I recently put the TiN-coated "general" insert in the SuperFly through 17-4 PH (Condition A, which I've heard is sticky compared to the aged grades of 17-4 PH). I noticed a couple things.
First, the surface finish suffered as a result of the insert not being square with the surface. I've made some mirror-like finishes on 6061 (see my youtube videos for some input on feeds and speeds), so I was surprised that the 17-4 surface felt serrated as a result of the insert being out of square.
Second, the feed and speed is more challenging in 17-4 PH (Condition A) to get a good finish. It's clear that the stickiness is affecting surface finish. I get some rippling from chatter, and I'll also be left with what almost very small chips stuck to the surface or tiny curls of metal that didn't get cut completely off. I've been playing at .010" DOC with the tool set to about 2.5 WOC (and a 1.1" wide piece of stock), feed rates of 15-20 IPM, spindle speeds of 750 to 1500 rpm, no coolant. The 6061 has been very forgiving running at 2500 rpm and 30 IPM (as a baseline) with a variety of cut depths and I'm practically making mirrors with flood coolant.
Christopher Anglin
www.mc2racing.com
