I am using master chemical trim e206 and while none of the exposed surfaces show a spec of corrosion, the underside of the vise, and table surface had a patina after 3 weeks of sitting there. I think putting down some way oil first will help solve this issue. Also make sure you are running at the higher end of the coolant concentration. Master chemical recommends 3-10% for my coolant, with 7-10% being recommended for longest life and minimal corrosion. I use 7%
