I've seen a single ball screw configuration mounted under the table to move the gantry (assuming that is the x-axis), and I've seen a configuration where there is a stepper driven ball screw for each side. How is the dual stepper configuration hooked up. Can two stepper driver board inputs be connected in parallel to a breakout board output, so that they can be driven simultaneously? I'm guessing that the output signal of the breakout board is just 0 or 5v, for step or direction, so it should run the two parallel driver modules just fine. Anyone tried this?
