586,307 active members*
3,351 visitors online*
IndustryArena Forum > CAM Software > FeatureCAM CAD/CAM > Need help with simultaneous 4th axis
Results 1 to 5 of 5
    Oct 2013
    3
    Does anybody know how to machine a Helix, simultaneously with a 4th axis,on the outside of a 400mm dia part using FeatureCam. I have a solid model imported from solidworks, is there an easy solution to this? Am I just not clicking the right buttons?
    Oct 2013
    1
    Apr 2013
    25
    Yes, make a groove, set your parameters. Make sure when you start/import the part 4 axis rotary index is on on the appropriate axis. Make the groove, set the angle to the helix angle, and select wrap feature around index axis.
    Oct 2013
    3
    Thanks Shamanj, got it sorted out
    Apr 2013
    25
    Re: Need help with simultaneous 4th axis
    Yeah I'm a bit of a gun at 4th axis. Send my the model and I'll see whats up. You can machine with the Y offset at a particular location. Look for Y offset in the help dialogue
  1. Need help with simultaneous 4th axis
    By mgmcnc in forum FeatureCAM CAD/CAM
    Last Post: 10-24-2013, 03:53 AM
  2. PP for heidenhain 426 5 axis simultaneous
    By strupi in forum OneCNC
    Last Post: 09-19-2012, 05:02 AM
  3. 4 axis simultaneous milling
    By svarzaru in forum FeatureCAM CAD/CAM
    Last Post: 07-05-2012, 05:33 AM
  4. simultaneous 4th and 5th axis work
    By jess fuqua in forum Mastercam
    Last Post: 06-23-2010, 02:15 PM
  5. simultaneous 4th and 5th axis work
    By jess fuqua in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 06-11-2010, 04:51 PM
