586,903 active members*
2,813 visitors online*
Thread: Foam cutter
    Apr 2003
    90
    Foam cutter
    I ran into this machine today (not literally). I know the company that supplies them with the scanner, so I thought I would check out the site. Amazing what can be done with a CNC foam cutter!
    Streamline CNC
    Paul Riedlinger
    Let the chips fall where they may...I'm not going to clean them up!
    Sep 2003
    1472
    This is an interesting site. Looking forward to seeing what you find out about the scanner.
    Hager Hay
    Apr 2003
    90
    Hager
    My company owns one of the scanners. We bought it directly from the manufacturer (in Denmark) about 3 years ago. The company is ScanTeck and there web site is
    Scantech
    It is a phenomenal piece of hardware/software for a fairly reasonable price (industrial wise not hobby!). We use it to scan carvings and reproduce them in wood.
    I was talking with the owner of Scantech this morning and found out that Streamline is the new exclusive distributor in North America. That is how I stumbled upon the site.
    Paul Riedlinger
    Sep 2003
    1472
    Paul,
    Does the scanner do a single plane scan or does it do arcs in a few different directions?
    Hager
    Apr 2003
    90
    Yes and no! How is that for an answer!
    The unit we have only does flat plane, but the new units can do arc scanning as well. It is a software upgrade we never made. If you go onto their website you can see the info on arc scanning. If you have any questions, email them. Claus it the president and will answer you right back.
    Paul Riedlinger
  1. Replies: 6
    Last Post: 06-18-2005, 05:19 PM
  2. one piece foam cutter
    By bladestalker in forum CNC Wire Foam Cutter Machines
    Last Post: 06-09-2005, 12:36 AM
  3. Using a controller and motors from a foam cutter
    By Quicker in forum DIY CNC Router Table Machines
    Last Post: 04-08-2005, 10:06 PM
  4. EDM CAM to control Foam Cutter?
    By vacpress in forum Mastercam
    Last Post: 03-31-2004, 01:05 AM
  5. Good Foam Cutter CAM Software?
    By vacpress in forum Uncategorised CAM Discussion
    Last Post: 03-31-2004, 12:26 AM
