586,655 active members*
3,982 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > G320 Issue - Servo moves upon startup
Results 1 to 4 of 4
    Jul 2007
    70
    This is a new install so i dont exactly know what normal startup is like. I got my mill wired and ready for power. As soon as I turned the power on my mill started moving unexpectedly until i shut off the power. I disconnected everything from the G320 except for the ground and power and there is 72vdc on arm+. Is this normal when there is no other wires hooked up? I checked the mosfets and none go to gnd. It seems all 3 drives do this same thing.
    Jan 2005
    15362
    turbotoys
    If the motors move when you power up you have an Encoder problem or a Encoder wiring problem
    Mactec54
    Jul 2007
    70
    I have rechecked my wiring and the encoder wiring seems fine. I have swapped the a and b channel but same thing happens. I tried a different encoder assembly and the same thing still occurs. I do not have a oscilloscope as of yet but i did just order one off of eBay few minutes ago (arrives in about a week) Is there anything else I can try with a regular VMM?
    Also shouldn't the drive fault out when it "runs" away like that?
    Jul 2007
    70
    I figured out this issue - The cable that I received from Industrial Hobbies had the +5v wire and channel A wire switched around. Once I figured that out everything was good.
  1. Mastercam V9 startup issue
    By anarchy4130 in forum Mastercam
    Last Post: 08-02-2013, 03:15 AM
  2. Haas VF3 startup issue no low gear
    By JHR1 in forum Haas Mills
    Last Post: 07-19-2011, 01:45 AM
  3. R2E3 Series 1 Startup Issue
    By rrperformance in forum Bridgeport / Hardinge Mills
    Last Post: 02-03-2011, 07:26 AM
  4. V2XT startup issue
    By V2XTnewbe in forum Bridgeport / Hardinge Mills
    Last Post: 06-07-2005, 07:26 PM
