i just got some pull studs that were custom made for BT30, and they are slightly too large in diameter, about 0.020" over. the rest of the measurements are perfect. the part that is too big is the flat part between the two angles on the little ball at the top. (bt30)
i have access to a hardinge super precision hlv-h at work, im wondering if its okay to turn down the diameter and call it a day? or will i be removing the hardened shell and causing problems of some kind?
btw i dont use the lathe very often..im thinking to do this ill chuck a piece of 1" aluminum bar stock in a 5c collet, the center drill, drill, and tap for the pull stud threads in the end of the bar. screw in the pull stud, check to make sure its running true, then turn it down. does that seem right?
why do they harden them anyway? just to be resistant to scratches and pits, or is it because of some engineering requirement in the drawbar or to increase the tensile strength?
