586,991 active members*
3,450 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Power Supply Replacement for RJ Controller
    Oct 2013
    Hi All,
    I recently "inherited" an old Fanuc Arc Mate Sr. and RJ controller for my lab. It's been a useful tool and a lot of students have benefited from hands-on time with the machine. Unfortunately, the controller has stopped powering on. After pressing the "on" switch, everything powers on, fans come on, main relay engages; however the main relay then disengages and the controller powers off. All of this happens within about a second. I have run through Fanuc's diagnostic steps and concluded that there is a short somewhere on the PSU board. Sound reasonable? The PSU board looks to be in bad physical shape as well, lots of crud around the bases of several capacitors. If I scrape of some of the crud, fiddle around with the components, and reinsert the board into the backpane, the controller will usually power on and stay on for a few minutes to an hour. Does anyone have any other theories or insight into this behavior?
    The PSU board is part #A16B-1212-0531/01A. I'm planning on replacing it with another board purchased from ebay, part #A16B-1212-0531/06B. My understanding is that the last three characters of the part # are the board revision, and that upgrading to a newer revision should be OK. Is this assumption correct?
    Cheers, and thanks to everyone for your time and assistance!
    i am not sure about it , but i know that some guy can help you out , you can search hilasercnc from google. there is videos and bloges to guide you, good luck
  1. replacement power supply
    By bartniswonger in forum Xylotex
    Last Post: 10-18-2013, 02:23 PM
  2. Setting up Bridgeport 412 TNC2500 after power supply replacement
    By gatesy in forum Bridgeport / Hardinge Mills
    Last Post: 05-27-2013, 01:46 AM
  3. controller power supply 115/230v OK for Australian power?
    By Momill in forum Australia, New Zealand Club House
    Last Post: 07-07-2011, 05:06 PM
  4. Power Supply Repair/Replacement
    By 2Bits in forum CNC Machine Related Electronics
    Last Post: 11-07-2010, 12:07 AM
  5. Power Supply Repair/Replacement
    By 2Bits in forum DIY CNC Router Table Machines
    Last Post: 11-05-2010, 09:35 PM
