I am getting a DRIVE AXIS FAULT every time I command the X-axis to move.
The motor doesn't actually move - not even a tiny bit. I can feel no movement.
I replaced the motor. After replacing it, I still got the axis fault message twice, but then it seemed to improve - now only failing with contouring and clamping errors which can be recoverable by hitting reset.
I poked around in the back of the X-axis, found a broken wire and fixed it. Now I'm back to DRIVE AXIS FAULT.
What would make the difference between a drive axis fault, and the lesser contouring/clamping failure, which at least indicates a willingness to command the motor?
So far, I've verified the following:
- The motor is good - I can jog it back and forth with a DC power supply.
- The tach is verified - 20V per 1000rpm.
- I found a single broken wire on the terminal block I hadn't noticed before and reconnected it.
I'm stuck. I could use some help, please.
Torin...
