z0.8926 A-97619.539 F5264.8444
    N1055 Z0.8885 A-97616.766 F5302.1196
    N1056 Z0.8842 A-97614. F5322.9272
    N1057 Z0.88 A-97611.234 F5349.8535
    N1058 Z0.8775 A-97609.156 F7175.4411
    N1059 Z0.8724 A-97606.383 F5381.6556
    N1060 Z0.8695 A-97603.617 F5431.4724
    N1061 Z0.8656 A-97600.844 F5443.3503
    N1062 Z0.8619 A-97598.078 F5468.4134
    N1063 Z0.858 A-97595.305 F5490.1265
    N1064 Z0.8553 A-97592.539 F5524.5868
    N1065 Z0.8528 A-97589.766 F5542.5411
    N1066 Z0.8513 A-97588.383 F9999.99
    N1067 Z0.8463 A-97585.617 F5545.1158
    N1068 Z0.8433 A-97582.844 F5599.1181
    N1069 Z0.8425 A-97580.078 F5624.9386
    N1070 Z0.8423 A-97579.383 F9999.99
    N1071 Z0.8386 A-97576.617 F5618.8189
    N1072 Z0.837 A-97573.844 F5655.7814
    N1073 Z0.8375 A-97571.078 F5663.7912
    N1074 Z0.835 A-97568.305 F5660.4227
    N1075 Z0.8342 A-97565.539 F5680.8843
    N1076 Z0.8356 A-97562.766 F5676.8155
    N1077 Z0.8344 A-97560. F5677.0318
    N1078 G94 X-8.4234 Z0.8402 F229.1831
    N1079 X-8.4219 Z0.8459
    N1080 X-8.4203 Z0.8517
    N1081 X-8.4187 Z0.8574
    N1082 X-8.4172 Z0.8631
    N1083 X-8.4156 Z0.8689
    N1084 X-8.4141 Z0.8746
    N1085 X-8.4125 Z0.8799
    N1086 X-8.4109 Z0.8849
    N1087 X-8.4094 Z0.89
    N1088 X-8.4078 Z0.8951
    N1089 X-8.4063 Z0.9002
    N1090 X-8.4047 Z0.9053
    N1091 X-8.4031 Z0.9104
    N1092 X-8.4016 Z0.9155
    N1093 X-8.4 Z0.9206
    N1094 G93 Z0.9217 A-97557.234 F5146.6038
    N1095 Z0.9237 A-97555.156 F6839.7126
    N1096 Z0.9243 A-97552.383 F5131.9327
    N1097 Z0.9274 A-97549.617 F5110.1224
    N1098 Z0.9305 A-97547.539 F6777.929
    N1099 Z0.9327 A-97544.766 F5084.5317
    N1100 Z0.9366 A-97542. F5054.5804
    N1101 Z0.9397 A-97540.617 F9999.99
    N1102 Z0.9436 A-97537.844 F5017.8485
    N1103 Z0.9502 A-97535.078 F4956.5451
    N1104 Z0.9565 A-97533. F6522.0654
    N1105 Z0.9639 A-97530.234 F4878.0861
    N1106 Z0.9718 A-97527.461 F4830.5887
    N1107 Z0.9791 A-97525.383 F6349.511
    N1108 Z0.9879 A-97522.617 F4741.1469
    N1109 Z0.9998 A-97519.844 F4631.4584
    N1110 Z1.0064 A-97518.461 F9122.4214
    N1111 Z1.0161 A-97515.695 F4600.973
    N1112 Z1.0287 A-97512.922 F4494.7701
    N1113 Z1.04 A-97510.844 F5848.3439
    N1114 Z1.0524 A-97508.078 F4402.4979
    N1115 Z1.0671 A-97505.305 F4301.605
    N1116 Z1.0817 A-97502.539 F4250.0864
    N1117 Z1.096 A-97499.766 F4201.9718
    N1118 Z1.113 A-97497. F4091.8702
    N1119 Z1.1199 A-97495.617 F8232.0979
    N1120 Z1.134 A-97492.844 F4073.7767
    N1121 Z1.1464 A-97490.766 F5312.5404
    N1122 Z1.1563 A-97488.695 F5342.2352
    N1123 Z1.1694 A-97485.922 F3971.3875
    N1124 Z1.1801 A-97483.156 F3967.4536
    N1125 Z1.1866 A-97481.766 F7819.9981
    N1126 Z1.1949 A-97479. F3941.5364
    N1127 Z1.1999 A-97477.617 F7799.1484
    N1128 Z1.2046 A-97474.844 F3931.5701
    N1129 Z1.2069 A-97473.461 F7844.8491
    N1130 Z1.2083 A-97470.695 F3925.765
    N1131 Z1.2091 A-97470. F9999.99
    N1132 Z1.207 A-97467.234 F3922.8985
    N1133 Z1.2062 A-97465.844 F7856.8856
    N1134 Z1.201 A-97463.078 F3924.624
    N1135 Z1.1999 A-97462.383 F9999.99
    N1136 Z1.1904 A-97459.617 F3915.2007
    N1137 Z1.1866 A-97458.234 F7904.058
    N1138 Z1.1745 A-97455.461 F3930.5845
    N1139 Z1.1694 A-97454.078 F7968.2631
    N1140 Z1.1563 A-97451.305 F3971.3047
    N1141 Z1.1464 A-97449.234 F5341.8358
    N1142 Z1.1304 A-97446.461 F3999.935
    N1143 Z1.1169 A-97443.695 F4095.9043
    N1144 Z1.1044 A-97441.617 F5436.551
    N1145 Z1.0885 A-97438.844 F4143.5264
    N1146 Z1.0779 A-97436.766 F5637.4829
    N1147 Z1.0673 A-97434.695 F5686.3389
    N1148 Z1.0533 A-97431.922 F4313.8285
    N1149 Z1.0461 A-97430.539 F8693.112
    N1150 Z1.0309 A-97427.766 F4369.4412
    N1151 Z1.0183 A-97425. F4486.427
    N1152 Z1.0085 A-97422.234 F4588.1648
    N1153 Z1.0064 A-97421.539 F9999.99
    N1154 Z0.9929 A-97418.766 F4567.9743
    N1155 Z0.9817 A-97416. F4676.4167
    N1156 Z0.9737 A-97413.234 F4782.6384
    N1157 Z0.9706 A-97411.844 F9673.7287
    N1158 Z0.9614 A-97409.078 F4815.3008
    N1159 Z0.9526 A-97406.305 F4868.4774
    N1160 Z0.9466 A-97403.539 F4951.3962
    N1161 Z0.9446 A-97402.156 F9992.475
    N1162 Z0.9378 A-97399.383 F4984.1598
    N1163 Z0.9333 A-97396.617 F5043.739
    N1164 Z0.9312 A-97393.844 F5081.345
    N1165 Z0.9298 A-97391.766 F6787.9958
    N1166 Z0.9263 A-97389. F5094.1355
    N1167 Z0.9251 A-97386.922 F6827.1538
    N1168 Z0.9228 A-97384.156 F5125.7363
    N1169 Z0.9226 A-97382.078 F6853.5833
    N1170 Z0.9213 A-97379.305 F5141.3531
    N1171 Z0.9218 A-97377.234 F6858.9978
    N1172 Z0.9213 A-97374.461 F5145.6353
    N1173 Z0.9225 A-97371.695 F5141.9491
    N1174 Z0.923 A-97368.922 F5138.924
    N1175 Z0.9248 A-97366.844 F6833.0502
    N1176 Z0.9257 A-97364.078 F5124.5826
    N1177 Z0.9284 A-97361.305 F5106.4203
    N1178 Z0.9303 A-97358.539 F5098.4293
    N1179 Z0.9338 A-97355.766 F5072.7399
    N1180 Z0.9367 A-97353. F5059.6778
    N1181 Z0.9402 A-97350.922 F6703.4438
    N1182 Z0.9422 A-97348.156 F5033.9546
    N1183 Z0.9461 A-97345.383 F5004.0556
    N1184 Z0.948 A-97344. F9980.9624
    N1185 Z0.9519 A-97341.234 F4973.9237
    N1186 Z0.956 A-97339.156 F6582.3036
    N1187 Z0.9575 A-97337.766 F9894.9545
    N1188 Z0.9608 A-97335. F4932.0641
    N1189 Z0.9664 A-97332.234 F4885.4222
    N1190 Z0.968 A-97331.539 F9999.99
    N1191 Z0.9706 A-97328.766 F4885.1269
    N1192 Z0.9756 A-97326. F4846.1206
    N1193 Z0.9795 A-97323.922 F6429.9138
    N1194 Z0.9838 A-97321.156 F4811.0893
    N1195 Z0.9869 A-97319.766 F9540.4506
    N1196 Z0.9903 A-97317. F4784.8985
    N1197 Z0.9942 A-97314.922 F6335.5375
    N1198 Z0.9983 A-97312.156 F4743.4411
    N1199 Z1.0018 A-97310.078 F6293.1478
    N1200 Z1.0045 A-97307.305 F4719.9699
    N1201 Z1.0068 A-97305.922 F9384.3264
    N1202 Z1.0092 A-97303.156 F4698.7917
    N1203 Z1.0113 A-97301.766 F9357.3913
    N1204 Z1.0131 A-97299. F4681.8731
    N1205 Z1.0144 A-97297.617 F9337.9798
    N1206 Z1.015 A-97294.844 F4673.4046
    N1207 Z1.0156 A-97293.461 F9342.9142
    N1208 Z1.0158 A-97290.695 F4669.1154
    N1209 A-97289.305 F9332.1382
    N1210 Z1.0156 A-97286.539 F4669.1029
    N1211 Z1.0144 A-97283.766 F4670.8978
    N1212 A-97282.383 F9354.1118
    N1213 Z1.012 A-97279.617 F4674.8315
    N1214 Z1.0113 A-97278.234 F9367.0311
    N1215 Z1.0078 A-97275.461 F4685.0653
    N1216 Z1.0068 A-97274.078 F9412.2579
    N1217 Z1.0029 A-97271.305 F4704.0462
    N1218 Z1.0018 A-97269.922 F9447.9074
    N1219 Z0.9971 A-97267.156 F4722.111
    N1220 Z0.9942 A-97265.078 F6331.4838
    N1221 Z0.9893 A-97262.305 F4756.6155
    N1222 Z0.9869 A-97260.234 F6385.781
    N1223 Z0.9814 A-97257.461 F4786.4386
    N1224 Z0.9774 A-97254.695 F4825.4464
    N1225 Z0.9722 A-97251.922 F4835.1651
    N1226 Z0.9684 A-97249.156 F4871.751
    N1227 Z0.9637 A-97246.383 F4883.8747
    N1228 Z0.9605 A-97244.305 F6544.2045
    N1229 Z0.9566 A-97241.539 F4929.6158
    N1230 Z0.9553 A-97240.156 F9906.2503
    N1231 Z0.95 A-97237.383 F4945.3154
    N1232 Z0.9462 A-97234.617 F4984.8395
    N1233 Z0.9427 A-97231.844 F5006.468
    N1234 Z0.9406 A-97229.766 F6702.6025
    N1235 Z0.9374 A-97227. F5037.5935
    N1236 Z0.9337 A-97224.922 F6718.3174
    N1237 Z0.9299 A-97222.156 F5070.7037
    N1238 Z0.9283 A-97219.383 F5101.2102
    N1239 Z0.9277 A-97218. F9999.99
    N1240 Z0.9242 A-97215.234 F5105.9474
    N1241 Z0.923 A-97212.461 F5132.4683
    N1242 Z0.9234 A-97210.383 F6849.5826
    N1243 Z0.9209 A-97207.617 F5134.6461
    N1244 Z0.9207 A-97204.844 F5150.2958
    N1245 Z0.9218 A-97202.766 F6858.422
    N1246 Z0.9206 A-97200. F5146.1957
    N1247 G94 X-8.3984 Z0.9256 F229.1831
    N1248 X-8.3969 Z0.9307
    N1249 X-8.3953 Z0.9358
    N1250 X-8.3938 Z0.9409
    N1251 X-8.3922 Z0.946
    N1252 X-8.3906 Z0.9511
    N1253 X-8.3891 Z0.9562
    N1254 X-8.3875 Z0.9613
    N1255 X-8.3859 Z0.9664
    N1256 X-8.3844 Z0.9715
    N1257 X-8.3828 Z0.9762
    N1258 X-8.3813 Z0.9807
    N1259 X-8.3797 Z0.9852
    N1260 X-8.3781 Z0.9897
    N1261 X-8.3766 Z0.9942
    N1262 X-8.375 Z0.9987
    N1263 G93 Z1.0007 A-97197.234 F4739.7614
    N1264 Z1.0018 A-97195.844 F9462.8786
    N1265 Z1.0032 A-97193.078 F4728.667
    N1266 Z1.0062 A-97190.305 F4711.2581
    N1267 Z1.0074 A-97188.922 F9406.9897
    N1268 Z1.0094 A-97186.156 F4698.9116
    N1269 Z1.0141 A-97183.383 F4665.7715
    N1270 Z1.0164 A-97182. F9299.4073
    N1271 Z1.0213 A-97179.234 F4632.113
    N1272 Z1.029 A-97176.461 F4570.7977
    N1273 Z1.0327 A-97175.078 F9099.0878
    N1274 Z1.0386 A-97172.305 F4548.1286
    N1275 Z1.0473 A-97169.539 F4479.8618
    N1276 Z1.0554 A-97166.766 F4455.2812
    N1277 Z1.0661 A-97164. F4375.1772
    N1278 Z1.0721 A-97162.617 F8646.7581
    N1279 Z1.0808 A-97159.844 F4344.4841
    N1280 Z1.0922 A-97157.078 F4265.1735
    N1281 Z1.1024 A-97155. F5582.3709
    N1282 Z1.1106 A-97152.922 F5597.5001
    N1283 Z1.1228 A-97150.156 F4142.3429
    N1284 Z1.1341 A-97148.078 F5398.7825
    N1285 Z1.1445 A-97146. F5384.3107
    N1286 Z1.1583 A-97143.234 F3997.5866
    N1287 Z1.1727 A-97140.461 F3942.684
    N1288 Z1.1869 A-97137.695 F3900.1467
    N1289 Z1.199 A-97135.617 F5105.877
    N1290 Z1.2062 A-97134.234 F7648.6361
    N1291 Z1.2194 A-97131.461 F3814.989
    N1292 Z1.2311 A-97129.383 F4989.3803
    N1293 Z1.2437 A-97126.617 F3750.8395
    N1294 Z1.2503 A-97125.234 F7430.2199
    N1295 Z1.2599 A-97122.461 F3731.367
    N1296 Z1.2659 A-97121.078 F7370.6445
    N1297 Z1.2734 A-97118.305 F3707.426
    N1298 Z1.2775 A-97116.922 F7370.694
    N1299 Z1.2825 A-97114.156 F3692.6935
    N1300 Z1.2839 A-97113.461 F9999.99
    N1301 Z1.2853 A-97110.695 F3690.5928
    N1302 Z1.2862 A-97110. F9999.99
    N1303 Z1.284 A-97107.234 F3688.016
    N1304 Z1.2839 A-97106.539 F9999.99
    N1305 Z1.2785 A-97103.766 F3687.4293
    N1306 Z1.2759 A-97102.383 F7401.5156
    N1307 Z1.2676 A-97099.617 F3695.3001
    N1308 Z1.2659 A-97098.922 F9999.99
    N1309 Z1.2549 A-97096.156 F3702.7363
    N1310 Z1.2503 A-97094.766 F7484.8824
    N1311 Z1.2375 A-97092. F3729.5225
    N1312 Z1.2312 A-97090.617 F7514.2258
    N1313 Z1.216 A-97087.844 F3754.1689
    N1314 Z1.2062 A-97085.766 F5097.1046
    N1315 Z1.195 A-97083.695 F5097.848
    N1316 Z1.1797 A-97080.922 F3859.6066
    N1317 Z1.1689 A-97078.844 F5220.1065
    N1318 Z1.1582 A-97076.766 F5266.8253
    N1319 Z1.1443 A-97074. F3996.3241
    N1320 Z1.1342 A-97071.922 F5390.7007
    N1321 Z1.1203 A-97069.156 F4077.5722
    N1322 Z1.1119 A-97067.078 F5544.4802
    N1323 Z1.0974 A-97064.305 F4143.6654
    N1324 Z1.0851 A-97061.539 F4231.334
    N1325 Z1.0761 A-97058.766 F4325.2171
    N1326 Z1.072 A-97057.383 F8723.6233
    N1327 Z1.0597 A-97054.617 F4327.4255
    N1328 Z1.0498 A-97051.844 F4413.3328
    N1329 Z1.0431 A-97049.078 F4493.3647
    N1330 Z1.039 A-97047.695 F8992.0399
    N1331 Z1.0314 A-97044.922 F4527.9513
    N1332 Z1.024 A-97042.156 F4564.8537
    N1333 Z1.0194 A-97039.383 F4621.3229
    N1334 Z1.0126 A-97036.617 F4623.8032
    N1335 Z1.0086 A-97033.844 F4677.2152
    N1336 Z1.0073 A-97031.078 F4703.044
    N1337 Z1.0064 A-97029.695 F9412.6223
    N1338 Z1.004 A-97026.922 F4712.1996
    N1339 Z1.0022 A-97024.844 F6296.2709
    N1340 Z1.0006 A-97022.078 F4733.0184
    N1341 Z1. A-97020.695 F9473.8158
    N1342 Z0.9991 A-97017.922 F4743.5516
    N1343 Z0.999 A-97015.844 F6329.7315
    N1344 Z0.9993 A-97013.078 F4746.2307
    N1345 Z0.9998 A-97011. F6326.2733
    N1346 Z1.001 A-97008.234 F4738.9888
    N1347 Z1.002 A-97006.156 F6309.5946
    N1348 Z1.0041 A-97003.383 F4723.1841
    N1349 Z1.0054 A-97002. F9425.2366
    N1350 Z1.0078 A-96999.234 F4705.2363
    N1351 Z1.0107 A-96997.156 F6246.9259
    N1352 Z1.014 A-96994.383 F4673.515
    N1353 Z1.0169 A-96992.305 F6206.8312
    N1354 Z1.0194 A-96989.539 F4651.6594
    N1355 Z1.024 A-96986.766 F4621.9353
    N1356 Z1.0281 A-96984. F4606.2495
    N1357 Z1.0342 A-96981.234 F4565.416
    N1358 Z1.0373 A-96978.461 F4569.7622
    N1359 Z1.043 A-96975.695 F4530.0528
    N1360 Z1.0469 A-96973.617 F6018.0558
    N1361 Z1.0509 A-96970.844 F4506.8858
    N1362 Z1.0556 A-96968.766 F5959.8011
    N1363 Z1.059 A-96966.695 F5958.3633
    N1364 Z1.0632 A-96963.922 F4454.1555
    N1365 Z1.0694 A-96961.156 F4415.8604
    N1366 Z1.0738 A-96958.383 F4409.5053
    N1367 Z1.0767 A-96957. F8761.7454
    N1368 Z1.0808 A-96954.234 F4382.5055
    N1369 Z1.0851 A-96952.156 F5805.3946
    N1370 Z1.089 A-96949.383 F4350.3864
    N1371 Z1.0911 A-96948. F8672.9828
    N1372 Z1.0946 A-96945.234 F4329.7834
    N1373 Z1.0959 A-96944.539 F9999.99
    N1374 Z1.0986 A-96941.766 F4316.389
    N1375 Z1.1003 A-96940.383 F8603.55
    N1376 Z1.1021 A-96937.617 F4303.8196
    N1377 Z1.1027 A-96935.539 F5735.5592
    N1378 Z1.104 A-96933.461 F5728.7442
    N1379 A-96930.695 F4295.6733
    N1380 Z1.1044 A-96930. F9999.99
    N1381 Z1.1037 A-96927.234 F4294.9793
    N1382 Z1.1035 A-96925.844 F8593.32
    N1383 Z1.1027 A-96923.078 F4298.703
    N1384 Z1.1007 A-96920.305 F4301.6511
    N1385 Z1.0997 A-96918.922 F8614.4894
    N1386 Z1.0963 A-96916.156 F4310.3636
    N1387 Z1.0959 A-96915.461 F9999.99
    N1388 Z1.0917 A-96912.695 F4322.0378
    N1389 Z1.0903 A-96911.305 F8683.7546
    N1390 Z1.0861 A-96908.539 F4344.1681
    N1391 Z1.0822 A-96906.461 F5803.3799
    N1392 Z1.0775 A-96903.695 F4373.756
    N1393 Z1.0753 A-96902.305 F8780.6415
    N1394 Z1.07 A-96899.539 F4397.8961
    N1395 Z1.0668 A-96897.461 F5898.1894
    N1396 Z1.0612 A-96894.695 F4431.3794
    N1397 Z1.0582 A-96892.617 F5947.8675
    N1398 Z1.054 A-96890.539 F5949.2537
    N1399 Z1.0492 A-96887.766 F4489.6668
    N1400 Z1.0476 A-96886.383 F9032.5688
    N1401 Z1.0413 A-96883.617 F4505.7418
    N1402 Z1.0369 A-96880.844 F4546.0264
    N1403 Z1.0327 A-96878.078 F4567.0215
    N1404 Z1.0272 A-96875.305 F4576.6009
    N1405 Z1.023 A-96872.539 F4609.5241
    N1406 Z1.0191 A-96869.766 F4629.9945
    N1407 Z1.0158 A-96867. F4650.8021
    N1408 Z1.0137 A-96864.922 F6220.1648
    N1409 Z1.0085 A-96862.156 F4663.5086
    N1410 Z1.0057 A-96859.383 F4701.1486
    N1411 Z1.005 A-96857.305 F6286.6791
    N1412 Z1.0015 A-96854.539 F4714.2979
    N1413 Z1.0003 A-96851.766 F4736.7496
    N1414 Z1.0007 A-96850.383 F9482.8097
    N1415 Z0.9984 A-96847.617 F4739.1736
    N1416 A-96844.844 F4749.8314
    N1417 Z0.9993 A-96843.461 F9483.0853
    N1418 Z0.9985 A-96840.695 F4746.7584
    N1419 Z0.9987 A-96840. F9999.99
    N1420 G94 X-8.3734 Z1.0031 F229.1831
    N1421 X-8.3719 Z1.0076
    N1422 X-8.3703 Z1.0121
    N1423 X-8.3687 Z1.0166
    N1424 X-8.3672 Z1.0211
    N1425 X-8.3656 Z1.0256
    N1426 X-8.3641 Z1.0301
    N1427 X-8.3625 Z1.0346
    N1428 X-8.3609 Z1.0391
    N1429 X-8.3594 Z1.0436
    N1430 X-8.3578 Z1.0481
    N1431 X-8.3562 Z1.0526
    N1432 X-8.3547 Z1.0571
    N1433 X-8.3531 Z1.0616
    N1434 X-8.3516 Z1.0661
    N1435 X-8.35 Z1.0706
    N1436 G93 Z1.0727 A-96837.234 F4421.7295
    N1437 Z1.0728 A-96834.461 F4420.7455
    N1438 Z1.0755 A-96831.695 F4409.0607
    N1439 Z1.0771 A-96830.305 F8793.5637
    N1440 Z1.0796 A-96827.539 F4392.5586
    N1441 Z1.0851 A-96824.766 F4357.545
    N1442 Z1.09 A-96822. F4341.7697
    N1443 Z1.0965 A-96819.234 F4304.8781
    N1444 Z1.0998 A-96817.844 F8573.0757
    N1445 Z1.1052 A-96815.078 F4278.8317
    N1446 Z1.114 A-96812.305 F4217.6443
    N1447 Z1.1201 A-96810.234 F5596.076
    N1448 Z1.13 A-96807.461 F4148.0518
    N1449 Z1.1374 A-96805.383 F5489.4843
    N1450 Z1.1458 A-96802.617 F4106.9086
    N1451 Z1.1577 A-96799.844 F4025.455
    N1452 Z1.1641 A-96798.461 F7964.2524
    N1453 Z1.1737 A-96795.695 F3999.988
    N1454 Z1.1864 A-96792.922 F3922.795
    N1455 Z1.193 A-96791.539 F7767.5313
    N1456 Z1.2049 A-96788.766 F3874.3399
    N1457 Z1.2186 A-96786. F3811.9475
    N1458 Z1.2294 A-96783.922 F5019.9785
    N1459 Z1.2428 A-96781.156 F3742.8943
    N1460 Z1.2567 A-96778.383 F3697.372
    N1461 Z1.2706 A-96775.617 F3659.8337
    N1462 Z1.2823 A-96773.539 F4801.8748
    N1463 Z1.2886 A-96772.156 F7232.4738
    N1464 Z1.3018 A-96769.383 F3582.1909
    N1465 Z1.3088 A-96768. F7094.1143
    N1466 Z1.3215 A-96765.234 F3535.4265
    N1467 Z1.3246 A-96764.539 F9999.99
    N1468 Z1.3336 A-96761.766 F3534.0678
    N1469 Z1.3387 A-96760.383 F7006.2097
    N1470 Z1.3457 A-96757.617 F3513.1539
    N1471 Z1.3479 A-96756.922 F9999.99
    N1472 Z1.3521 A-96754.156 F3505.8757
    N1473 Z1.3536 A-96753.461 F9999.99
    N1474 Z1.3548 A-96750.695 F3501.3213
    N1475 Z1.3556 A-96750. F9999.99
    N1476 Z1.3537 A-96747.234 F3499.3365
    N1477 Z1.3536 A-96746.539 F9999.99
    N1478 Z1.3487 A-96743.766 F3499.87
    N1479 Z1.3479 A-96743.078 F9999.99
    N1480 Z1.3402 A-96740.305 F3503.6634
    N1481 Z1.3387 A-96739.617 F9999.99
    N1482 Z1.3289 A-96736.844 F3515.005
    N1483 Z1.3247 A-96735.461 F7082.0287
    N1484 Z1.3118 A-96732.695 F3526.2698
    N1485 Z1.3057 A-96731.305 F7118.4235
    N1486 Z1.2917 A-96728.539 F3564.1577
    N1487 Z1.2858 A-96727.156 F7228.3158
    N1488 Z1.2786 A-96725.766 F7206.4689
    N1489 Z1.2635 A-96723. F3623.8431
    N1490 Z1.2531 A-96720.922 F4898.0165
    N1491 Z1.2394 A-96718.156 F3709.503
    N1492 Z1.2291 A-96716.078 F4993.0928
    N1493 Z1.2152 A-96713.305 F3776.9594
    N1494 Z1.2024 A-96710.539 F3832.8001
    N1495 Z1.1932 A-96708.461 F5163.0557
    N1496 Z1.1802 A-96705.695 F3897.2987
    N1497 Z1.1694 A-96702.922 F3966.0444
    N1498 Z1.1596 A-96700.844 F5289.809
    N1499 Z1.1475 A-96698.078 F4017.2987
    N1500 Z1.139 A-96695.305 F4100.4486
    N1501 Z1.1374 A-96694.617 F9999.99
    N1502 Z1.1269 A-96691.844 F4114.6772
    N1503 Z1.1168 A-96689.078 F4154.7677
    N1504 Z1.11 A-96686.305 F4226.5451
    N1505 Z1.1012 A-96683.539 F4232.0925
    N1506 Z1.0954 A-96680.766 F4291.6835
    N1507 Z1.0907 A-96678. F4321.6006
    N1508 Z1.0837 A-96675.234 F4324.3661
    N1509 Z1.0789 A-96672.461 F4366.9578
    N1510 Z1.077 A-96669.695 F4396.6841
    N1511 Z1.075 A-96667.617 F5868.7468
    N1512 Z1.0736 A-96664.844 F4412.8741
    N1513 Z1.072 A-96662.078 F4418.382
    N1514 Z1.0721 A-96660.695 F8842.092
    N1515 Z1.0705 A-96657.922 F4424.3679
    N1516 Z1.0702 A-96655.844 F5907.9566
    N1517 Z1.0701 A-96653.078 F4431.3941
    N1518 Z1.0704 A-96651. F5908.5887
    N1519 Z1.0717 A-96648.234 F4426.4189
    N1520 Z1.073 A-96645.461 F4421.0752
    N1521 Z1.0756 A-96642.695 F4408.4196
    N1522 Z1.0784 A-96639.922 F4397.2429
    N1523 Z1.0802 A-96638.539 F8761.5077
    N1524 Z1.0823 A-96635.766 F4382.3737
    N1525 Z1.0854 A-96633.695 F5817.1374
    N1526 Z1.0886 A-96630.922 F4354.2561
    N1527 Z1.0926 A-96628.844 F5768.7073
    N1528 Z1.0973 A-96626.078 F4314.5361
    N1529 Z1.1025 A-96624. F5699.5591
    N1530 Z1.1062 A-96621.234 F4284.0952
    N1531 Z1.1124 A-96618.461 F4246.794
    N1532 Z1.1184 A-96615.695 F4225.8242
    N1533 Z1.1238 A-96612.922 F4209.1928
    N1534 Z1.128 A-96610.844 F5585.0827
    N1535 Z1.1325 A-96608.766 F5561.101
    N1536 Z1.1383 A-96606. F4153.3355
    N1537 Z1.1428 A-96603.922 F5512.9122
    N1538 Z1.1473 A-96601.156 F4127.6468
    N1539 Z1.1524 A-96599.078 F5457.319
    N1540 Z1.1561 A-96597. F5455.4839
    N1541 Z1.1604 A-96594.922 F5431.9208
    N1542 Z1.1652 A-96592.156 F4063.3179
    N1543 Z1.1686 A-96590.766 F8070.5925
    N1544 Z1.1724 A-96588. F4042.465
    N1545 Z1.1746 A-96586.617 F8056.6898
    N1546 Z1.1785 A-96583.844 F4020.9617
    N1547 Z1.1817 A-96581.078 F4012.5996
    N1548 Z1.1835 A-96579.695 F8002.9586
    N1549 Z1.1854 A-96576.922 F4001.4996
    N1550 Z1.1863 A-96574.156 F3998.5358
    N1551 Z1.1868 A-96572.766 F7991.5549
    N1552 Z1.1874 A-96570. F3994.6151
    N1553 Z1.1868 A-96567.234 F3994.6154
    N1554 Z1.1863 A-96565.844 F7991.5528
    N1555 Z1.1854 A-96563.078 F3998.5428
    N1556 Z1.1835 A-96560.305 F4001.5105
    N1557 Z1.18 A-96557.539 F4005.4526
    N1558 Z1.1785 A-96556.156 F8031.3751
    N1559 Z1.1746 A-96553.383 F4020.9799
    N1560 Z1.1702 A-96550.617 F4032.6913
    N1561 Z1.1686 A-96549.234 F8097.0809
    N1562 Z1.1624 A-96546.461 F4045.041
    N1563 Z1.1604 A-96545.078 F8143.8631
    N1564 Z1.1547 A-96542.305 F4076.0304
    N1565 Z1.1508 A-96540.234 F5461.2474
    N1566 Z1.1455 A-96537.461 F4111.7385
    N1567 Z1.143 A-96536.078 F8251.5606
    N1568 Z1.1369 A-96533.305 F4135.1514
    N1569 Z1.1316 A-96530.539 F4161.8332
    N1570 Z1.1255 A-96527.766 F4175.5628
    N1571 Z1.1199 A-96525. F4201.7993
    N1572 Z1.1172 A-96523.617 F8441.5267
    N1573 Z1.1106 A-96520.844 F4225.0876
    N1574 Z1.1055 A-96518.078 F4260.7473
    N1575 Z1.1009 A-96515.305 F4282.8867
    N1576 Z1.0949 A-96512.539 F4292.2407
    N1577 Z1.0913 A-96510.461 F5760.6977
    N1578 Z1.0872 A-96507.695 F4340.1512
    N1579 Z1.0834 A-96504.922 F4358.6098
    N1580 Z1.0822 A-96503.539 F8748.2154
    N1581 Z1.078 A-96500.766 F4376.6989
    N1582 Z1.0759 A-96498. F4400.0117
    N1583 Z1.0755 A-96496.617 F8815.5948
    N1584 Z1.0721 A-96493.844 F4407.1899
    N1585 Z1.0713 A-96491.078 F4424.5038
    N1586 Z1.0712 A-96489.695 F8852.7003
    N1587 Z1.0695 A-96486.922 F4427.9724
    N1588 Z1.0704 A-96484.156 F4431.6153
    N1589 Z1.0705 A-96482.766 F8859.9297
    N1590 Z1.0706 A-96480. F4429.8293
    N1591 G94 X-8.3469 Z1.0788 F229.1831
    N1592 X-8.3438 Z1.087
    N1593 X-8.3406 Z1.0951
    N1594 X-8.3375 Z1.1033
    N1595 X-8.3344 Z1.1115
    N1596 X-8.3313 Z1.1196
    N1597 X-8.3281 Z1.1273
    N1598 X-8.325 Z1.135
    N1599 G93 Z1.1373 A-96477.922 F5555.6436
    N1600 Z1.1385 A-96475.156 F4166.7206
    N1601 Z1.1417 A-96472.383 F4152.4455
    N1602 Z1.1431 A-96471. F8294.272
    N1603 Z1.1466 A-96468.234 F4134.3455
    N1604 Z1.151 A-96466.156 F5471.5299
    N1605 Z1.1544 A-96463.383 F4106.4278
    N1606 Z1.1605 A-96460.617 F4072.7109
    N1607 Z1.1637 A-96459.234 F8108.633
    N1608 Z1.1707 A-96456.461 F4032.5438
    N1609 Z1.1804 A-96453.695 F3976.9361
    N1610 Z1.184 A-96452.305 F7956.0818
    N1611 Z1.192 A-96449.539 F3953.9611
    N1612 Z1.1974 A-96448.156 F7801.2307
    N1613 Z1.2063 A-96445.383 F3900.0958
    N1614 Z1.2185 A-96442.617 F3829.7939
    N1615 Z1.2231 A-96441.234 F7675.954
    N1616 Z1.2327 A-96438.461 F3812.2319
    N1617 Z1.2461 A-96435.695 F3734.4306
    N1618 Z1.2539 A-96433.617 F4984.3117
    N1619 Z1.2653 A-96430.844 F3700.0473
    N1620 Z1.276 A-96428.766 F4848.2023
    N1621 Z1.2847 A-96426.695 F4853.9573
    N1622 Z1.2979 A-96423.922 F3593.7601
    N1623 Z1.3087 A-96421.844 F4727.1813
    N1624 Z1.3215 A-96419.078 F3535.3164
    N1625 Z1.3352 A-96416.305 F3491.1431
    N1626 Z1.3485 A-96413.539 F3462.7681
    N1627 Z1.3564 A-96412.156 F6813.5414
    N1628 Z1.3624 A-96410.766 F6862.9981
    N1629 Z1.375 A-96408. F3403.6834
    N1630 Z1.3807 A-96406.617 F6785.017
    N1631 Z1.393 A-96403.844 F3363.2454
    N1632 Z1.4023 A-96401.078 F3361.2128
    N1633 Z1.4066 A-96399.695 F6700.6445
    N1634 Z1.4131 A-96396.922 F3348.2724
    N1635 Z1.4159 A-96394.844 F4462.5795
    N1636 Z1.4185 A-96393.461 F6675.8993
    N1637 Z1.4197 A-96390.695 F3341.2229
    N1638 Z1.4204 A-96390. F9999.99
    N1639 Z1.4188 A-96387.234 F3339.5808
    N1640 Z1.4185 A-96386.539 F9999.99
    N1641 Z1.4144 A-96383.766 F3341.949
    N1642 Z1.4113 A-96382.383 F6687.8099
    N1643 Z1.4048 A-96379.617 F3353.02
    N1644 Z1.3955 A-96376.844 F3355.1529
    N1645 Z1.393 A-96376.156 F9999.99
    N1646 Z1.3808 A-96373.383 F3364.154
    N1647 Z1.3751 A-96372. F6781.6476
    N1648 Z1.3625 A-96369.234 F3403.6205
    N1649 Z1.3564 A-96367.844 F6860.9254
    N1650 Z1.3416 A-96365.078 F3427.2804
    N1651 Z1.3318 A-96363. F4637.2892
    N1652 Z1.3214 A-96360.922 F4657.6213
    N1653 Z1.3087 A-96358.156 F3536.9928
    N1654 Z1.2943 A-96355.383 F3551.6757
    N1655 Z1.2825 A-96352.617 F3616.3912
    N1656 Z1.2691 A-96349.844 F3632.3858
    N1657 Z1.2601 A-96347.766 F4904.5051
    N1658 Z1.2491 A-96345. F3719.3432
    N1659 Z1.2394 A-96342.922 F4968.6472
    N1660 Z1.2287 A-96340.156 F3782.4025
    N1661 Z1.2171 A-96337.383 F3805.4674
    N1662 Z1.2056 A-96334.617 F3842.415
    N1663 Z1.1974 A-96331.844 F3908.2281
    N1664 Z1.1869 A-96329.078 F3912.6395
    N1665 Z1.1813 A-96327. F5296.8661
    N1666 Z1.1736 A-96324.234 F3990.8342
    N1667 Z1.1643 A-96321.461 F4003.0907
    N1668 Z1.1578 A-96318.695 F4057.2817
    N1669 Z1.1541 A-96315.922 F4093.8021
    N1670 Z1.1483 A-96313.156 F4096.7823
    N1671 Z1.1438 A-96310.383 F4124.5262
    N1672 Z1.1417 A-96308.305 F5525.132
    N1673 Z1.1382 A-96305.539 F4151.4594
    N1674 Z1.1366 A-96303.461 F5553.9865
    N1675 Z1.1351 A-96300.695 F4173.4213
    N1676 Z1.1338 A-96297.922 F4179.1413
    N1677 Z1.1339 A-96295.844 F5577.0608
    N1678 Z1.1338 A-96293.078 F4182.4293
    N1679 Z1.1342 A-96291. F5576.4289
    N1680 Z1.1355 A-96288.234 F4177.6349
    N1681 Z1.1365 A-96285.461 F4173.8758
    N1682 Z1.1383 A-96283.383 F5552.5123
    N1683 Z1.1404 A-96280.617 F4159.1209
    N1684 Z1.1427 A-96278.539 F5529.694
    N1685 Z1.1463 A-96275.766 F4135.0827
    N1686 Z1.1483 A-96274.383 F8248.0393
    N1687 Z1.1528 A-96271.617 F4108.2072
    N1688 Z1.1569 A-96269.539 F5447.9561
    N1689 Z1.1625 A-96266.766 F4069.3071
    N1690 Z1.1662 A-96264.695 F5408.3616
    N1691 Z1.1719 A-96261.922 F4035.8646
    N1692 Z1.1773 A-96259.844 F5341.7268
    N1693 Z1.1823 A-96257.766 F5324.1138
    N1694 Z1.1889 A-96255. F3973.2799
    N1695 Z1.1956 A-96252.234 F3951.0044
    N1696 Z1.1992 A-96250.844 F7855.282
    N1697 Z1.2042 A-96248.766 F5227.7822
    N1698 Z1.2111 A-96246. F3900.0666
    N1699 Z1.2173 A-96243.234 F3884.4243
    N1700 Z1.2225 A-96241.156 F5147.8484
    N1701 Z1.2275 A-96238.383 F3857.1786
    N1702 Z1.2325 A-96236.305 F5107.8974
    N1703 Z1.2386 A-96233.539 F3818.6921
    N1704 Z1.244 A-96230.766 F3804.9324
    N1705 Z1.2475 A-96229.383 F7561.1033
    N1706 Z1.2517 A-96226.617 F3786.0415
    N1707 Z1.2538 A-96225.234 F7552.1158
    N1708 Z1.2581 A-96222.461 F3766.3977
    N1709 Z1.2614 A-96219.695 F3758.9414
    N1710 Z1.2637 A-96216.922 F3753.4119
    N1711 Z1.2645 A-96216.234 F9999.99
    N1712 Z1.2654 A-96213.461 F3748.637
    N1713 Z1.2657 A-96210.695 F3747.2469
    N1714 Z1.2661 A-96210. F9999.99
    N1715 Z1.2656 A-96207.234 F3746.2659
    N1716 Z1.2645 A-96204.461 F3748.1729
    N1717 Z1.2645 A-96203.766 F9999.99
    N1718 Z1.2621 A-96201. F3750.9614
    N1719 Z1.2586 A-96198.234 F3756.6015
    N1720 Z1.2569 A-96196.844 F7531.3643
    N1721 Z1.2531 A-96194.078 F3771.3237
    N1722 Z1.2483 A-96191.305 F3779.715
    N1723 Z1.2475 A-96190.617 F9999.99
    N1724 Z1.2411 A-96187.844 F3789.6005
    N1725 Z1.237 A-96185.766 F5082.3999
    N1726 Z1.2315 A-96183. F3825.9139
    N1727 Z1.2252 A-96180.234 F3839.7266
    N1728 Z1.2228 A-96178.844 F7718.9586
    N1729 Z1.2156 A-96176.078 F3860.9207
    N1730 Z1.212 A-96174. F5192.273
    N1731 Z1.204 A-96171.234 F3889.4538
    N1732 Z1.1983 A-96168.461 F3928.9797
    N1733 Z1.1904 A-96165.695 F3934.3089
    N1734 Z1.184 A-96162.922 F3969.5687
    N1735 Z1.1795 A-96160.844 F5321.9731
    N1736 Z1.1721 A-96158.078 F3999.7532
    N1737 Z1.1677 A-96156. F5374.647
    N1738 Z1.163 A-96153.234 F4055.1011
    N1739 Z1.1571 A-96150.461 F4065.6879
    N1740 Z1.1517 A-96147.695 F4089.1463
    N1741 Z1.1473 A-96144.922 F4112.7926
    N1742 Z1.1436 A-96142.156 F4131.0321
    N1743 Z1.1401 A-96139.383 F4145.0761
    N1744 Z1.1388 A-96136.617 F4160.6372
    N1745 Z1.1365 A-96134.539 F5548.4025
    N1746 Z1.1349 A-96131.766 F4173.8217
    N1747 Z1.1351 A-96129.695 F5571.4808
    N1748 Z1.1334 A-96126.922 F4179.0487
    N1749 Z1.1345 A-96124.156 F4181.0851
    N1750 Z1.1343 A-96121.383 F4180.3362
    N1751 Z1.135 A-96120. F8356.1097
    N1752 G94 X-8.3219 Z1.1426 F229.1831
    N1753 X-8.3188 Z1.1502
    N1754 X-8.3156 Z1.1579
    N1755 X-8.3125 Z1.1656
    N1756 X-8.3094 Z1.173
    N1757 X-8.3062 Z1.1801
    N1758 X-8.3031 Z1.1873
    N1759 X-8.3 Z1.1944
    N1760 G93 Z1.1965 A-96117.922 F5282.2826
    N1761 Z1.1985 A-96115.156 F3957.8166
    N1762 Z1.2025 A-96112.383 F3940.8499
    N1763 Z1.2055 A-96109.617 F3933.72
    N1764 Z1.2112 A-96106.844 F3905.6206
    N1765 Z1.2161 A-96104.078 F3894.0827
    N1766 Z1.2232 A-96101.305 F3860.2787
    N1767 Z1.23 A-96098.539 F3840.9252
    N1768 Z1.2378 A-96095.766 F3811.3512
    N1769 Z1.2449 A-96093. F3793.8613
    N1770 Z1.2557 A-96090.234 F3733.0973
    N1771 Z1.2654 A-96087.461 F3715.052
    N1772 Z1.2756 A-96084.695 F3682.5094
    N1773 Z1.2851 A-96081.922 F3660.9693
    N1774 Z1.2983 A-96079.156 F3592.5224
    N1775 Z1.303 A-96077.766 F7211.7369
    N1776 Z1.3133 A-96075. F3578.4761
    N1777 Z1.3271 A-96072.234 F3510.8816
    N1778 Z1.3372 A-96069.461 F3516.4045
    N1779 Z1.3503 A-96066.695 F3459.3614
    N1780 Z1.3575 A-96065.305 F6838.7409
    N1781 Z1.369 A-96062.539 F3427.4328
    N1782 Z1.3794 A-96060.461 F4503.6885
    N1783 Z1.3922 A-96057.695 F3361.349
    N1784 Z1.4024 A-96055.617 F4436.7071
    N1785 Z1.4144 A-96052.844 F3315.9269
    N1786 Z1.4254 A-96050.766 F4353.4356
    N1787 Z1.4374 A-96048. F3264.796
    N1788 Z1.4435 A-96046.617 F6485.2443
    N1789 Z1.4537 A-96043.844 F3239.5091
    N1790 Z1.4568 A-96043.156 F9999.99
    N1791 Z1.4655 A-96040.383 F3221.7497
    N1792 Z1.4682 A-96039.695 F9999.99
    N1793 Z1.4748 A-96036.922 F3208.8855
    N1794 Z1.4765 A-96036.234 F9999.99
    N1795 Z1.48 A-96033.461 F3204.3852
    N1796 Z1.4804 A-96032.422 F8538.2685
    N1797 Z1.4819 A-96030. F3658.3421
    N1798 Z1.4805 A-96027.234 F3201.1159
    N1799 Z1.4794 A-96026.195 F8535.4752
    N1800 Z1.4759 A-96023.422 F3205.5987
    N1801 Z1.4697 A-96021. F3661.7006
    N1802 Z1.4669 A-96019.961 F8569.2837
    N1803 Z1.4588 A-96017.539 F3673.4276
    N1804 Z1.4568 A-96016.844 F9999.99
    N1805 Z1.4458 A-96014.078 F3227.7645
    N1806 Z1.4406 A-96012.695 F6497.1945
    N1807 Z1.4284 A-96009.922 F3256.0717
    N1808 Z1.4254 A-96009.234 F9999.99
    N1809 Z1.4114 A-96006.461 F3275.5102
    N1810 Z1.4024 A-96004.383 F4424.3498
    N1811 Z1.392 A-96002.305 F4433.3807
    N1812 Z1.3796 A-95999.539 F3365.5692
    N1813 Z1.3658 A-95996.766 F3382.2709
    N1814 Z1.3576 A-95994.695 F4580.5813
    N1815 Z1.3439 A-95991.922 F3436.6812
    N1816 Z1.3357 A-95989.844 F4651.6081
    N1817 Z1.3267 A-95987.766 F4668.5275
    N1818 Z1.3143 A-95985. F3525.9299
    N1819 Z1.3033 A-95982.234 F3569.3116
    N1820 Z1.2984 A-95980.844 F7207.6847
    N1821 Z1.286 A-95978.078 F3600.177
    N1822 Z1.2836 A-95977.383 F9999.99
    N1823 Z1.2713 A-95974.617 F3641.0305
    N1824 Z1.2625 A-95971.844 F3705.4567
    N1825 Z1.2557 A-95969.766 F4968.1312
    N1826 Z1.2442 A-95967. F3726.9742
    N1827 Z1.2364 A-95964.234 F3791.1295
    N1828 Z1.2326 A-95962.156 F5102.9789
    N1829 Z1.2235 A-95959.383 F3817.4209
    N1830 Z1.2172 A-95956.617 F3863.7701
    N1831 Z1.2142 A-95954.539 F5188.0555
    N1832 Z1.2072 A-95951.766 F3889.3277
    N1833 Z1.2032 A-95949. F3925.5872
    N1834 Z1.2017 A-95946.922 F5255.8909
    N1835 Z1.1985 A-95944.156 F3945.4312
    N1836 Z1.1963 A-95942.078 F5274.8242
    N1837 Z1.1948 A-95939.305 F3965.1778
    N1838 Z1.1936 A-95936.539 F3970.3669
    N1839 Z1.1931 A-95934.461 F5297.2201
    N1840 Z1.1935 A-95931.695 F3974.0964
    N1841 Z1.1941 A-95928.922 F3972.284
    N1842 Z1.1947 A-95927.539 F7938.6287
    N1843 Z1.1964 A-95924.766 F3964.993
    N1844 Z1.1983 A-95922. F3958.4818
    N1845 Z1.2009 A-95919.922 F5262.3225
    N1846 Z1.204 A-95917.156 F3938.0264
    N1847 Z1.2072 A-95915.078 F5229.8123
    N1848 Z1.2122 A-95912.305 F3905.8131
    N1849 Z1.2153 A-95910.234 F5196.4145
    N1850 Z1.2209 A-95907.461 F3875.2255
    N1851 Z1.2268 A-95904.695 F3855.7486
    N1852 Z1.2348 A-95901.922 F3818.6931
    N1853 Z1.2411 A-95899.156 F3809.5988
    N1854 Z1.247 A-95897.078 F5039.8026
    N1855 Z1.2552 A-95894.305 F3755.9179
    N1856 Z1.2629 A-95891.539 F3737.2153
    N1857 Z1.2709 A-95888.766 F3711.4016
    N1858 Z1.2789 A-95886. F3689.1335
    N1859 Z1.2863 A-95883.234 F3671.0158
    N1860 Z1.2933 A-95880.461 F3654.0077
    N1861 Z1.2978 A-95879.078 F7244.6785
    N1862 Z1.3032 A-95876.305 F3632.9783
    N1863 Z1.3082 A-95874.234 F4815.1945
    N1864 Z1.315 A-95871.461 F3595.0576
    N1865 Z1.3211 A-95868.695 F3581.3046
    N1866 Z1.3238 A-95867.305 F7149.2134
    N1867 Z1.3277 A-95865.234 F4753.4544
    N1868 Z1.3317 A-95862.461 F3559.353
    N1869 Z1.3335 A-95861.078 F7105.7651
    N1870 Z1.3364 A-95859. F4728.6398
    N1871 Z1.3388 A-95856.234 F3542.9096
    N1872 Z1.3403 A-95853.461 F3539.3235
    N1873 Z1.3405 A-95852.078 F7072.6901
    N1874 Z1.3411 A-95850. F4715.9194
    N1875 Z1.3407 A-95847.234 F3536.5919
    N1876 Z1.3393 A-95844.461 F3538.2296
    N1877 Z1.3369 A-95841.695 F3541.5277
    N1878 Z1.3352 A-95840.305 F7089.3957
    N1879 Z1.333 A-95838.234 F4733.6917
    N1880 Z1.3286 A-95835.461 F3555.3797
    N1881 Z1.3261 A-95834.078 F7126.9486
    N1882 Z1.3227 A-95832. F4761.4451
    N1883 Z1.3162 A-95829.234 F3575.207
    N1884 Z1.3134 A-95827.844 F7186.2441
    N1885 Z1.3071 A-95825.078 F3601.6422
    N1886 Z1.3003 A-95822.305 F3616.4643
    N1887 Z1.2978 A-95820.922 F7277.752
    N1888 Z1.2898 A-95818.156 F3635.3487
    N1889 Z1.285 A-95816.078 F4885.3783
    N1890 Z1.2767 A-95813.305 F3669.2482
    N1891 Z1.2716 A-95811.234 F4933.4341
    N1892 Z1.2628 A-95808.461 F3703.9127
    N1893 Z1.2578 A-95806.383 F4988.6165
    N1894 Z1.2489 A-95803.617 F3743.6507
    N1895 Z1.2414 A-95800.844 F3778.7952
    N1896 Z1.2371 A-95798.766 F5078.6365
    N1897 Z1.2289 A-95796. F3810.3935
    N1898 Z1.2222 A-95793.234 F3844.8171
    N1899 Z1.2167 A-95790.461 F3871.8472
    N1900 Z1.2123 A-95787.695 F3893.8564
    N1901 Z1.2072 A-95784.922 F3905.2376
    N1902 Z1.2027 A-95782.156 F3923.8077
    N1903 Z1.1986 A-95779.383 F3939.7695
    N1904 Z1.197 A-95776.617 F3957.7548
    N1905 Z1.1962 A-95775.234 F7922.2471
    N1906 Z1.1937 A-95772.461 F3964.8068
    N1907 Z1.1939 A-95769.695 F3972.4466
    N1908 Z1.1923 A-95766.922 F3973.3885
    N1909 Z1.1937 A-95764.156 F3973.9462
    N1910 Z1.1935 A-95761.383 F3973.1426
    N1911 Z1.1944 A-95760. F7939.1696
    N1912 G94 X-8.2969 Z1.2016 F229.1831
    N1913 X-8.2937 Z1.2087
    N1914 X-8.2906 Z1.2159
    N1915 X-8.2875 Z1.2227
    N1916 X-8.2844 Z1.2294
    N1917 X-8.2813 Z1.2361
    N1918 X-8.2781 Z1.2428
    N1919 X-8.275 Z1.2494
    N1920 G93 Z1.251 A-95758.617 F7574.9983
    N1921 Z1.2531 A-95755.844 F3785.3887
    N1922 Z1.2577 A-95753.078 F3766.6989
    N1923 Z1.261 A-95750.305 F3760.1112
    N1924 Z1.2657 A-95748.234 F4979.4891
    N1925 Z1.271 A-95745.461 F3724.9223
    N1926 Z1.2781 A-95742.695 F3696.196
    N1927 Z1.2849 A-95739.922 F3678.3019
    N1928 Z1.2919 A-95737.844 F4853.9853
    N1929 Z1.2996 A-95735.078 F3632.5647
    N1930 Z1.3098 A-95732.305 F3587.8197
    N1931 Z1.3176 A-95729.539 F3583.3288
    N1932 Z1.3291 A-95726.766 F3526.231
    N1933 Z1.3401 A-95724. F3503.3175
    N1934 Z1.351 A-95721.234 F3475.6273
    N1935 Z1.3612 A-95718.461 F3455.9564
    N1936 Z1.3745 A-95715.695 F3397.9927
    N1937 Z1.3844 A-95712.922 F3401.0028
    N1938 Z1.3974 A-95710.156 F3346.9834
    N1939 Z1.4013 A-95709.461 F9999.99
    N1940 Z1.4114 A-95706.695 F3335.5618
    N1941 Z1.4245 A-95703.922 F3285.107
    N1942 Z1.4338 A-95701.844 F4352.8941
    N1943 Z1.4466 A-95699.078 F3239.1393
    N1944 Z1.45 A-95698.383 F9999.99
    N1945 Z1.4618 A-95695.617 F3212.3472
    N1946 Z1.4707 A-95693.883 F5074.0009
    N1947 Z1.4819 A-95691.117 F3173.2945
    N1948 Z1.4885 A-95689.734 F6279.9165
    N1949 Z1.5003 A-95686.961 F3132.038
    N1950 Z1.5053 A-95685.922 F8274.1535
    N1951 Z1.5147 A-95683.156 F3114.6142
    N1952 Z1.518 A-95682.117 F8284.6501
    N1953 Z1.5264 A-95679.344 F3095.1754
    N1954 Z1.5322 A-95676.578 F3091.4674
    N1955 Z1.5339 A-95675.539 F8231.062
    N1956 Z1.5375 A-95673.117 F3523.9865
    N1957 Z1.5386 A-95670.344 F3082.9999
    N1958 A-95669.656 F9999.99
    N1959 Z1.5375 A-95666.883 F3082.9808
    N1960 Z1.5337 A-95664.117 F3084.1938
    N1961 Z1.5283 A-95661.695 F3528.0384
    N1962 Z1.5264 A-95660.656 F8258.5157
    N1963 Z1.5181 A-95657.883 F3095.4912
    N1964 Z1.5148 A-95656.844 F8284.4699
    N1965 Z1.5053 A-95654.078 F3114.0735
    N1966 Z1.4927 A-95651.305 F3116.9844
    N1967 Z1.4854 A-95649.578 F5027.0145
    N1968 Z1.4732 A-95646.805 F3160.3937
    N1969 Z1.4691 A-95645.766 F8501.6287
    N1970 Z1.4552 A-95643. F3182.1138
    N1971 Z1.4466 A-95640.922 F4299.8312
    N1972 Z1.4333 A-95638.156 F3235.3787
    N1973 Z1.4251 A-95636.078 F4369.1064
    N1974 Z1.4119 A-95633.305 F3282.6123
    N1975 Z1.4013 A-95630.539 F3331.4039
    N1976 Z1.3881 A-95627.766 F3336.4301
    N1977 Z1.3795 A-95625.695 F4504.2177
    N1978 Z1.3716 A-95623.617 F4540.3946
    N1979 Z1.3588 A-95620.844 F3410.0201
    N1980 Z1.351 A-95618.766 F4608.6156
    N1981 Z1.3408 A-95616. F3480.4691
    N1982 Z1.3345 A-95614.617 F6960.7759
    N1983 Z1.3217 A-95611.844 F3501.8123
    N1984 Z1.313 A-95609.078 F3566.9383
    N1985 Z1.3098 A-95607.695 F7194.3857
    N1986 Z1.2989 A-95604.922 F3582.5972
    N1987 Z1.2909 A-95602.156 F3632.8508
    N1988 Z1.2879 A-95600.766 F7321.2746
    N1989 Z1.2784 A-95598. F3653.3528
    N1990 Z1.2723 A-95595.234 F3700.2912
    N1991 Z1.27 A-95593.844 F7439.3517
    N1992 Z1.2628 A-95591.078 F3719.4962
    N1993 Z1.2586 A-95588.305 F3752.4801
    N1994 Z1.2568 A-95586.234 F5022.8622
    N1995 Z1.253 A-95583.461 F3771.7491
    N1996 Z1.2502 A-95580.695 F3784.79
    N1997 Z1.249 A-95578.617 F5058.6714
    N1998 Z1.2481 A-95575.844 F3797.8217
    N1999 Z1.2473 A-95573.078 F3800.4155
    N2000 A-95571. F5069.8571
    N2001 Z1.2483 A-95568.234 F3799.9021
    N2002 Z1.2496 A-95565.461 F3796.1787
    N2003 Z1.2512 A-95563.383 F5052.8995
    N2004 Z1.2543 A-95560.617 F3780.4492
    N2005 Z1.2574 A-95557.844 F3771.3611
    N2006 Z1.2605 A-95555.766 F5010.319
    N2007 Z1.2658 A-95553. F3740.3524
    N2008 Z1.271 A-95550.234 F3725.467
    N2009 Z1.2759 A-95548.156 F4938.4231
    N2010 Z1.2827 A-95545.383 F3684.8605
    N2011 Z1.2876 A-95543.305 F4892.7317
    N2012 Z1.295 A-95540.539 F3647.0124
    N2013 Z1.3017 A-95538.461 F4820.4827
    N2014 Z1.3064 A-95537.078 F7191.9332
    N2015 Z1.315 A-95534.305 F3585.7031
    N2016 Z1.324 A-95531.539 F3558.7242
    N2017 Z1.3288 A-95530.156 F7072.4381
    N2018 Z1.3353 A-95528.078 F4703.0026
    N2019 Z1.3424 A-95526. F4673.2029
    N2020 Z1.351 A-95523.234 F3491.2894
    N2021 Z1.3557 A-95521.844 F6936.078
    N2022 Z1.361 A-95519.766 F4627.1209
    N2023 Z1.3674 A-95517.695 F4597.2299
    N2024 Z1.3749 A-95514.922 F3436.4301
    N2025 Z1.3799 A-95512.844 F4568.6056
    N2026 Z1.3854 A-95510.766 F4544.8748
    N2027 Z1.3917 A-95508. F3400.2054
    N2028 Z1.3937 A-95507.305 F9999.99
    N2029 Z1.3992 A-95504.539 F3384.9678
    N2030 Z1.4034 A-95501.766 F3377.4931
    N2031 Z1.4052 A-95500.383 F6741.9148
    N2032 Z1.4081 A-95498.305 F4488.2891
    N2033 Z1.4106 A-95495.539 F3362.6542
    N2034 Z1.412 A-95492.766 F3359.4592
    N2035 Z1.4125 A-95490. F3357.8837
    N2036 Z1.412 A-95487.234 F3357.8837
    N2037 Z1.4106 A-95484.461 F3359.4592
    N2038 Z1.4081 A-95481.695 F3362.6535
    N2039 Z1.4046 A-95478.922 F3367.6352
    N2040 Z1.4002 A-95476.156 F3374.6241
    N2041 Z1.3963 A-95474.078 F4508.5254
    N2042 Z1.3937 A-95472.695 F6776.7486
    N2043 Z1.3869 A-95469.922 F3393.7309
    N2044 Z1.382 A-95467.844 F4545.4628
    N2045 Z1.3767 A-95465.766 F4559.2049
    N2046 Z1.3698 A-95463. F3434.8745
    N2047 Z1.3656 A-95461.617 F6875.7223
    N2048 Z1.3579 A-95458.844 F3459.0292
    N2049 Z1.3511 A-95456.766 F4624.2122
    N2050 Z1.3428 A-95454. F3492.9346
    N2051 Z1.333 A-95451.234 F3504.4829
    N2052 Z1.3272 A-95449.156 F4719.4412
    N2053 Z1.3169 A-95446.383 F3541.7947
    N2054 Z1.3088 A-95443.617 F3582.712
    N2055 Z1.3042 A-95442.234 F7181.4484
    N2056 Z1.2952 A-95439.461 F3611.6551
    N2057 Z1.2878 A-95436.695 F3646.7102
    N2058 Z1.281 A-95433.922 F3669.9335
    N2059 Z1.2734 A-95431.156 F3685.7649
    N2060 Z1.2672 A-95428.383 F3714.2596
    N2061 Z1.2622 A-95425.617 F3736.8146
    N2062 Z1.2591 A-95423.539 F5005.0095
    N2063 Z1.2556 A-95420.766 F3765.4445
    N2064 Z1.2518 A-95418. F3775.3226
    N2065 Z1.2503 A-95415.234 F3789.6267
    N2066 Z1.2476 A-95412.461 F3793.0377
    N2067 Z1.2477 A-95409.695 F3800.9321
    N2068 Z1.2466 A-95406.922 F3801.7661
    N2069 Z1.2481 A-95404.156 F3800.7224
    N2070 Z1.2482 A-95401.383 F3799.4227
    N2071 Z1.2494 A-95400. F7587.9009
    N2072 G94 X-8.2719 Z1.2561 F229.1831
    N2073 X-8.2688 Z1.2628
    N2074 X-8.2656 Z1.2694
    N2075 X-8.2625 Z1.2756
    N2076 X-8.2594 Z1.2818
    N2077 X-8.2563 Z1.2881
    N2078 X-8.2531 Z1.2943
    N2079 X-8.25 Z1.3005
    N2080 G93 Z1.3016 A-95399.305 F9999.99
    N2081 Z1.3037 A-95396.539 F3638.6319
    N2082 Z1.3084 A-95393.766 F3620.6734
    N2083 Z1.3124 A-95391. F3611.9558
    N2084 Z1.3171 A-95388.922 F4785.1486
    N2085 Z1.3229 A-95386.156 F3577.7756
    N2086 Z1.3289 A-95384.078 F4731.7494
    N2087 Z1.3356 A-95381.305 F3540.5363
    N2088 Z1.3431 A-95379.234 F4666.6039
    N2089 Z1.3508 A-95376.461 F3496.2667
    N2090 Z1.3617 A-95373.695 F3448.9296
    N2091 Z1.3706 A-95370.922 F3440.4043
    N2092 Z1.3798 A-95368.844 F4521.9672
    N2093 Z1.3883 A-95366.078 F3399.1196
    N2094 Z1.4006 A-95363.305 F3345.5565
    N2095 Z1.4122 A-95360.539 F3323.4701
    N2096 Z1.4236 A-95357.766 F3299.1466
    N2097 Z1.4347 A-95355. F3276.4585
    N2098 Z1.4417 A-95353.617 F6464.2949
    N2099 Z1.4501 A-95351.539 F4318.4742
    N2100 Z1.4613 A-95348.766 F3217.1896
    N2101 Z1.468 A-95347.383 F6361.2973
    N2102 Z1.4768 A-95345.305 F4236.6116
    N2103 Z1.4883 A-95342.539 F3158.3572
    N2104 Z1.5005 A-95339.766 F3128.9222
    N2105 Z1.5118 A-95337.344 F3543.3226
    N2106 Z1.523 A-95334.578 F3089.2429
    N2107 Z1.5311 A-95332.844 F4895.3663
    N78104 Z1.6239 A8949.462 F5838.6335
    N78105 Z1.624 A8952.23 F2920.172
    N78106 Z1.6241 A8955. F2919.9766
    N78107 Z1.624 A8957.77 F2919.9904
    N78108 Z1.6239 A8960.538 F2920.1928
    N78109 Z1.6238 A8963.308 F2920.3733
    N78110 Z1.6237 A8964.692 F5842.4738
    N78111 Z1.624 A8967.115 F3337.4644
    N78112 Z1.6241 A8969.885 F2920.0636
    N78113 A8972.654 F2919.9392
    N78114 A8975.423 F2919.9231
    N78115 A8978.192 F2919.9793
    N78116 Z1.624 A8980.962 F2920.0542
    N78117 A8983.73 F2920.1163
    N78118 A8986.5 F2920.1429
    N78119 A8989.27 F2920.1107
    N78120 A8992.038 F2920.0439
    N78121 Z1.6241 A8994.808 F2919.9594
    N78122 A8997.577 F2919.9394
    N78123 A9000. F3336.7139
    N78124 G94 X-1.0187 F229.1831
    N78125 X-1.0125
    N78126 X-1.0063
    N78127 X-1.
    N78128 G93 Z1.624 A9002.77 F2919.9746
    N78129 Z1.6239 A9005.538 F2920.159
    N78130 Z1.6241 A9007.962 F3336.9477
    N78131 Z1.624 A9010.73 F2920.0658
    N78132 A9013.5 F2920.1421
    N78133 A9016.27 F2920.1653
    N78134 A9019.038 F2920.1593
    N78135 A9021.808 F2920.1207
    N78136 Z1.6241 A9024.577 F2920.019
    N78137 A9027.346 F2919.9283
    N78138 A9030.115 F2919.9361
    N78139 Z1.624 A9032.885 F2920.0797
    N78140 Z1.6239 A9035.654 F2920.2879
    N78141 Z1.6236 A9037.73 F3894.0403
    N78142 Z1.6239 A9039.462 F4673.4823
    N78143 Z1.624 A9042.23 F2920.1737
    N78144 Z1.6241 A9045. F2919.9735
    N78145 Z1.624 A9047.77 F2919.9719
    N78146 Z1.6239 A9050.538 F2920.1593
    N78147 Z1.6238 A9053.308 F2920.3602
    N78148 Z1.6237 A9054.692 F5838.8613
    N78149 Z1.624 A9057.115 F3337.6624
    N78150 Z1.6241 A9059.885 F2920.0802
    N78151 A9062.654 F2919.9175
    N78152 A9065.423 F2919.9322
    N78153 Z1.624 A9068.192 F2920.0348
    N78154 A9070.962 F2920.1155
    N78155 A9073.73 F2920.1432
    N78156 Z1.624 A9076.5 F2920.159
    N78157 Z1.624 A9079.27 F2920.1263
    N78158 A9082.038 F2920.0348
    N78159 Z1.6241 A9084.808 F2919.9411
    N78160 A9087.577 F2919.9308
    N78161 Z1.624 A9090.346 F2920.0642
    N78162 A9092.77 F3337.3829
    N78163 A9095.538 F2920.1365
    N78164 Z1.6241 A9097.962 F3337.3811
    N78165 A9100.73 F2920.057
    N78166 Z1.624 A9103.5 F2920.1332
    N78167 A9106.27 F2920.1593
    N78168 A9109.038 F2920.1423
    N78169 Z1.624 A9111.808 F2920.1138
    N78170 Z1.6241 A9114.577 F2920.0328
    N78171 Z1.6241 A9117.346 F2919.9311
    N78172 A9120.115 F2919.9173
    N78173 Z1.624 A9122.885 F2920.0789
    N78174 Z1.6238 A9125.654 F2920.3054
    N78175 Z1.6236 A9127.73 F3894.0383
    N78176 Z1.6239 A9129.462 F4671.4145
    N78177 Z1.624 A9132.23 F2920.18
    N78178 Z1.6241 A9135. F2919.9832
    N78179 Z1.624 A9137.77 F2919.9666
    N78180 Z1.6239 A9140.538 F2920.1462
    N78181 Z1.6238 A9143.308 F2920.3395
    N78182 Z1.6237 A9144.692 F5842.4078
    N78183 Z1.624 A9147.115 F3337.4513
    N78184 Z1.6241 A9149.885 F2920.0825
    N78185 Z1.6241 A9152.654 F2919.9397
    N78186 A9155.423 F2919.9145
    N78187 Z1.624 A9158.192 F2920.0179
    N78188 A9160.962 F2920.1313
    N78189 Z1.624 A9163.73 F2920.1909
    N78190 A9166.5 F2920.1762
    N78191 Z1.624 A9169.27 F2920.1232
    N78192 A9172.038 F2920.0592
    N78193 Z1.6241 A9174.808 F2919.953
    N78194 Z1.6241 A9177.577 F2919.9505
    N78195 Z1.624 A9180.346 F2920.1063
    N78196 Z1.624 A9182.77 F3336.9846
    N78197 Z1.6239 A9185.538 F2920.1626
    N78198 Z1.6241 A9187.962 F3336.9311
    N78199 A9190.73 F2920.0486
    N78200 Z1.624 A9193.5 F2920.116
    N78201 A9196.27 F2920.1556
    N78202 A9199.038 F2920.1476
    N78203 Z1.6241 A9201.808 F2920.0678
    N78204 A9204.577 F2919.9813
    N78205 Z1.6241 A9207.346 F2919.9228
    N78206 A9210.115 F2919.9195
    N78207 Z1.624 A9212.885 F2920.0531
    N78208 Z1.6239 A9215.654 F2920.2685
    N78209 Z1.6237 A9218.077 F3337.6436
    N78210 Z1.6239 A9219.462 F5842.3029
    N78211 Z1.624 A9222.23 F2920.1917
    N78212 Z1.6241 A9225. F2919.9888
    N78213 Z1.624 A9227.77 F2919.9774
    N78214 Z1.6239 A9230.538 F2920.1753
    N78215 Z1.6238 A9233.308 F2920.3639
    N78216 Z1.6236 A9235.038 F4671.5749
    N78217 Z1.624 A9237.115 F3893.8495
    N78218 Z1.6241 A9239.885 F2920.1088
    N78219 Z1.6241 A9242.654 F2919.9563
    N78220 Z1.6241 A9245.423 F2919.9333
    N78221 Z1.624 A9248.192 F2920.0381
    N78222 A9250.962 F2920.1263
    N78223 Z1.624 A9253.73 F2920.177
    N78224 A9256.5 F2920.1604
    N78225 A9259.27 F2920.1179
    N78226 Z1.6241 A9262.038 F2920.06
    N78227 Z1.6241 A9264.808 F2919.9475
    N78228 Z1.6241 A9267.577 F2919.9489
    N78229 Z1.624 A9270.346 F2920.1096
    N78230 Z1.624 A9272.77 F3337.4122
    N78231 Z1.6239 A9275.538 F2920.1487
    N78232 Z1.6241 A9277.962 F3337.3847
    N78233 Z1.624 A9280.73 F2920.06
    N78234 A9283.5 F2920.1179
    N78235 A9286.27 F2920.1604
    N78236 A9289.038 F2920.177
    N78237 A9291.808 F2920.1265
    N78238 Z1.6241 A9294.577 F2920.0378
    N78239 Z1.6241 A9297.346 F2919.9333
    N78240 Z1.6241 A9300.115 F2919.9563
    N78241 Z1.624 A9302.885 F2920.1088
    N78242 Z1.6239 A9305.654 F2920.2682
    N78243 Z1.6237 A9308.077 F3337.7736
    N78244 Z1.6239 A9309.462 F5838.6402
    N78245 Z1.624 A9312.23 F2920.1753
    N78246 Z1.6241 A9315. F2919.9774
    N78247 Z1.624 A9317.77 F2919.9888
    N78248 Z1.6239 A9320.538 F2920.1917
    N78249 Z1.6238 A9323.308 F2920.3741
    N78250 Z1.6237 A9324.692 F5842.4766
    N78251 Z1.624 A9327.115 F3337.4673
    N78252 Z1.6241 A9329.885 F2920.0686
    N78253 A9332.654 F2919.9403
    N78254 A9335.423 F2919.925
    N78255 A9338.192 F2919.9854
    N78256 Z1.624 A9340.962 F2920.0611
    N78257 A9343.73 F2920.1346
    N78258 A9346.5 F2920.1593
    N78259 A9349.27 F2920.116
    N78260 A9352.038 F2920.0486
    N78261 Z1.6241 A9354.808 F2919.9605
    N78262 A9357.577 F2919.943
    N78263 A9360. F3336.7189
    N78264 G94 Z1.7241 F229.1831
    N78265 G00 Z3.5926
    N78266 M09
    N78267 M05
    N78268 G53 Y0.
    N78269 M30
    Nate.
    Ann Arbor Meechigan
    Dec 2008
    4548
    Quote Originally Posted by nate View Post
    Here's the issues-
    1. if I set the stock wizard for a cylindrical workpiece and then generate code to cut a shape inside it (as pictured in the screen shot) why will it just generate code off the parts geometry. Shouldn't it allow me to generate code starting at the boundary of the stock and machine into the stock until I reach the parts geometry?
    What's the point of being forced to run the stock wizard, if the code fails to see the stock as stock to be removed?
    to run this part, without being able to start at the stock is irritating. I can only start at a level I pick for the start, BUT that level is dependant upon the Z location of the geometry underneath it. SO...I am stuck with cutting huge amounts of stock on some parts in a single pass, and very little stock when cutting at Z locations with a higher Z value of the part geometry.
    Only some of the toolpaths will react to stock. Some of the older toolpaths don't work off of stock. Setting the stock is also for the simulation.
    2. I am using a Mach3 PP written by bobcad (attached) it seems to send the tool to Y0 after a program completes. How can I eliminate this in the PP?
    Some of those are hard coded in the post. Look in the post under toolchanges and end of program blocks. Anything with quotes ("") around it will output just like that. If you don't want the Y0, you can delete "Y0" from the posting blocks.
    3. The simplest part of my part geometry (pictured) is the cylinder at the base of the skull. This should be the fastest part of the program. The cyl is concentric with my A axis, and should cut quite quickly seeing as it only has go to Z(location) and rotate in the A axis.
    Instead it seems to break up the cylinder into many many different segments (not of consistant angular size mind you) and this takes forever to cut. Oddly, the coordinated Z and A cuts for the skull seem to go much faster than the cuts for the cylinder.
    Could be numerous things. Might need the file to look at. Could be the machine settings. Hard to tell.
    4. I seem to have the A axis's rotation stop after every line of code that uses it. I would think that their would be a way to have it more smoothly flow into the next line. Is this a PP issue or one in Mach3?
    The machine is a BP with a peiseiler 4th axis all running steppers/SmoothStepperUSB/mach3.
    Thoughts?
    Again, hard to tell without a file to look at...
    Oct 2005
    278
    BurrMan-
    Thanks for your input.
    Would you PM me your email and I will get you the file. I don't have permission to post the file.
    best,
    Nate.
    Nate.
    Ann Arbor Meechigan
    Dec 2008
    4548
    Hi Nate, The forum says you've turned pm's off. You could email it to burrmanator at gmail dot com....
    Maybe if Al see's this he can jump in. He can connect with you on your computer and look at things locally.
    Apr 2008
    1577
    Here's the issues-
    Thoughts?
    I would not recommend (no matter who makes your rotary) to rough your stock using the rotary. I think if you watch some Youtube videos doing similar parts, you will see most CAM vendors and machine builders advise indexing the part, locking the A axis brake, then roughing in XYZ. When most of the material is removed, then switch to a finishing toolpath strategy. It looks like you started with a finish toolpath right off the get go. Try a Z level rough or an Advanced/Adaptive rough toolpath for the stock recognition.
    I have a Haas rotary. It specifically states that heavy machining,must be done with the brake engaged. If not, premature breakdown should be expected.
  1. Replies: 0
    Last Post: 08-30-2013, 07:21 AM
  2. Delta 20 post processor/ code issues
    By Kevin77 in forum Dynapath
    Last Post: 09-07-2011, 08:40 PM
  3. Taking a screenshot from Bobcad to post online
    By maxboostbusa in forum BobCad-Cam
    Last Post: 09-14-2009, 10:58 AM
  4. Post Processor (ISO G-Code)
    By cncadmin in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-29-2005, 02:33 PM
  5. Post Processor (ISO G-Code - Non Modal)
    Last Post: 01-29-2005, 02:32 PM
