587,040 active members*
2,757 visitors online*
    Mar 2013
    10
    Morbidelli Author 213
    Hi all,
    Quite a few years ago my Dad bought a Morbidelli Author 213 but not any of the CAD/CAM software to go with it (Aspan?). When they sold him the machine, they made it sound like Aspan was tied to the machine so any other software wouldn't generate the "correct" g-code. Now that I've looked into it, I doubt that's really the case. Unfortunately I'm in another state so I can't just duck over to the factory to play with the machine (I will be going down at Christmas though). In the meantime, I'm getting my Dad to email me a few files contained on the floppy disc that's in his machine. I'm hoping I'll open up the files from the machine and they're just plain text g-code but if they're not then I'm in a bit of a tight spot.
    I did some googling and saw a bloke selling an identical machine, he put in the description "Works with all the major CAD/CAM software". That's encouraging but I'll have to see it before I believe it. I also did some searching on this forum and there was talk about a PGM file format which was essentially some for of g-code and a simple convert needed to be written to convert normal CAM g-code output to a PGM structure.
    I'll find out more about it once I crack open the files but in the meant time, does anyone know much about these machines or their g-code format?
    Apr 2013
    we have a cam with postprocessing for Morbidelli Author 213.. we can help you contact me [email protected]
    19
    Any cadcam system will work but you must convert the txt file to binary using a morbidelli utility called xiso. PM me if you want a copy. There is no license so nothing illegal in sharing it
    Re: Morbidelli Author 213
    Quote Originally Posted by loko View Post
    I know the subject is from long time ago, but do you think you could provide a copy of the winxiso.exe file ?
    I found a link on internet, but when I try to use it with this file:
    H DX828.00 DY357.00 DZ20.00 -A R5 *MM /OUT1
    F1
    B X85.50 Y257.30 Z29.00 V1 T18
    B Y332.30 V1 T18
    B X742.70 Y332.00 V1 T18
    B Y257.00 V1 T18
    B X1300.00 Y25.50 Z1.00 V2 T18
    I have the following error
    Compiled lines:7 Errors:52
    and it doen't produce the pgm file
    Could you send a copy of the utility or display a download link ?
    Dec 2017
    Sorry to wake this converstaion but i have a huge problem! I have recently bought morbidelli author 213 and I only have a Italian language manual, for two months now i cant use the machine it is just standing there! I dont know hot to start it or know to write one line to have her do anything!!! It is in perfect shape and it is just sad standing there! If anyone has some instruction or english manual i will be so thankfull! I would appreciate if u stil have that xiso software!
    ​THANK YOU ALL IN ADWANCE!
  1. Morbidelli Author 502
    By danarch in forum Commercial CNC Wood Routers
    Last Post: 02-28-2024, 09:19 PM
  2. Morbidelli Author 503
    By num1040 in forum CNC Machining Centers
    Last Post: 07-22-2018, 10:49 AM
  3. Morbidelli Author 344
    By tyretochka in forum CNC Machining Centers
    Last Post: 05-19-2012, 06:32 PM
  4. Morbidelli Author 430
    By Scooby Doo in forum Commercial CNC Wood Routers
    Last Post: 04-27-2012, 02:32 PM
  5. morbidelli author 504
    By msahin2012 in forum Commercial CNC Wood Routers
    Last Post: 05-19-2009, 01:06 PM
