586,384 active members*
3,576 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > I need the pinout for a Fanuc Servo Motor (6 pin/wire)
    Feb 2010
    16
    I need to know which wires from the servo amp goes to each pin on a Fanuc servo motor ( A06B-0373-B571#7008 ). The 6 wires were pulled/ripped out of the wire connector on the motor after a drastic tool changing crash. I can't find a manual for the servo motor The plug is 6 prong female (A63L-0001-0428).
    Thanks in Advance.
    Feb 2010
    16
    SOLVED:
    Servo Amp_______Servo Motor
    U(UM)..................Pin 1 (Red)
    V(VM)..................Pin 2 (White)
    W(WM)................Pin 3 (Black)
    G(GM)..................Pin 4 (Green)
    ..........................Pin 5 (not used in my case)
    ..........................Pin 6 (not used in my case)
  1. 536 Servo alarm Fanuc Tape Cut W1 Wire EDM 5Axis
    By anoop.kp in forum EDM Discussion General Topics
    Last Post: 05-29-2012, 08:35 PM
  2. Replies: 4
    Last Post: 09-08-2011, 11:41 PM
  3. Replies: 0
    Last Post: 07-02-2010, 06:01 AM
  4. stepper motore 8 wire need pinout thanks
    By chawkiz in forum Stepper Motors / Drives
    Last Post: 02-15-2009, 08:39 PM
  5. Westamp servo board pinout help
    By metlcutr55 in forum DNC Problems and Solutions
    Last Post: 07-01-2008, 04:50 PM
