Hi Everyone,
I'm new to this forum. Thanks in advance for your expertise!
I am working on my first CNC build. It is a 2'x4' 8020 DIY machine with 3x Nema 23 380 oz-in steppers from cncrouterparts run by a Gecko G540. I purchased cncrouterparts' Nema 23 "3-axis electronics kit" which includes:
48V 7.3A switching power supply
Gecko G540 4 axis stepper motor driver
3 High-torque Nema 23 380 oz-in stepper motors (OEMOTOR 57BYGH433-06BS)
3 High-performance flexible motor cables: (1) 6'and (2) 12' cables
I have the latest version of Mach3 installed on Windows XP. Mach3 has the xml file provided by cncrouterparts for my specific motors loaded. I have the charge pump set to off on the G540 because otherwise it stays in fault. I have achieved movement on all axes.
I had some issues with the scale of the movements at first (g00 x1 would produce only a half a unit movement). I fixed this by doubling the "steps per" in the motor tuning. Now it runs so 1" in the gcode is 1" in real life.
After solving this problem I was excited to make my maiden cut. I started the router and ran the gcode (created in Aspire, exported for Mach 2/3) and it cut about ten of the holes before the G540 faulted. It faults whether or not the router is on, I have tried separating the components to different outlets in my studio and have the same problem. (I don't really know how sound the wiring is in this old building and I'm no electrician.)
I have run a variety of files from Aspire and the G540 faults at various points every time. What am I missing??? What else should I check? The only thing I haven't been able to test is the parallel cable from the G540 to the computer because I don't have a replacement laying around. Could this be it?
Please help me solve this so I can move on to playing with my awesome new router.
Logan
loganbeck.com
