I am having a probem with Sprut importing files from the specified directory. I have set it in setup and saved it, run it as an administrator etc and it will not keep the specified directory in memory.
Once a file is imported it will retain the path as long as I dont close the program, once its closed and restarted it reverts "look in version 7" where the directorys should be located.
In setup the directories are correct for importing files, but I cant seem to get it saved to where it will retain what I have setup.
any help appreciated.......
