586,664 active members*
5,600 visitors online*
Results 1 to 20 of 22
    Nov 2003
    287
    MTW MD001 CNC Conversion
    I am converting my second RF45 style machine to CNC and thought I would share the parts made to complete project. Currently I have most of the parts machined for the 3 axis. I am using 20mm ball screws for the X and Y and 25mm for the Z. My method does require some lite machining of the casting for clearance and to create interlocking areas for the ball nuts. Soon as I format the drawings I will get them posted.
    Attachment 204642Attachment 204644Attachment 204646Attachment 204646Attachment 204648Attachment 204650Attachment 204652Attachment 204654Attachment 204656Attachment 204658
    Oct 2009
    483
    vertcnc,
    Nice work so far. I've been contemplating an IH clone mill, so I'll be following your conversion closely.
    Any sort of quality control issues on your particular mill?
    Subscribed.
    Titaniumboy
    Nov 2003
    287
    Titaniumboy,
    Quality control is very limited on these machines. X and Y Axis seem pretty good. Z Axis will need some more work, ways are tight on one end loose on the other. Should n't be that much work to repair. They use lots of Bondo to make up for poor finishing of the castings. You just have to keep in mind these are a hobby quality machine and really are limited. But, If you work through the issues, and install CNC with decent parts you can really make some nice quality parts, just probably not on a production level. I am guessing for about $6000-7000 including machine and depending on skill level, you can have a nice machine. If your not a DIY kind of person or need light production then I would look at the Novakon Torus Pro or Tormach.
    Nov 2003
    287
    Nov 2012
    220
    Nice work man This will be fun to watch :cheers:
    Aug 2008
    1186
    Re: MTW MD001 CNC Conversion
    Any updates on the build? This is looking awesome!
    Nov 2009
    4415
    This is a nice looking build. I wonder what he was using to build the parts displayed?
    A lazy man does it twice.
    Nov 2003
    287
    Fastest,
    An Enco 45 converted to CNC. Sold after completing MD001. The pictures above show the pulley setup I was contemplating, but decided to go direct drive with couplers. Works great rapids set at 300IPM
    May have the MD001 for sale soon, Looking for Haas VMC.
    Nov 2009
    4415
    Well lets see your pictures, bound to be a nice build!
    Nov 2003
    287
    Here are the Solidworks files for the parts used to convert the MTW MD001 to CNC. Should work on most RF45 type machines. 20mm ballscrews on X and Y and 25mm on Z. These will require some light machining on the Y saddle and also the Z slide. Nema 34 size motors direct coupled to the ballscrews.
    Nov 2003
    287
    MTW MD001 now for sale
    I am going to list this mill for sale shortly, moving on to another project.
    MTW MD001 oversize RF45 type mill.
    Mach3 control
    10 pos tool changer for TTS tooling
    Stand on wheels with metal chip tray setup for flood coolant.
    Electrical cabinet- with ESS, servo drives, power supplies, PC
    Ballscrews 25mm on Z, 20mm on X & Y
    Leadshine Easyservo motors and drives. 300 ipm x&y , 180ipm Z
    Belt drive spindle w/ 2:1 pulleys, 3HP 3 phase motor, VFD 220V 1 Phase 8000rpm
    Air operated drawbar.
    Automated Lube system for ways and ballscrews
    Flood coolant system
    Located west of Chicago
    PM me if interested.
    $8000
    Attachment 261146Attachment 261148
    Nov 2003
    287
    For sale on Craigslist now. $6500 Pick-Up Only
    Feb 2009
    137
    why would you not post the CL add link?
    Nov 2003
    287
    Not sure it was allowed, but here it is.
    Hobby CNC Milling Machine
    Jun 2013
    75
    Damn! Wish you were closer. I've wanted a charter oak 12z cnc for a little while now but for that price, I'd definitely get yours. Good luck with the sale.
    Nov 2003
    287
    Yeah it's pretty much same machine as a Charter Oak. Have lots of money into it, so will be a good deal for someone. Easy to rent a little box truck with a lift gate.
    Aug 2013
    194
    I shared your ad on another forum, hopefully you will get some calls.
    Nov 2003
    287
    Jul 2016
    41
    What happened with the drawings you were going to post ??
    Nov 2003
    287
    What drawings? The ones on the previous page.
  1. Dave's MD001 CNC conversion
    By dave111 in forum Benchtop Machines
    Last Post: 03-13-2015, 04:30 AM
  2. Austin's MD001 / IH clone CNC conversion build
    By BrownDesert in forum Benchtop Machines
    Last Post: 06-24-2014, 01:22 PM
  3. Plans or Kit for IH mill / MTW MD001
    By Titaniumboy in forum Benchtop Machines
    Last Post: 10-24-2013, 04:42 AM
  4. New MTW MD001
    By Redgoatfab in forum Benchtop Machines
    Last Post: 03-02-2012, 04:36 PM
  5. MD001 gibs
    By yooooda in forum Benchtop Machines
    Last Post: 03-02-2012, 05:48 AM
