586,471 active members*
3,649 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > vfd and spindle installation and settings
    Mar 2006
    58
    hi everybody,
    i have purchased a chinese spindle rated 3 phase 220v 400hz 1.5kw, and an LG SV-IC5 frequency inverter (manual: http://www.rototech.com.au/pdf/SV-iC5.pdf) .
    Please may you advice me with the least I should do to run the spindle.
    I mean do I have to connect reactor or brake resistor or it is not necessary in my case?
    another question is how to control the inverter via mach?will i need an intermediary circuit or interface between the hobbycnc board and the vfd?
    thx in advance
    24223
    Via Modbus A new Huanyang VFD plugin
    Al.
  1. Replies: 13
    Last Post: 04-03-2014, 03:31 AM
  2. frequency inverter installation and settings
    By shreifali in forum Phase Converters
    Last Post: 11-22-2013, 07:38 PM
  3. X1 Spindle control relay installation (belt drive)
    By fragger6662000 in forum Benchtop Machines
    Last Post: 04-19-2010, 11:55 AM
  4. Bridgeport spindle bearing installation
    By L98FIERO in forum Bridgeport / Hardinge Mills
    Last Post: 01-24-2009, 06:39 PM
  5. Installation of spindle speed sensor
    By Bloy2004 in forum CNC Machine Related Electronics
    Last Post: 01-28-2004, 04:50 AM
