586,265 active members*
3,612 visitors online*
IndustryArena Forum > Community Club House > Gecko G540 A Axis has no output.
    Oct 2013
    Hi All,
    New here at the zone.
    Am doing a CNC build right now using a USB Smooth Stepper, Mach 3 and a Gecko G540 with 2 x-axis motors.
    Having a problem right now that I can't seem to resolve!!!
    Have everything hooked up and everything works great except for I have no output coming out of my A-axis.
    Have re-assigned pin outputs and moved motors around. I know that all the motors are ok and that all outputs work except what is coming out of the A-Axis port. I have control of the A-axis when pins are re-assigned(eg. z-axis changed to 8&9), but not the motor that is plugged into the A port.
    Have also opened the G540 and moved G250 drivers around and they all work in different places except for the A-port.
    Hoping its not the motherboard of the g540... Any suggestions?
    I do want to add that all 4 motors do lock up when everything is powered up and I can get rid of some of the A motor idle noise with the A trim pot.
    Any help would be appreciated.
    Mike
    Apr 2004
    5740
    Call Geckodrives and ask them about this. It sounds like you might have a defective board. Fortunately, it's not Chinese - you can get tech support for it in English. If they agree that it's defective after having you do some tests, they'll probably exchange it for another one - they're good about things like that.
    Andrew Werby
    www.computersculpture.com
    Oct 2013
    Thanks Andrew,
    Just called them and am arranging to ship it to them.
    Hopefully it won't take too long!!!
    Mike
  1. Replies: 1
    Last Post: 08-27-2018, 08:41 AM
  2. Replies: 0
    Last Post: 05-04-2013, 08:19 PM
  3. 2 Motors 1 Axis Driver in Gecko G540
    By guy2b1 in forum DIY CNC Router Table Machines
    Last Post: 06-10-2012, 04:00 AM
  4. Gecko G540 4-axis Stepper Controller Kit and Schematic
    By phomann in forum Australia, New Zealand Club House
    Last Post: 01-19-2010, 01:38 AM
  5. Config for 2 motors on x-axis (w/ Gecko g540)
    By rogerer in forum LinuxCNC (formerly EMC2)
    Last Post: 05-17-2009, 03:30 AM
