587,070 active members*
2,975 visitors online*
Page 1 of 10 123
Results 1 to 20 of 184
    Dec 2004
    1316
    Jason's 5x10 Router Build
    After contemplating it for a while I decided to make a start at building a router that could hold at least a full sheet of plywood. this wouild be my third router but the first metal one.
    I have access to 2" by 4" rectangular hollow section metal which I will use for the bearing assembly pictured, to run on. I left a space between the bottom bearings in order to support the long axis.
    I also have access to lots of skate bearings(608 series) from frequent copier scrapping and the 5/16" threaded rod is cheap and strong enough to tie the whole assembly together, it also fits the bearings with minimal play.
    It looks I should be using in the region of 64 bearings which will be no problem.
    The solid metal bar that makes up the corners of the runner assembly is 16mm (~5/8") square and was a pain to drill even after marking the holes with a center punch. After having the drill bit wander too many times I went looking for Black & Decker's bullet point drill bits or DeWalt's pilot point bits. These bits have a tip somewhat like a brad point bit for wood but the pilot or bullet point bit will drill metal, wood or plastic.
    I will get some hollow section this week to give a visual idea of how the setup will work.
    It appears that gear track will be the mode of motion for the long axis which then raises the question of whether the long axis will be driven from both sides, one side or the middle.
    My CAD skills are ok but I should make up for that with lots of pics.
    Jason
    Jul 2003
    276
    WOW! Looks like i is going to be a big machine if those are the linear bearings
    Are you going to tie the bottom of that assembly together? Seems like it would splay out on the bottom.
    Oct 2005
    612
    John,
    I found it better to place a couple of washers between the double bearing when I trialed it. There is a bit of play between the threaded rod and bearing and one beariing always lifted higher than the other. It is only slight but if you hold the bearings and spin the threaded rod you can feel it. The washers between the bearings spaced the bearings slightly apart and helped. Hold the bearings against a flat surface as you tighten the threaded rod and you should get a better result.
    cheers,
    Rod
    Perth, Western Australia
    Dec 2004
    1316
    The problem with tying the bottom together is that there would be no way to support the long axis. The top of the bearing assembly would be fastened to the assembly on the opposite side so there should be no problem.
    Jason
    Jul 2003
    276
    doh! yep
    Dec 2004
    1316
    Rod
    I have also felt that movement, I was thinking however that when I tightened the whole assembly to the running surface all the bearings would at the same level together.
    Jason
    Aug 2004
    3215
    Quote Originally Posted by Jason Marsha
    Rod
    Jason
    The bearings should pull up tight to the threaded rod and have no play when tightened from both side.
    Have you thought about belt drive for both sides for the X Axis?
    Dec 2004
    1316
    Joe
    I guess I was avoiding belts but I may have to consider them if they will give me the most bang for the buck. Has anyone used belts with sucess in the forum?
    Jason
    Feb 2005
    578
    Benny used belts and really liked them.
    http://www.cnczone.com/forums/showthread.php?t=6143
    Steve
    Dec 2004
    1316
    Thanks Steve.
    Jason
    Dec 2004
    1316
    After giving belts an examination it seems that they may be the best option for me. Belts can be rolled up and easily transported eg suitcase, that would be a bit harder with gear track. I have family due for a visit to the island soon, so I will probably have them bring the belts for me.
    I like Benny's design as well as a design from Europe, I will probably rig up a hybrid of the two machines. My only concern is the belt stretching. Is there a special type of belt for this application?
    Jason
    Feb 2005
    578
    After thinking about this, belts do seem like the easiest and cheapest way to go. 10 feet rules out screws. Have not priced gear track, but seems expensive and hard to gear down and align. With a 5 foot wide gantry, I would think you need to drive from both sides. Use an axle at both ends, with split belts tied to the gantry. You would only need one motor that way, driving the axle in the middle, under the table.
    Seems like everyone goes to SDP/SI for belts and gears.
    http://www.sdp-si.com/
    Dang, this seems like a fun project, especially if you are getting some of the components for “free”.
    Steve
    Dec 2004
    1316
    Thats right Steve, SDP/SI has a very wide selection of gears, belts and pulley parts. They seem a little pricey but quality is what matters.
    I will ask Benny what is the pitch of the belt he is using for his machine.
    Jason
    Jul 2003
    276
    You might want to down the belt drive doc . loads of info
    http://www.sdp-si.com/D757/Libdownload.htm
    Dec 2004
    1316
    Thanks Randy,
    Downloading as I type. I suspect this information is in one of the catalogs they sent me a while back "Handbook of Timing Belts and Pulleys". Its full of info on what belts and pulleys to use, actually I think its a bit much (information overload) :drowning:
    I went over to Benny's thread and saw that he had used T5 , 16mm wide belts.
    From reading the SDP/SI catalog the GT2 belts seem to be the best to use, I will have to check the cost first to be sure.
    If the cost is right for me I will probably go for the GT2 5mm pitch, 15mm wide belt.
    I think I will have fun with this project.
    Jason
    Dec 2004
    1316
    Due to length, that belt I want is a special order. I will email them and see what they quote me.
    Jason
    Dec 2004
    1316
    The smallest pulley recommended for this 15mm wide belt is a 18 groove pulley. If I drove the shaft with the pulley attached is driven directly with the stepper I would be moving the axis about 1.1* pi inches (27.94 * pi mm) per turn of the motor. At 500 rpm those figures translate into 1727.88 inches (43,888 mm ) per minute which seems awful fast and I suspect I would need a rather strong stepper to move the gantry back and forth even at a slower speed. It looks like lots of gearing down in order
    The pulley info has pitch diameter and outside diameter listed I am not sure which to use for step calculations.
    Jason
    Nov 2005
    53
    Jason,
    movement per rotation is effective diameter * pi. I suspect it is more than 28mm with an 18t pulley. Actually i think you forgot to multiply by pi.
    550ipm doesn't sound *that* fast.. how about 1650
    What european design did you refer to earlier?
    Regards
    K
    P.S. i will start a build log/planning log for my machine soon, also a belt driven design.
    Nov 2004
    126
    Sweet with you and Joe both working on 4x8+ designs, by the time i finish my jgro, and build joes 2006 you guys should have some nice designs to look at for expanding further.
    Keep it comin!!!
    Apr 2006
    512
    How much do you think belt slipage and stretch will effect accuracy/precision on a design of this size?
Page 1 of 10 123
  1. New Feedback From Jason About OMNI 4'*8' Cnc Wood Router
    By omnicnc in forum News Announcements
    Last Post: 10-30-2012, 07:06 AM
