586,588 active members*
2,907 visitors online*
Results 1 to 4 of 4
    Jul 2013
    5
    Question Chuck cannot be clamped/Unclamped
    I bought a CNC lathe, model KND, K1Ti (identical with FANUC CNC systems).
    The chuck of the machine looks locked, it seems I cannot open
    it or close it manually as shown in the attached photo.
    In my machine panel, there is no control key to clamp/unclamp
    the chuck. So I think I should open/close it by a program.
    I run the following program:
    M11 // chuck unclamped
    G04 U3 // dwell for 3 seconds
    M10 // chuck clamped
    and nothing happened. The chuck does not move.
    Although I hear a sound of a relay that dilever 24v to something when I run M11 and
    there is another relay that also dilever 24v when I run M10.
    Does that mean there is a 24v motor that controls the chuck? It looks so.
    What could be the problem? Is it a wiring problem or software problem?
    Should I check the cables? What is your suggestions?
    Nov 2013
    17
    Hi, I don't know the machine but it sounds like solenoid valve problem.
    Jul 2005
    12177
    Has the machine been unused for a long time? I had a chuck stop working simply because the draw tube was rusted to the spindle.
    Feb 2009
    6028
    Do you have hydraulic pressure, is the phase backwards.
    Sent from my G-Tab Quantum using Tapatalk
