586,125 active members*
2,807 visitors online*
    Jan 2013
    23
    Accessing Macro Variable from another macro
    Hi is it possible to access a variable assigned in one macro from a different macro?
    M810.m1s
    Dim MyVariable
    MyVariable=123.456
    M811.m1s
    Dim MyNewVariable
    MyNewVariable=MyVariable/2
    ex-egll
    It would depend on the machine you are running. In the Fanuc machines I run the variables are stored in the machines variable list. The values will stay in those variables until the machine is powered down or overwritten.
    I can set a value in variable #100 and then call it from any program in place of a value.
    Brad English
    fanucmilling.com
  1. Macro b variable order
    By Diggitdude in forum Parametric Programing
    Last Post: 01-13-2014, 06:02 AM
  2. Macro/Variable Programing
    By chadr03 in forum WinCnc
    Last Post: 02-02-2011, 02:00 PM
  3. macro b local variable
    By samu in forum Fanuc
    Last Post: 12-19-2010, 12:55 AM
  4. Macro Variable Lock
    By James L in forum Haas Mills
    Last Post: 07-23-2009, 02:29 PM
  5. Macro variable example I programmed today.
    By theemudracer in forum G-Code Programing
    Last Post: 03-08-2007, 03:50 AM
