Just joined the forum, after months of trolling various Forums and searching on Google, I'm about to take a leap of faith and order from China.
LG900 from G weike (900x900)
I do need a laser that is accurate,(so the cuts are right size not 2 mm bigger or smaller) so need some advice on what I can add to it to make it as good as it possibly can be. I will be engraving cutting a mixture of different materials
Ive asked for the following
6565 series Based DSP Board
3 Phase Stepper Motor on all axis
Molybdenum-Mirrors (>25mm)
CW5000 Water chiller
reci CO2 laser tube W4 130W
Chain appose to belt to raise the bed.
Why do people ask for different size lenses? and should I order different size lenses for different applications?
Is there anything that I've missed that you think i should order?
1 last thing, should i ask for the stepper motors to be powered from a separate source, and the rest of the laser from a separate source? (so 2 power sources)
Thank you
Gio
