I'm not sure of what the original intent for the pocket is, but the issue in the file is there is multiple "stacked" and various entity types. Here's a picture where I took one of the pockets and reselected the geometry for it and enabled adaptive and computed, without changing any parameters:
Attachment 206882
I think the geometry selection needs to be addressed. If you blank the solid, you can see the pocket areas have lines extracted. The end lines have dashed lines underneath. I would suspect that the pockets have 2 open ends selected? I selected the 4 edges and put them on a seperate layer, then set the linetypes as I wanted, on "just 4 entities". The pocket then works ok.....
