586,489 active members*
2,473 visitors online*
IndustryArena Forum > CAM Software > SheetCam > Cut path issues
    Jul 2010
    28
    Cut path issues
    Hello, I have a cut path issue, cutting inside a western font which I've done once already, only changes were to art work, not letters. Now the letters aren't cutting or tool pathing completely, it's adding a small triangle to a right angle corner (what I call a keyhole) . Any suggestions Thanks Ray
    Did you double check your operation on SheetCam to make sure that there is no (key hole) in the letters?
    Jul 2010
    28
    Morning Lighting CNC, Yes I have cut the same letters same art work before, only thing I changed was to add eyes into horse silhouettes otherwise same thing I cut before as far as letters and they pathed correctly. This is what has me scratching my head.
    Ray
    Jul 2013
    15
    Are you cutting a pocket or line, if you are cutting a pocket and added another outline within the pocket sheet cam should throw up a warning, try putting the eyes on a different layer and treating it as a line with what ever offset is required ie inside, outside or none.
  1. Romi/Bridgeport EZ-Path Lathe serial transfer using EZ-Path Utilities
    By Moscow in forum Bridgeport / Romi Lathes
    Last Post: 06-04-2017, 04:37 AM
  2. Tool Path Issues
    By hst in forum BobCad-Cam
    Last Post: 11-06-2013, 02:33 AM
  3. Replies: 3
    Last Post: 10-07-2011, 05:45 PM
  4. G540 Mach3 Display Issues & Slave Axis Issues
    By umustsurf in forum Gecko Drives
    Last Post: 09-30-2011, 03:23 AM
  5. Path Issues - Which Software???
    By kingpav in forum CNC Wire Foam Cutter Machines
    Last Post: 05-20-2008, 03:58 AM
