586,331 active members*
4,288 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Torchmate > TM3 Issue transitioning from lines to arcs and arcs to lines: stuttering/jumping
    Dec 2013
    13
    Machine:
    Torchmate Small Shop Machine, 4x4, ~2007 original purchase
    501A(?) USB Signal Generator
    3A stepper motors (didn't think to write down the PNs)
    2.25hp DeWalt Router
    1/4in solid carbide router bit
    Torchmate 3 Driver Software (Torchmate's website is down, and I'm at work, so I can't double-check this!)
    BobCAD/CAM V21 gCode generation, Torchmate w/ FlashCut Post-Processor
    Computer: Windows 7 64bit (w/ 64bit 501A driver)
    I have a Torchmate Small Shop machine 4x4 table I just setup and am using as a CNC router. As of now I have successfully cut circles with good interpolation (i.e. they turned out consistently round and of the proper dimensions) and a few polygon profiles, both with no issues.
    My problem is that when I program the machine to cut a rectangle with fillets on the corners the drive 'jumps' or 'stutters' or 'jerks' right at the transition from cutting a straight line to an arc.
    I tried reducing feed rates down to 10ipm, reducing drive accelerations down to 2ips^2, turned the feedrate up to 12ipm (above the starting feedrate of 11.75ipm), I checked the X, Y, and Z drives for any loose drive components (belts, gears, etc) or backlash and fixed a few things, but they didn't solve my problem. The only adjustment that sort-of masked the problem was changing the maximum arc feedrate down to 1ipm, I experimented with it set to 10ipm and 70ipm (default).
    The problem was reproducible with no cutting forces on the router, I ran it 'in air' and still saw the stutter/jump/jerk.
    Any thoughts on what to try next? Any help would be greatly appreciated.
    Edit: I think I should add that the cuts are still turning out very repeatably. Its not missing any steps that I can detect after multiple passes on the same profile, even under cutting loads.
    Mar 2004
    413
    Flashcut can negotiate thru all sorts of mixed geometry be it short lines or short lines mixed with arcs without breaking a sweat when things are set correctly, so its not the control in itself....
    Are you using, or have you done a "save as" for a new setup from your plasma setup file ? If so, you would need to scour thru it to make sure things set for productive plasma operation do not inhibit router operations
    In your configuration/ feedrate/ramping section, is your Continuous Contouring Feedrate Tol. set higher than your start stop feedrate and ramping rate ? CCFT usually needs to be set higher or you can get momentary pauses at the end of geometry.
    In the same place, did the plasma system have the Max arc feedrate (under General) set to a lower rate than your trying to achieve ?
    In your configuration/ Motion Delays, has there been a change by chance to the "Direction Change Delays" or "Corner Delays" ? ?
    Flashcut does not have a specific setting for anything like "exact Stop" others are familiar with.... so it can't be that.
    I'll give this some more thought as to what you might be seeing there.......
    Chris L
    Dec 2013
    13
    Quote Originally Posted by datac View Post
    It was a fresh install from scratch, so I've only adjusted from default values on everything, though I will take yet another look through.
    I don't think I have set a value named anything like that. I will definitely look into this.
    Not sure, though when I have tried to make poor settings changes the software has caught it. I will double-check.
    No. I tried adding a 0.1s direction change delay, but it didn't affect transitioning from line to arc. That has been removed now though.
    I appreciate it, thanks!
    Dec 2013
    13
    Fixed!
    Feedrates were lower than the 'start movement' feedrates, and the CCFT rates were never initialized it seemed. All is well now.
    Thanks datac!
    Mar 2004
    413
    Well, its rather easy when you have a great control to work with !
    By the way, all those settings can be a real challenge to get the most of of your machine..... If you go to Flashcut's site and download the user manual, they do have a really good section on what those settings all accomplish as well as a routine/step by step method a person can use to dial it in.
    Glad I could help.
    Chris L
    Dec 2013
    13
    Glad I could help.
    Indeed!
    I found some tuning routines in Torchmate's documentation, and the FlashCut manual you mentioned, and I have a dial indicator to measure for missed steps, so that will be my next activity.
    Edit: looks like Torchmate copied and pasted the flashcut procedure into their manual!
    Again, I appreciate it!
  1. Break Arcs Into Lines Issue
    By ArchieF in forum NCPlot G-Code editor / backplotter
    Last Post: 09-09-2011, 05:47 PM
  2. arcs to lines
    By rmason in forum BobCad-Cam
    Last Post: 07-03-2011, 07:06 AM
  3. Incremental arcs and Break arcs into lines
    By forhire in forum NCPlot G-Code editor / backplotter
    Last Post: 09-16-2010, 04:55 PM
  4. Converting lines to arcs?
    By Fleck in forum Rhino 3D
    Last Post: 03-14-2009, 06:47 PM
  5. points to lines/arcs
    By vmax549 in forum Autodesk
    Last Post: 10-14-2008, 02:05 PM
