Hi Tom, sorry for the delay.
For example, the x-axis (ADC(0)). I doing it right?
Code:
// Two Axis Resolver Program 1/6/08
// outputs square wave to both resolvers using Aux Switch Output
// then samples output coils near positive and negative peaks
// takes the difference to compute magnitudes
// these ratios are used to match the amplitudes of sine:cosine
#define RATIO0 (978.0f/768.0f) // size j/size k
#define RATIO1 (978.0f/768.0f) // size n/size m
#define RATIO2 (978.0f/768.0f) // size p/size q
main()
int i=0;
int k0,j0,k1,j1;
int m0,n0,m1,n1;
int q0,p0,q1,p1;
SetBit(167); //+/-15V on
SetBitDirection(152,1); // configure AUX switch as output
DefineCoordSystem(0,1,2,-1); // Define 2 axis system
Delay_sec(0.1); // wait for +/- 15V to be stable
for (;;) // repeat forever
WaitNextTimeSlice(); // wait a few servo cycles
Delay_sec(10e-6); // wait for ADC conversion to complete
k0=ADC(0); // Sample all the ADCs
j0=ADC(1);
m0=ADC(2);
n0=ADC(3);
q0=ADC(4);
p0=ADC(5);
SetBit(152); // Switch the resolver excitation
//compute & track position based on measured magnitudes
DoResolverInput2(ch0,(k1-k0)*RATIO0,j1-j0);
DoResolverInput2(ch1,(m1-m0)*RATIO1,n1-n0);
DoResolverInput2(ch2,(q1-q0)*RATIO2,p1-p0);
k1=ADC(0); // Sample all the ADCs
j1=ADC(1);
m1=ADC(2);
n1=ADC(3);
q1=ADC(4);
p1=ADC(5);
ClearBit(152); // Switch the resolver excitation
#if 0 // enable this to print the magnitudes occasionally
if (++i==1000)
i=0;
printf("%5.0f %5d\n",k1-k0,j1-j0);
#endif
