Did you lose the Bios settings for RT-board, Sol? And are you capable of flashing it yourself?
If so you need to identify the rt-board id-number.
thanks mvas82
yes i removed the bios battery to Chang it and i also take a backup from the HD
now i already set the bios again and i have a mini prog and good exp. in microcontroler and EPROM but i think the bios is good because i started up the mother board by external power supply and VGA
