I'm kind of out of the options here. I've tried everything. Basically my machine produces strange wobbly/jagged results as you can see from the image attached.
So far, machine worked great without any issues whatsoever. Transmission is Ahren's rack and pinion and drive is Gecko G540. Machine has been in light production for 4 years now. It's a 3-axis machine.
Issue is most prominent when doing circles and arcs, as if interpolation is wrong or something. I have throughly checked mechanics and everything seems to be in order, so my conclusion is that it's either some electric/electronic part or something in software. I'm running this on Mach3 (haven't changed versions, so it can't be that?) and I have tried to contact gecko to see if they have seen this behavior or if they have some idea - but they haven't responded at all. So much for support.
So guys, please, have you seen this type of issue before or have any ideas what might be the cause? I'm all out of options.
