I've got to program some jobs with a helical/spiral groove around a bar, (i.e. on the drawing looks like a figure of 8 on its side).
The last time the job was done (on different dia bar and shorter spiral) several of us had a go at programming it and we all got the same result, effectively, two lines, (i.e. C0 Z-50.; C180. Z-100.; C0. Z-50; , its metric, 50mm pitch helical/spiral groove). it was eventually programmed long hand, (all 360 degrees of movement with z move for each degree).
There must be an easier way!
Can anyone help, please!
Cheers Jim
