586,500 active members*
1,541 visitors online*
IndustryArena Forum > Other Machines > CNC Wire Foam Cutter Machines > Shuttle parallel port revisited
    Nov 2007
    18
    Unhappy Shuttle parallel port revisited
    Hello me again.
    After a long absence due to a wiring problem in my vision I am back into experimenting with my lathe and future three axis machine running on EMC2. After a call out for redundant computers with a parallel port, I have inherited yet another Shuttle PC. I have had another go using a PCI parallel port card but with no success. An earlier response indicated that EMC2 Foamworks and Mach3 will drive via the PCI card. I suspect that this is because as with Foamworks, Mach3 uses the windows driver rather than as I suspect, re-configuring the parallel port driver/configuration when EMC2 is loaded onto a Shuttle. So I guess I must attempt to get into I believe the HAL file and put things right. So if anyone is able to guide a non software wizard such as myself then I would be chuffed to have a go. Any offers?
    Regards
    Ken
    Jan 2011
    I realize this post is a few months old, but I just completed an install of a Shuttle with a PCI card on LinuxCNC. I had issues until I realized that the Shuttle has a header on the board for the parallel port and in LinuxCNC I was talking to the non-existent header rather than the PCI parallel port card. Try a dmesg|grep parport command in terminal and make sure you have the correct address specified. See if the PCI card has a different address than the one you are entering into the software.
    Jan 2010
    2141
    Quote Originally Posted by kbraat View Post
    I don't have that problem, but that's an interesting approach to finding out the parallel port address (I'm only an occasional Linux user and so it's good to see how others use the system).
    IIRC there is also an lspci command that may lead you to the same info.
    Jun 2009
    251
    Re: Shuttle parallel port revisited
    I have 2 Shuttle systems with add on pci cards with NetMos chips and they both work flawlessly with Linuxcnc, on both cases you will need to change the parport address on the stepconf wizard or in the .hal file of your config. In both cases i had to use an 0DD.. address.
    As mentioned above use "lspci -v" and find your card so you can see exactly what addresses your card is using and put that in config or hal file.
    Tom
  1. parallel port
    By BIG IGG in forum Tormach Personal CNC Mill
    Last Post: 07-29-2013, 11:24 PM
  2. Parallel port issue on Shuttle PC,s
    By GEFR in forum CNC Wire Foam Cutter Machines
    Last Post: 06-19-2012, 10:46 PM
  3. parallel port or parallel universe
    By bruno34 in forum Taig Mills / Lathes
    Last Post: 04-15-2009, 04:58 PM
  4. Second parallel port?
    By essa in forum LinuxCNC (formerly EMC2)
    Last Post: 04-12-2006, 08:18 AM
  5. Parallel port
    By Aldoseri in forum BobCad-Cam
    Last Post: 03-13-2006, 05:10 PM
