586,497 active members*
3,078 visitors online*
IndustryArena Forum > CAD Software > Uncategorised CAD Discussion > Need to get from SolidEdge V20 contour to toolpath G-code
Results 1 to 2 of 2
    Apr 2013
    18
    Question Need to get from SolidEdge V20 contour to toolpath G-code
    Hey guys
    So I'm making some parts in Solid Edge V20, among other things a spool for a flyereel, and I need to get the contour from the 3D model to a usable G-code.
    I'm using an Okuma LC-40 with an OSP5000L controller. I'm doing all the programing manualy, so I don't need the code from the stock piece to the finished part. Only the contour it self. And as the contour consist of both curves and arcs I can't do it all manual.
    Anyone know of any basic software that I can use for this, and how to go about?
    Can i use the .par files for this, or do I have to convert into something else?
    Thanks ahead guys
    Sep 2006
    10
    Re: Need to get from SolidEdge V20 contour to toolpath G-code
    Hello J,
    My 2D drawings I save as a DXF file, and I then import it with DeskCNC. From there on I create/modify the toolpath for milling the part. I'm sure there must be lots of software around that can do this.
  1. Need to get from SolidEdge V20 contour to toolpath G-code
    By jrolands in forum Uncategorised CAM Discussion
    Last Post: 09-17-2013, 10:20 PM
  2. Need to get from SolidEdge V20 contour to toolpath G-code
    Last Post: 09-17-2013, 09:15 PM
  3. Need help with Lathe Contour toolpath, please.
    By awolfoutwest in forum GibbsCAM
    Last Post: 11-23-2011, 05:23 AM
  4. contour toolpath containment
    By fjbart70 in forum Mastercam
    Last Post: 02-11-2011, 01:28 AM
  5. Surface contour toolpath (odd)
    By jnc in forum Mastercam
    Last Post: 04-23-2007, 01:16 AM
