586,635 active members*
3,071 visitors online*
    Apr 2006
    proximity switches
    I own a shopbot prt standard 4x8 i want to fit proximity limitswitches on the x and y rails using mechanical contact switches can any advise me about how to go about wiring these switches to the machine? thanks
    Dec 2005
    3319
    1. Buy good switches designed for dirty/wet industrial use (IE: Honeywell microswitch).
    2. Don't use dry use, light duty electrical/electronic switches.
    3. Machine wiring depends on the machine control/controller. Insufficient information to provide specific instructions.
    24223
    Quote Originally Posted by woodguy7777
    i want to fit proximity limitswitches ...... using mechanical contact switches
    Proximity switches do not have mechanical contacts.
    If you are looking at true proximity type, there are a few configurations, DC, AC, AC/DC, three wire, two wire.
    For the three wire there are sink or source type.
    Selection depends on the interface used or required.
    Al.
    Jul 2005
    12177
    proximity limitswitches..... using mechanical contact switches
    I suppose it would be possible to claim that a magnetic reed switch is a proximity switch with mechanical contacts. Provided the machine was not going to be creating particles or dust from a ferromagnetic material they could be a good way to get a combination of durability, dirt proof and electrical simplicity at a low cost.
    24223
    Good Point.
    I'm so used to working with Hall effect.
    Al.
