586,637 active members*
2,818 visitors online*
    Dec 2004
    4
    Fagor 8025TG and WinDNC
    I am not having any luck connecting my 8025TG controller to a PC using WinDNC. I have tried lots of different configurations on the PC and controller searched for answers on the web and still am not having any luck - Spent way to much time on it but I really want to back up the programs on this old control so I am not starting from scratch if it dies.
    I am almost positive my cable is correct- I am looking for a step by step (preferably from someone who has this control and windnc working) to get this control to work with WinDNC so I can be sure I did not miss something simple.
    The control is on a upgrade technologies GT27 and I am able to communicate with my Fadal on the same computer flawlessly.
    Any help would be greatly appreciated.
    Trent
    Feb 2007
    11
    I just use command prompt to send files to my gt27 / 8025. have you tried that? I can give you the specs. connecting to the 8025 was / is tricky.
    Dec 2004
    4
    I got it to work by changing the 605 parameter to 10111000. Hope this helps someone else.
    Dec 2011
    73
    What was 605 set to before?
    Sent from my Nexus 7 using Tapatalk
    Apr 2014
    5
    Re: Fagor 8025TG and WinDNC
    Did you fix this problem? if not look up CNCNew.com so call they could walk you through problem.
  1. Desesperado con WinDnc y UN Fagor
    By JLAM in forum Spanish
    Last Post: 06-12-2013, 01:51 AM
  2. Fagor 8025TG
    By Oregon Rich in forum Fagor Automation
    Last Post: 10-22-2012, 08:17 AM
  3. Need help with Fagor 8025TG
    By AnOldUR in forum Fagor Automation
    Last Post: 09-29-2010, 12:31 PM
  4. G36 with fagor 8025TG
    By Captdave in forum Fagor Automation
    Last Post: 08-23-2010, 08:08 PM
