586,604 active members*
3,489 visitors online*
    Aug 2004
    421
    Best way to handle an indexing axis
    I am adding a horizontal router to my Z axis, which has the ability to rotate 180 degrees. I plan to handle the indexing (0, 90, and 180 degrees) externally with ladder logic, what is the best way to interface this with Mach? Should I use M codes and somehow wait for a finish pulse? Ideas are much appreciated!
    Joe
    If you try to make everything idiot proof, someone will just breed a better idiot!
    Aug 2004
    421
    I had a thought, how about handling this like a toolchanger? T2 would be horizontal spindle at 0deg, T2 at 90deg, etc. Somehow I could write a macro in Mach to tell the PLC to index to a certain position, then wait for finish signal.
  1. Replies: 2
    Last Post: 01-06-2013, 03:08 AM
  2. 4 axis indexing
    By aldepoalo in forum BobCad-Cam
    Last Post: 11-02-2012, 04:50 PM
  3. Indexing on the 4th axis
    By bevinp in forum SprutCAM
    Last Post: 08-20-2010, 09:29 AM
  4. indexing 4th axis
    By 69ss396 in forum Haas Mills
    Last Post: 12-03-2008, 10:06 PM
  5. 4 axis indexing
    By camtd in forum PTC Pro/Manufacture
    Last Post: 05-12-2006, 01:20 PM
