586,762 active members*
8,562 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > A20 Citizen guide bushing belt change
    Aug 2013
    4
    Hey Guys,
    Quick question, ha are there ever....
    Bearings went bad on my A20 Swiss main spindle guide bushing timing shaft, so we replaced all of the bearing and the main spindle drive belt lost some teeth so we replaced that too, the guide bushing drive belt is in good shape, do the belts have to be matched or can we just replace one then adjust the tension out.
    If we need to do the guide bushing belt, what is the best way to remove the guide bushing housing?
    Apr 2009
    101
    I replaced the belts on our A20 after the started squealing after about 3 years of use.
    You do not need to remove the guide bushing. There is a cover on the headstock side of the guide bushing that comes off and a small window to the left of the guide bushing when looking into the machine. Remove that cover and window and you can access the belt without removing the GB.
    Look at the exploded drawings in the maintenance manual for more details.
    Aug 2013
    4
    Thanks, we got it out but still a *****
  1. guide bushing range
    By hacdlux in forum CNC Swiss Screw Machines
    Last Post: 11-01-2022, 12:05 PM
  2. Guide Bushing
    By apalm in forum CNC Swiss Screw Machines
    Last Post: 08-14-2013, 11:43 AM
  3. rough turned stock through guide bushing
    Last Post: 04-04-2011, 11:15 PM
  4. Guide bushing scratching on 303....
    By PoiToi in forum CNC Swiss Screw Machines
    Last Post: 02-28-2009, 08:20 AM
  5. Pneuamtic Guide Bushing Assm on Citizen's
    By JMS4287 in forum Uncategorised MetalWorking Machines
    Last Post: 08-29-2007, 01:45 PM
