Hi
I have a Fadal VMC 4020 machine with FADAL controller. It worked fine until the day before yesterday. When I turned it on it appeared on the screen:
"Error While Processing Block 0". It always appears since then and I can't use the CS command and work.
the Maintenance Manual says to use RI command but it doesn't work.
Any advise or suggestions what should I do next ?
