Hi my names is John and I have a 4020 i am retired so now it's playtime.
Hello all! I am an engineer doing civil work now but had some background in machine shop and drafting tools like ProE. I hope to be able to build parts for pedal steel guitars and whatnot eventually.
Hi my name is Nelson Santo and I have a Opticut 1100 and in my playtime i like to use my cnc machine and i hope that can one here can help-me .
Best Regards
Nelson Santo
Howdy Everyone
Been doing artwork layouts in my scant spare time for 2d plaques and suchlike.
Hi guys. I am only mechanical engineering student. I am from turkey.
I am Rector of a public institution of my city!, Since young I have gone through the modeling, electronics, robotics, programming and business management, I am in the process of retirement and wish to return it all together with this project, in my country is not easy! but we must do it!
I hope I have patience with my questions and doubts, I am compiling the second hand steps engines and searching for electronics components for my first attempt, so is that bother you enough!
Soy Rector de una institución publica de mi ciudad!, Desde joven he transitado por el modelismo, la electrónica, la robotica, la programacion y la administración de empresas, estoy en proceso de jubilación y deseo retomar todo eso junto con este proyecto, en mi pais no es facil! pero por eso debemos hacerlo!
Espero me tengan paciencia con mis preguntas y dudas, estoy recopilando los motores de segunda y buscando los componentes de la electrónica para mi primer intento, asi es que molestare bastante!
Thank you GOnzalo
Hi all
I design, laser cut and build large scale r/c model planes, I was also a cnc programmer for a cabinet makers untill recently. At home I use TurboCAD, CorelDraw and a GCC LaserPro X252 lasercutter.
Hi , I'm a machinist from Puerto Rico looking for knowledge.
Hi, my name is Dylan, I used to be a cnc programmer/operator on a SAOM 300SE using AlphaCam for a cabinet makers untill recently. I now design, laser-cut and build large scale model r/c aircraft. I currently use TurboCAD, CorelDraw X6, DevCAM and a GCC LaserPro X252 laser cutter.
Hey guys,
Using an alibi. Based in India. Inherited a machine shop. Here to learn,share and get better
Here to learn, share and stay.
Hello, I'm an R&D engineer at a loudspeaker manufacturing company, and have a side interest in diy CNC although I'm very much a beginner here. Have built a 3d printer (reprap) which was a great success and now look forward to moving on to a more serious cnc 3 axis router. The idea is for something that can cut aluminium moulds for a small injection moulding machine. I hope to build on the pronciples I learned from the 3d printer, but I expect there is lots to learn about rigid constructions and much more demanding forces!
Cheers!
Hello all! I am a technician with an FA lab located north of Houston. We recently acquired an old Sodick A320L to help us cut hard facings and acquire fine cuts. We've been having issue after issue with it, so I'm hoping to find some help and eventually share my experience as I gain it.
hi! i'm italian boy and i would like cnc...
i use artcam
Hello,
I am a horizontal lathe machinist from Connecticut looking to advance my knowledge.
hello my name is leonel, developer of Mastercam but only in 2D, I hope to find help for programming in 3D
Hello!
I am a cnc operator for both wood and metal fabrication. Look forward to sharing and learning on this forum!
Hello
I am quite new to the world of cnc. I know to program via artcam pro. I would like to learn more and invest more in CNC.
Hello all, my name is Mark.
I have been lasercutting for 4 years now. Next step is build my own machine, as in 'german quality for chinese price'
since two months I've got myself a small cnc machine.
I am here to share and learn everything there is to know about lasercutting....
Hello. I have rover A 3.30. I have problem while tool change automaticly. error code is "tool change disable (tooled manually). error in tool change parameters preset instructions" . How I can solve it.
Great thanks
I'm a machine operator , have 6 cnc machines , two haases, two matsuura , daewoo puma 8s, eccoa sj
