586,645 active members*
2,059 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Feed Plane Overwriting Rapid Plane V26
Results 1 to 8 of 8
    Sep 2013
    9
    I am drilling holes with a rapid plane of 2" to clear some clamps. I have my feed plane at .1 because i don't want to be feeding air for two inches. However when the tool path is computed the drill rapids to .1 from hole to hole. I changed the posted code from G99 to 98 so it will hopefully work. But how do i get the computed toolpath to rapid to 2" and feed at .1? Thank you.
    Apr 2008
    1577
    Quote Originally Posted by Jbrown74 View Post
    It is the G98/G99 setting that is causing the behavior you describe. You may have to edit your PP to make sure it only uses G98. I don't know your particular machine but if I program a G99 in any drill cycle, the tool will only return to the "R" plane before moving to the next hole. G98 will force the tool to return to the Rapid plane, move to the next hole, then rapid down to the R plane.
    Dec 2005
    121
    In the V26 software for drilling the Rapid Plane Value is the Initial Plane Value. And the Feed Plane Value is the Retract Value for the Drilling Canned Cycles. If you are long coding these then they would be rapid and feed panes
    MikeG
    Sep 2013
    9
    I guess I will just have to change the G99 to G98 manually, does anyone know how to make it automatically post to G98? Thank you for the clarification MikeTheG.
    Jun 2008
    1838
    Try opening your PP in Notepad and look for the lines that control the G98/G99 output shown below :-
    515. Output G99 instead of G98 in drilling? y
    516. Output G98/G99 in drilling? y
    I believe changing the "y" to "n" in line 515 should do it.
    Remember just "Save" the PP after modifying, do not do a "Save as" or the PP will just be saved as a txt file and not a MillPst file.
    Regards
    Rob
    :rainfro: :rainfro: :rainfro:
    Sep 2013
    9
    Thanks a lot Engine, the computed tool path is still off but at least I don't have to manually changed the code every time. And the predator backplot seems to be running the correct path.
    Dec 2011
    295
    PS how do you save as to MILLPST. I want a copy for safe keeping.
    bobcad guy Guest
    Well, if you " copy" the file, it would be a millpst file, and just rename it. But, might I warn you, I think you should never modify your actual post, I only modify a copy of the post, and after proving out that no unintended change have occured, then I will save the new edited post as my day to day post. Just my opinion
  1. adjusting feed plane to allow rapid move
    By bobcad guy in forum BobCad-Cam
    Last Post: 05-13-2013, 02:06 PM
  2. Drill Cycle Rapid Plane B769
    By seal1966 in forum BobCad-Cam
    Last Post: 10-17-2012, 09:41 PM
  3. Drill Cycle Pecks from Rapid Plane
    By Miksak in forum BobCad-Cam
    Last Post: 01-26-2012, 06:18 PM
  4. Replies: 8
    Last Post: 09-03-2009, 07:18 PM
  5. cycles initial plane/retract plane
    By HuFlungDung in forum OneCNC
    Last Post: 06-27-2003, 01:02 AM
