Originally Posted by
KKamel
i want to make the top square with the sides so double stick tape doesnt work, the sides on this particular project is going to be a glue joint so it doesnt matter that much but i imagine there will be other boards that it will do.
If you don't have vacuum, double stick tape is pretty much the only way to go. It's an even thickness so space it every so often and you should be good and the sides will be square to the top..
Cam clamps from the side might work as well but they can cause the workpiece to go convex on top if you clamp them down too hard.
-Andy B.
http://www.birkonium.com CNC for Luthiers and Industry http://banduramaker.blogspot.com
